batterys in a jayco hawk
Submitted: Monday, May 01, 2006 at 13:05
ThreadID: 33410 Views:2423 Replies:4 FollowUps:0
Hi i have just got a 2004 hawk and dont know where to place the deep cycle batters. i was told thay should not be placed rear of the axel(as vibration will wreck them) but in a hawk thats where all the room is if any one has an idea let me know
Reply By: matty g - Monday, May 01, 2006 at 20:51
I have a jayco swan out back 84 model , i have put my two deep cycle batteries
as close to the centre as posible , in a cabinet that is on the right just as you walk in the door . Just happens to be right in front of the axles , this might work for you as your layout may be different. Good luck
AnswerID: 170109
Reply By: Muzzgit (WA) - Monday, May 01, 2006 at 21:30
Most people put them under the couch, which I think runs in front of the main bed.
As for............
"i was told thay should not be placed rear of the axel(as vibration will wreck them)"
I don't think it's viabration that dictates you don't put them rear of the axle, it's more likely to be a balance thing.
Jayco campers are balanced to have around 120KG on the towball. Puting heavy objects rear of the axle upsets this balance, and if you have ever towed a trailer that "wags the dog" you won't want to do it again. What happens is, you get steered all over the road by your trailer, and at 100 klm it's quite scary.
AnswerID: 170126
Reply By: Member - Andy Q (VIC) - Monday, May 01, 2006 at 23:38
G'day emgirl, On our Jayco Dove we placed our battery in the cupboard, below the sink
AnswerID: 170147
Reply By: GTVic - Wednesday, May 03, 2006 at 21:23
We have a 2004 Hawk ob with a deep cycle sla battery located in the compartment behind the setec power unit (the obvious place as you suggested). To prevent any movement, the battery has been fastened securely to the floor using some battery clamps (purchased from BatteryWorld). Wiring was straightforward as close to setec unit where wires connect. An isolation switch and voltmeter (purchased from Jaycar) were installed on sidewall of battery compartment which is also accessible from external storage door - that enables convenient isolation of battery during storage and monitoring voltage during periods of use.
Travelled well over 10,000km (incl several 1000km offroad) and no problems yet...
AnswerID: 170544
