Waeco Fridge
Submitted: Friday, May 05, 2006 at 21:45
ThreadID: 33592 Views:4139 Replies:6 FollowUps:4
Have just purchased a 50l Waeco and we are still considering whether or not to use it as a freezer only. The question is once the fridge has reached the preset operating temperature (say -18) would it draw more power maintaining this temperature than say a preset temperature of say -3.
Reply By: Derek from Affordable Batteries & Radiators - Friday, May 05, 2006 at 21:57
Yes it will and the outside temperature will also play a role. Why would you want -18 ?
When you open the fridge in will increase in temp and then take a long time to get back down to -18.
AnswerID: 171048
Reply By: Voxson (Adelaide) - Friday, May 05, 2006 at 22:23
With Kryovac facilities who would want to freeze anything...??
AnswerID: 171056
Follow Up By: Mad Dog (Australia) - Friday, May 05, 2006 at 22:39
People who take can't leave the icecream at home.
FollowupID: 426479
Follow Up By: Gramps (NSW) - Saturday, May 06, 2006 at 18:34
You mean there are people who go camping WITHOUT one of the main food groups - ice cream ???? Bugger !!!
FollowupID: 426635
Reply By: Alloy c/t - Friday, May 05, 2006 at 22:32
Wait for member no1 {nudie} to reply ,fridge guru par excelence , however basic refridgeration theory and some lateral thinking will give you the answer ,,the colder the object already frozen the longer to defrost , ergo the initial cool down will consume more power ,after that to maintain temp you will use NO more power at any given ambient than if you have a higher set temp , at -18 your goods act as a freeze bank ,at -3 goods are barely frozen and defrost in next to no time , a 50lt waeco uses the bd35 comp , would expect to use 45/50 amps per 24hrs set at -18 ,know for fact that our 80lt waeco with the bigger donk bd50 uses 64amp per 24hrs set on -18 ,, the only time that we used our 80 as all fridge set at 2/4 deg our power usage almost doubled to 115amps per 24hr.
AnswerID: 171060
Follow Up By: Mainey (WA) - Saturday, May 06, 2006 at 03:06
Not sure member no1 would agree with -> " would expect to use 45/50 amps per 24hrs, when set at -18 deg.
know for fact that our 80lt Waeco with the bigger donk bd50 uses 64amp per 24hrs, when set at -18 deg.
The only time that we used our 80 as ALL fridge set at 2/4 deg, our power usage almost doubled to 115 amps per 24hr"
FollowupID: 426504
Reply By: AdrianLR (VIC) - Friday, May 05, 2006 at 23:01
When you remove the frozen food I assume you will replace it with fresh food that will need to freeze? If this is the case then you will use power to remove the heat from the new food. If you replace it with already frozen food (eg from the supermarket freezer) you still use some power but nowhere near as much.
Theoretically, in a full fridge, frozen food will remain below zero until it all melts and then the temp inside the fridge will rise. -3 however is probably not enough to have all of the food completely frozen due to salts and other things (ie it is not pure water that you're freezing) so it doesn't take much to melt it all and have the temp vary. In typical car fridges the insulation is not that good so the bigger the frozen lump inside is the longer it will take for the temp to rise and the lower the amount of power required to keep everything below zero.
If it's a freezer then where do you keep the drinks?
AnswerID: 171068
Reply By: brett - Saturday, May 06, 2006 at 12:51
If you cryovac your meat you can easily get two weeks in the fridge, even longer if you freeze it before hand and run the Waeco on 3 lights which is around 0 deg. Stick the meat down the bottom of the fridge and on 3 lights it will take days before it's thawed out. I took some cryovaced meat up to Fraser for nearly 2 weeks that was first frozen, didn't use it, came home for a few days left the Waeco running, off on another trip for a week still didn't use it and cooked it up when I got home no problems.
AnswerID: 171129
Reply By: bombsquad - Saturday, May 06, 2006 at 15:16
Although I don't have the figures to back up my asumptions, I'msure a fridge set on -18 will use more power than set at say 0 degrees. I am sure that the energy consumed would have a direct relationship with the difference between the inside temparature and outside temparature. eg -18 in th fridge, 30 outside = 48 degrees difference, wheras 0 deg and 30 deg is only 30. this would be the case for equal fridge loads and temparatures already down at presets. to get a full fridge of 4 degree food down to -18 would take some time and energy.
Cheers Andrew
AnswerID: 171143
Follow Up By: brett - Saturday, May 06, 2006 at 18:28
I tend to agree, I don't have any figures but I have run my waeco once as a freezer and never added anything to it, only took stuff out, and at the highest setting it almost ran continuosly and this was on mount panorama at bathurst in october so temps were not veryhigh. Inside temp I think was about -20 from memory. When on 3 lights which is 0 deg it certainly doesn't run continuosly far from it, but depends on outside temp
FollowupID: 426633
