Waeco use on 240V at home.
Submitted: Monday, Jun 26, 2006 at 12:47
ThreadID: 35285 Views:3491 Replies:3 FollowUps:2
When not travelling, I would like to use my 25 litre Waeco as a small freezer at home.
Could this constant use on 240V be detrimental to the fridge or Mobotronic transformer.
Thanks,
Dave
Reply By: ro-dah-o (WA) - Monday, Jun 26, 2006 at 13:02
shouldnt be. I run mine 24/7 at home when not away. great for storing drinks and the such. I have noticed thast the mobitronics runs warm, but havent had it fail. Make sure you check every now and then that th efridge is still running, as i had the fuse i my mobitronic blow due to a powersurge. thanfully I didnt have anything in the fridge at the time.
From my understanding (and im sure someone will be able to clarify) that as it is a compresor driven fridge, similair to a household fridge, it is better if they are run all the time to keep them cycling. I dont know the science behind it, just what Ive been told and some common sense. Its similair to a house fridge, store it away and dont run it, risks not working the same again.
my two bob
AnswerID: 180403
Reply By: Wizard1 - Monday, Jun 26, 2006 at 13:17
I guess you need to look at the economics of what you plan. At nearly $700 for a CF25 you could buy a freezer for much, much less. At $ 139 for the MPS 50 it could become a very expensive exercise to replace one or even more. I've had a MPS 50 go south at the worst time (dropped to output of only 6volts) and you can't just duck down to the Harvey Norman and get another one.
To be honest it would be much more economical to get a second hand freezer for even a third or half the price of the Waeco.
AnswerID: 180408
Follow Up By: hl - Monday, Jun 26, 2006 at 13:48
and spend a couple of hundred buckos a year running it!!!!
The Waeco is VERY cheap to run on mains (or battery), much much cheaper than a mains powered one, especially any older types.
FollowupID: 436653
Follow Up By: TerraFirma - Monday, Jun 26, 2006 at 14:03
That is a fair call. You wouldn't want the beautiful Waeco to die when you could always sacrifice a $100 bar fridge or something like that. I'm not sure how long the Waeco's are designed to run for, indefinetely or 5-10 years, but if you don't have another fridge I don't see the issue.
FollowupID: 436655
Reply By: Member - andrew B (Kununurra) - Monday, Jun 26, 2006 at 22:12
Have considered doing the same, Possibly even getting a solar panel/battery setup sorted, runs for free, keeps the deep cycle battery charged??? I think the fridges like a regular run, and batteries don't really like slowly going flat...
Cheers Andrew
AnswerID: 180505
