Flooded car
Submitted: Monday, Apr 10, 2006 at 21:35
F4Phantom
I flooded my navara on the weekend up to the centre console. Now when I drive I have a sloshing sound. I have tried to tell myself it's the
fuel but I cant ever remember hearing the
fuel in the
tank before. And the sound is noisy and interior sounding. I have searched for cavities and cant find any. The car is just pressed steel, all single layer. EG, where the rear
seat buldge is under the beanch
seat, it's hollow under the car. Does anyone know of any cavities in the navara (the older one not the brand newie) that could retain
water, probably only accessable (meaning able to be filled) from the inside of the car. I would really like to drill some holes and empty my onboard
water carrying
tank. Thanks.
Reply By: MATT.D(WA) - Monday, Apr 10, 2006 at 21:40
F4,
People pay big dollars for these onboard
water containers, you've saved a fortune. Hope the Navara's allright.
Goodluck
166278
Reply By: Trevor R (QLD) - Monday, Apr 10, 2006 at 21:45
I am pressuming you have checked in the doors, some of the drain holes may be blocked???
My old Rocky went swimming, it takes a while to get things sorted again.
Good luck and regards Trevor.
166281
Reply By: F4Phantom - Monday, Apr 10, 2006 at 21:50
Yeah car is fine, I just want access to this new
water container. The doors are empty, its easy to check cause you just wave em around a bit. The sloshing comes from accelerating and braking. Kind of near the rear of the cab behind the
seat. I hope I dont have to use the evaporation method, it's winter and that will take some time. perhaps it will freeze solid and provide me with a massive onbord esky.
166290
Follow Up By: GaryInOz (Vic) - Monday, Apr 10, 2006 at 22:24
Is there a storage tub under the rear carpet? They can fill easily and have their holes blocked by leaves or papers/plastic that you may have left in
the tub.
I did a similar thing to my vehicle, except I have a largish spare tyre tub. Boy, does that hold some
water.................
421188
Reply By: Peter 2 - Monday, Apr 10, 2006 at 22:01
Probably the sills under the doors, have a look along the bottom of the body under the doors, there should be either drain slots or bungs.
166298
Follow Up By: F4Phantom - Monday, Apr 10, 2006 at 22:07
ok thanks. I just had a look, there are not any but i may drill a hole or 2 in that area to make sure. Good old silicon is my bung.
421179
Follow Up By: Member - Oldplodder (QLD) - Tuesday, Apr 11, 2006 at 08:00
If it is in the sills or some other cavity, once the
water is out, put some fish oil, or penetrol or tectyl (what ever is your favourite) in to slosh around and chase the moisture in the seams. Then bung up again.
421230
Reply By: streeter - Monday, Apr 10, 2006 at 22:05
your not the phantom warrnambool bloke who got bogged at killarny yesterday are you head lines in todays paper Ilegal
beach drive leaves driver all at sea the
water was lapping over the bonnet plus he got booked for driving on
the beach
166299
Follow Up By: F4Phantom - Monday, Apr 10, 2006 at 22:23
If that was me I think I would be posting about the effectivness of those electric rust proofing things, wether they work on already rusting panels in contact with sea
water, where to buy them and if anyone wants to buy a used nissan, good nick, little rust, restore or parts.
421185
Reply By: Utemad - Monday, Apr 10, 2006 at 22:46
Dual or single cab?
My dual cab Rodeo has an inacessible cavity under the rear
seat. I've filled that with muddy
water before.
Either that or has been said in the door sills.
166310
Follow Up By: F4Phantom - Tuesday, Apr 11, 2006 at 08:36
dual cab, and I recon this could be it. When you say inaccessable, how do you access it?
421244
Follow Up By: Utemad - Tuesday, Apr 11, 2006 at 08:47
My Rodeo has two rubber grommets on the underside of the cavity (under the car).
Mine filled up as one of the rubber grommets was missing (so
mine drained as soon as I was out of the muddy hole but it left the mud residue in the cavity). However it could fill from inside the car as if you lift up the rear
seat the jack and
tools are stored in a sectioned off part of this cavity. However the silicon seals around the edges of this sectioned off bit have left some gaps so
water could get in there too if you drowned your car.
421246
Reply By: Member - Bware (Tweed Valley) - Tuesday, Apr 11, 2006 at 00:23
Where are the photos?
166327
Reply By: Member - Beatit (QLD) - Tuesday, Apr 11, 2006 at 07:51
Dear Mr Phantom,
Just to discount the obvious - your not sloshed are you?
Kind regards
166355
Reply By: Member - Crazie (VIC) - Tuesday, Apr 11, 2006 at 08:42
Hi Cary
Sorry to hear mate, Where did you swim it?
Ads
166369
Follow Up By: F4Phantom - Tuesday, Apr 11, 2006 at 08:50
a bog filled track at toolangi, actually it was all my fault. i thought i would be smart, think ahead and rig up the snatch before i tried a hole, i then proceeded to put the strap through the DOOR, not the window. so when i got stuck,
water leaked a small amount through the panels, which is fine, but to get the snatch out i had to open the door!! idiot. so of course the flood was not heald back and rushed in giving me a really nice rustic smell as i work each day. no probs tho, even the inverter and laptop cables kept going as i got them out of the
water fast.
i would post a photo but i have not bothered to learn how to do it yet.
421248
Reply By: F4Phantom - Tuesday, Apr 11, 2006 at 16:29
Thanks everyone, I drilled 6 holes in the sills below the doors there is a U shape. Most of these holes leaked the brown stuff, the sloshing is dying down. I will fill with penetrol and let that do some sloshing of it's own and also bung up the holes. This is is a story that ended with good news.
166465
Reply By: Member -Dodger - Tuesday, Apr 11, 2006 at 17:33
Phantom,
Lift the scratch pads on top of the sill where you get in, often there are small holes that are used to help hold the kick pads and with these you can insert fish oil or the like.
166486
Follow Up By: F4Phantom - Tuesday, Apr 11, 2006 at 17:39
brilliant advice, i was thinking i was having to pump it it upwards through my holes. Thanks for that.
421349
