TD42 Oil Filters
Submitted: Monday, Jun 26, 2006 at 10:31
ThreadID: 35279 Views:2921 Replies:6 FollowUps:2
When I change my oil filters I have noticed that the back oil filter doesn't have as much oil in it as the front oil filter. Does anyone know if this is normal??
Demack
Reply By: chips - Monday, Jun 26, 2006 at 11:55
Hi Demack.
I too do my own oil changes on a 1999 Patrol with TD42, I use Z9s and havnt noted and huge difference in amount of oil in them, even the extra time it takes to remove rear filter may make some difference to the amount that drains out,food for thought.
Sorry I cant give you a tec. answer
Chips
AnswerID: 180384
Reply By: Member - Roachie (SA) - Monday, Jun 26, 2006 at 12:10
Does your Patrol have 2 filters the same OR does it have a "by-pass" filter at the front and a standard filter at the back?
If so, that could explain it. The by-pass filter has different internals and tends to retain more oil than the rear filter which is a more 'normal' type and probably allows the oil to flow back out more readily.
Roachie
AnswerID: 180387
Follow Up By: Demack - Monday, Jun 26, 2006 at 12:29
It has 2 filters the same, I use Ryco Z115.
Demack
FollowupID: 436642
Reply By: chips - Monday, Jun 26, 2006 at 12:53
Hi Demack
My brother has a 1991 td42d as do I as I said in previous reply I as well as my Brother use Z9s. both Patrols have done well over 200.000ks without any probs using the cheaper filters, as my brother impressed on me the most important thing is to do your oil changes at very regular intervials about every 5/6000ks and you shouldnt have any probs, the saving on the filters nearly pays for 1/2 the cost of the oil.
AnswerID: 180400
Follow Up By: Demack - Monday, Jun 26, 2006 at 13:06
Thanks for the tip.
FollowupID: 436648
Reply By: chips - Monday, Jun 26, 2006 at 13:09
No worries mate.
where are you and what year Patrol do you have
AnswerID: 180406
Reply By: Member - Browny (VIC) - Monday, Jun 26, 2006 at 17:26
DMack,
Incredibly observant of you, have you emptied them into a measuring container or is it quite obviouse when removed? I used to allways spill way to much to have any reliable guage of how much oil is in wich filter!
Browny
AnswerID: 180447
Reply By: Alloy c/t - Monday, Jun 26, 2006 at 17:41
A mate of mine usualy does his oil and filter changes at my place [Ihave toyota so no dual filters] , his is a 92 model ,,cant say that ever paid any attention to quantity of oil in either filters but come to think of it would not the 1st filter be getting the larger paticles and therfore clogging 1st so less "room " for oil ??
AnswerID: 180450
