Friday, Feb 28, 2003 at 12:38
This from a guy who did his Toyota fan- probably identical I guess
"Separate the two half's and be careful not to damage the O-ring. The O-ring always seems to get stretched out.
The manual says to use 50mL of 3000Cst. silicone fluid to refill the fan clutch. Each bottle is 18mL. Toyota P/N 08816-03001
After cleaning out all of the old silicone from the fan clutch half's, add about 50mL of silicone to the lower half of the clutch. This should be just enough to fill the holes and not
overflow into the O-ring groove.
The fan clutch is full of silicone and the O-ring is in the back half of the groove. Note how the O-ring has stretched. Some people cut out a small section of the O-ring and super glue it back together, but I didn't do that......
I placed the top of the clutch on the back of the O-ring and used a small flat blade screwdriver to push the O-ring back into it's groove. You must apply some pressure on the top piece to prevent the O-ring from popping out of the groove.
Reinstall the outer philips screws to secure the cover, install the fan, and you are all done."
There were a few fotos attached but they don't really tell you much..
8439
