Saturday, May 06, 2006 at 14:56
G'day Paul,
I've got a 2000 model GU and I've spent a lot of $$$$$ on it trying to get maximum power and cooling.....haven't been too concerned about economy up until recently. The other blokes have concentrated their responses on engine mods etc. This is all okay, but there are a couple of more basic things to also be thrown into the mix.
1. If you have a roof rack or bars, this will sap your economy by about 10%. I fitted a ARB heavy, full length roof rack when I bought the vehicle new in 2000 and it hasn't been off ever since....This is because of the permanent gear I have up there like UHF aerial, air horns, rearward-facing lights, shovel etc.
2. Tyre pressures; I used to run my tyres on bitumen at 32psi. I now run 42psi. This will assist lower the rolling resistence of your truck on the black top and will assist with economy.
3. Tyre type; I use Goodyear MTRs which are boardering on being a mud-terrain tyre. I know this decreases my economy, but it's one of those trade-offs I can live with. I go off road too often to bother with farting around with a dedicated set of off road rubber and another set of highway tyres. However, the latter type will save you some
fuel.
4. Weight; if you wanna save money on
fuel, put your truck on a crash diet (sorry, poor choice of words...."crash"......when talking about motor vehicle). I've given up on this one except that I do take the heavy crate of recovery gear out of my truck except when I go on a trip. Also, I have a dual spare wheel set-up with heavy rear bar (no plastic at the front or back of my rig!!! ;-)). Even after trying to get rid of any non-used gear,
mine still weighs over 3T before I load up for a trip!!
Now, as far as the under bonnet mods are concerned.........I've had a 3" mandrel bent system for a few years now with a larger dump pipe. I don't believe the fitment of that system improved my economy. More recently (October 2005), I chucked the standard old Nissan turbo (which apparently is the same one that Nissan has on it's 3.3L MQ Patrol back in the 1980's, so you will appreciate that it probably is a bit under-sized for the job at hand.......but that's the sort of thing Nissan does.....don't forget the more recent 4.2TDI uses the same intercooler as the 2.8L Patrol had!!!.....they don't like to see anything go to waste over there at Nissan!!!!!). The turbo was replaced by a Denco kit which utilises a Schwitzer turbo. I was fortunate enough to have had
mine done by
Berri Diesel Service, SA and the blokes there were (unlike most workshops) happy enough for me to hang around for the day and watch the work be done. As such I saw the new and old turbos side-by-side on the work bench..........man, was there some difference in the size of those 2 hair-dryers or what!!!!!!????? They cranked my boost up from 12psi (factory is around 8 or 9 psi) to 15psi.
I've achieved more power and quicker spooling of the snail, but haven't changed my economy at all. It's worth noting that the 3" exhaust system which i fitted in 2003 is still on the vehicle and it utilises a straight-through Lukey hot-dog muffler and no other mongrel things like resonators etc. It is no louder than a standard 4.2TD, but does have a different "note".
In short, I don't think there are any sure-fire
fuel-saving methods for the 4.2TD, other than drive like granny. You own a "truck" and need to expect it to drink like one (unfortunately). The alternative would be to sell it and get a 3L......now that'll save you some money (on
fuel).....but don't spend the savings on beer, cos you're gunna have to save up for a new motor after 100,000klm or so!!!!!! (Sorry to all those satisfied 3L owners;-))))
Roachie
171142
Follow Up By: Member - JohnR (Vic)&Moses - Sunday, May 07, 2006 at 08:18
G'day Bill, I was pleasantly surprised to get 1200 kms
tank to
tank the other day in Moses including low ratio work over
the Pyrenees with the Riverlanders. This was the first time I had really watched it after fitting the 3" mandrel bent system.
I know I would have been beating grannie a few times at the ligfhts as I have been watching the Stop
sign into
Timboon to the 80kph and see what I can get to. (Just as
well as there havent been any hairdryers out taking note) Even with that it has been better than 14.6 litres/100km. Regulars will remember Moses isn't a lightweight, so I was pleased. Should be able to coach him to do better some time.
NAB girls and boys taking me to the footy early August mate. Pity it's a Saints/Weagles match.
426716
Follow Up By: Member - Roachie (SA) - Sunday, May 07, 2006 at 12:58
G'day John,
That's not too bad (ie: 14.6L/100) and would be about equal to the best figures I've ever recorded (longish trip without trailer.......pretty rare for me...hahaha).
However, to get 1200
tank to
tank (and I just checked your rig profile info), may I ask what your capacity is? I seem to recall the cab chassis has 2 x 95 litre tanks? That is a bit more than my 145 + 34, but I reckon the most klicks I've ever had is about 1100klm from both tanks.......But then again, I know my speedo is out by around 7% (so when I say I've done 1100 klm, I know I've done more like 1177klm). However, that 1100 figure is rare..........I'm usually looking for a fill-up at around 800 to 900klm as the sub has been pumped and the main is showing a quarter (which really means it has got stuff all left in it afaik).
Cheers mate......I'll have to charge some extra fees to clients to make-up for the cost of sending you to the corporate box!!!!!! hahahaha
Roachie
426755
Follow Up By: Member - JohnR (Vic)&Moses - Sunday, May 07, 2006 at 17:27
I thought you had spent the corporate box entitlements on the GU mods Bill. I am glad you are thoughtful enough to contribute enough to our night at the footy. One of your agribusiness competitors is taking me out to dinner interstate in July. They know how to entertain.
I have the standard tanks on the Coil Cab totalling 175 litres. A 95 l. main
tank and the 80 l. subtank. I usually empty the subtank before the other gets too far down and fill it first to check the
fuel bowser against it. 80 litres or less is good. Did get in excess of 85 in
Mildura once at a discount outlet in the 80 litre
tank. My speedometer is out by about 4% but the odometer is very good when I have checked against the GPS.
426787
