NITROGEN TYRE INFLATION
Submitted: Friday, Feb 14, 2003 at 17:07
rum pig
JUST LIKE TO KNOW IF ANY ONE IS USING NITROGEN IN THEIR TYRES READ AN ARTICLE TODAY SAYING $15.00 FOR AN 18INCH TYRE AND FREE REFILL IN THE EVENT OF A PUNCTURE POSSIBLY NOT REALLY SUITED TO 4X4 AS IT WOULD BE QUITE EXPENSIVE IF THEY HAD TO BE DEFLATED FOR OFF ROAD BEACH ETC BUT I AM CURIOUS FOR ON ROAD
Reply By: ThePublican - Friday, Feb 14, 2003 at 17:37
Have had nitrogen in my m/cycle tyres for the last 2 years ,pressure has not varied in that time, B/JANE had $10 per wheel about 8/9 mths ago when fitted new tyres to trouble and strifes car,no pressure variations as yet ,would be a waste on my 4x4 as need to vary pressure for monthly beach trips ,
13130
Reply By: baz - Friday, Feb 14, 2003 at 17:46
Rum pig,
have had nitrogen in my 295 BFGS AT'S for 10 months,have done 40,000klms hard driving," and as the publican says," the tyre pressure does not alter.I get them checked every 10,000klms .
regards,
baz.
13131
Reply By: David W - Friday, Feb 14, 2003 at 18:57
Ordinary air from the petrol station compressor is about 80% nitrogen, and usually is filtered so it contains no moisture. About 18% of what comes out of the compressor is oxygen, and the remaining few percent is argon.
Aircraft use nitrogen in their tyres because of the tremendous heat generated when landing and braking: the tyres can get hot enough that the oxygen in an air-filled tyre can auto-ignite (ie the tyre explodes). By filling with nitrogen, and so removing most of the oxygen, this problem is greaty reduced. That's why truck use it and racing cars use it.
Apparenty oxygen inside a tyre accelerates the aging of rubber, but 99% of us will puncture the tyre or wear out the tread before it falls apart because of oxygen aging. Also, oxygen will diffuse out of the tyre a bit faster than nitrogen.
So, by using air you will need to check the pressure more often, but aside from that, I'm not sure why pure nitrogen is supposed to be SO much better, and I wouldn't be surprised if it was anything more than a way of getting you to pay $60 to get your tyres pumped up!
13134
Follow Up By: Diamond - Friday, Feb 14, 2003 at 20:29
fair coment david fair coments nitrogen was something bob jane uses to get a few dollars more out the customer along with his gold wheel balances i worked in bob jane and was made to unbalance tyres if the customer didnt get gold balances and when they do come back explain that a gold tyre balance should fix the problem.oh and just a couple of other things im still great friends with the management and staff at the store i worked for so no sour grapes and when when i say unbalance tyres i should have said unbalance only by about 10-15 grams
7681
Follow Up By: Member - Moggs - Friday, Feb 14, 2003 at 23:56
Daimond, doesn't surprise me, always had suspicions about this practice happening at one near us - absolutely disgusting rip-off. Nothing bleep es me off more than having someone knowingly ripping off people who have no knowledge and trust in the 'experts' to do the right thing.
7699
Follow Up By: Truckster - Saturday, Feb 15, 2003 at 08:58
Diamond you could make GOOD money and lots more friends sellin that story to Current Affair...
7713
Reply By: sean - Friday, Feb 14, 2003 at 20:28
I have had Nitrogen in my BFG,s for 2 years - 40,000k.
Tyres never get got but thats just BFGs anyway - they all run cool. Maybe they run too cool cos they have slowly chipped away. Never added any air in that time. Honestly, for these type of tyres, I cant see any advantage.
Just my opinion
Sean
13139
Reply By: victatwo - Friday, Feb 14, 2003 at 21:14
Just for interest for years I carried a D cyl of nitrogen in the back together with an air line and regulator for the bottle, good system and could inflate tyres faster than a service station, the bottle would do about 30 10x15 tyres from nil to 30 psi cost wise it was much cheaper than an expensive comp depending on use as a refill was only $40 and plus if the worst came to the worst you had a very efficient fire ext on board
victatwo
13146
Follow Up By: Member - Bob - Sunday, Feb 16, 2003 at 09:27
But Victatwo, what did it weigh, and how much extra
fuel did it cost to take it every where? I guess there is no such thing as a free lunch. The compressor costs more up front but weighs a lot less. The N2 is faster so saves you time which has a price. The cylinder takes up space etc etc
7761
Reply By: rum pig - Saturday, Feb 15, 2003 at 16:53
thanks for the help. very interesting about bob who you just never know what you are getting
13201
Reply By: Suzuki Viagra - Monday, Feb 17, 2003 at 16:21
Why would any of us pay for nitrogen unless we carry some CIG canisters - or whatever the equivalent is these days.....
Unlike almost all other tyre users 4wd'ers are required to fiddle with pressures regularly.
No question - pure Nitrogen is inert and more stable and both Gp and aircraft companies don't do it for bragging rights (which some of us in this
forum do though) - but I don't think Bob Jane will be there to reinflate our tyres with Nitrogen between Suicide Pass and Madness Mountain.......
13318
