HOW LONG DO RUBBER DOOR SEALS REMAIN EFFECTIVE ?
Submitted: Saturday, Jul 15, 2006 at 13:45
ThreadID: 35852 Views:4317 Replies:12 FollowUps:14
Howdy Formorites ,
On my last trip I got a heap of dust through my car . This had never happened before and I was wondering - do the seals become stiffer , become compressed , or perish ?
The car is a 2001 TD Cruiser . After it started to let dust in , I inspected and cleaned all the rubber seals , but I could find no obvious problem and it did not solve the problem .
Thanks ,
Willie .
Reply By: DP - Saturday, Jul 15, 2006 at 14:15
Wille,
your door seals should remain effective for at least 5 years after manufacture.
The extrusion materials are designed to withstand compression, however not all prodcution processes run to plan 100% of the time. If however the rubber was not completely cured then some 'set' may have occured.
Bear in mind also, that dust will find it's way through the tiniest of spaces, so it may not be your seals at fault.
Dan
AnswerID: 183614
Follow Up By: Member - Willie , Epping .Syd. - Saturday, Jul 15, 2006 at 16:47
Dan ,
It is the seals around the rear bottom door . I can see the dust in that area .
Willie
FollowupID: 440264
Reply By: cokeaddict - Saturday, Jul 15, 2006 at 14:16
Willie,
Over time all door seals become less effective, that is they start to loose thier "bound" for a better word. They dont push up against the panels as good as they would when new. That is a common problem with rubbers. But in saying that, Unless you actually saw traces of dust entering the vehicle from the rubbers, then its more likely the dust came in via vents. So before you go trying to replace the rubber seals, Id take a closer look at your vents mate. That fine dust can float around for ages before it settles down. I know the GQ's have this problem with the rear quarter panel vents behind the windows, they are usually taped up before a dusty trip is started, it helps eliminate entry problems.
If your door rubbers are in tact with no chunks missing, i wouldnt touch them at all.
Id be looking at floor clips missing or cracked and thinsg like that.
Hope that helps
Ange
AnswerID: 183615
Follow Up By: Member - Willie , Epping .Syd. - Saturday, Jul 15, 2006 at 16:45
Ange ,
I could see the general area which was the problem - around the bottom rear door seals . I cleaned and inspected these , but could not stop the dust .
It is not coming in the vents .
I agree , the rubbers would harden up and lose their ability to seal to some extent after 5 years .
Willie
FollowupID: 440263
Reply By: WDR - Saturday, Jul 15, 2006 at 16:54
Try a Jackaroo - Sometimes I wonder if I am inside or outside.
Only suggestion from Isuzu - Close windows and run fan on high - Switch it to circulate if someone passes you.
It works actually - Bit of a nuisance if you are an open window driver though.
AnswerID: 183631
Follow Up By: Member - Willie , Epping .Syd. - Saturday, Jul 15, 2006 at 19:02
No , you and Leigh are approaching it from the wrong direction . My car , for the first 95,000 klm was dustproof .I need to fix a problem that has developed , not resort to pressurising the cabin .
Thanks ,
willie .
FollowupID: 440288
Reply By: Member - Leigh (Vic) - Saturday, Jul 15, 2006 at 18:34
Age old problem this one!! Try shutting all your windows, turn on the fan to 1 or 2 and open the fresh air vent. This will pressurise your vehicle and keep the dust out. Make sure you close the vent if you are in a dust trail or on coming vehicle approaches. Leave the seals alone, nothing wrong with them!!
AnswerID: 183647
Reply By: The Rambler( W.A.) - Saturday, Jul 15, 2006 at 19:25
Willie.
This is just a suggestion---since the problem seems to be coming from the rear door I would check to see if the rubber gromet stops at the bottom of the door are missing as if so this allows free play in the door that will let in dust.Hope this helps.
AnswerID: 183655
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:15
Good idea ,
Did not know there was any - I will check .
Thanks ,
Willie .
FollowupID: 440361
Reply By: Ian from Thermoguard Instruments - Saturday, Jul 15, 2006 at 19:26
Hi Willie,
Had any panel repairs or similar on the rear of your vehicle recently (not necessarily the rear doors)?
Our '97 Discovery had always been admirably dust-tight over many thousands of corrugated gravel roads/tracks. About 2 years ago, my beloved backed it into a tree (It just jumped out!!). After 3 return visits to the insurer's "approved" repairer to get a half-decent job, the rear door was still out of alignment and now leaked dust if you pulled over onto an unsealed road shoulder.
A reputable repairer (The Bumpshop, Eagle Farm, Brisbane - excellent work) told me how to 're-align' my rear door for nothing. It now seals perfectly again (have done a more-than 1000 kms of dirt trip in NW Qld/eastern NT since). That's with the original seals, 10 years (1996 UK build date) and 215,000km.
Have a close look to see if the seals are actually in contact with opposing surface. You might be able to do this by: clean both surfaces, smear vaseline along the seals, close the doors gently and re-open, look for vaseline on the opposing surfaces. They might have gone out of alignment/firm contact due to panel movement (a light shunt?) or just 'fair wear and tear' to the latch mechanism, etc.
Let us know what you find.
Ian P.
AnswerID: 183656
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:19
Ian ,
There could be an alignment problem as you suggest , although I have had no accidents . I will check . Maybe it is not the seals after all .
Thanks a lot ,
Willie .
FollowupID: 440362
Reply By: Max - Sydney - Saturday, Jul 15, 2006 at 20:48
Willie
My 80 s has done 250,000 km with no loss of dust sealing, and plenty of harsh country. You are right to look for what has changed, rather than scrub around it by pressurising the cabin.
I guess you have looked for anything come loose (hinges, locks, rubber stops, plugs etc etc) and looked along to make sure the door is still straight (it gets some weight when loading fridges etc).
Failing that, is there something loose that's holding open the rubber somewhere along it?
It does not look like a very difficult job to replace the whole seal once you are convinced that its just the rubber lost its "bound". I'd pay the price for genuine Toyota rubber.
Good hunting
Max
AnswerID: 183671
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:38
I have checked out the rubbers carefully , but as you and Ian P suggested , the door may have somehow got out of alignment . ( could not be my slim little bod sitting on it having lunch )
I will check that out and also ask Traction 4 (ARB ) to have a look .
Thanks Max ,
Willie .
FollowupID: 440368
Reply By: Exploder - Saturday, Jul 15, 2006 at 21:51
Do all the doors get regularly open and shut or just some of them, If the doors are not open and closed every now and agene then the rubber will become compressed and loose it’s sealing ability.
This is why when you store a car for a period of time you don’t full close all the doors.
Cheers.
AnswerID: 183683
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:44
X Ploder ,
That makes good sense , but would be a problem if you needed to put the alarm on .
Thanks ,
Willie .
FollowupID: 440371
Reply By: brd - Saturday, Jul 15, 2006 at 21:58
G'day Willie
If the seals have compacted on you, one fix could be to cut a small hole in the end of the seal, and feed a suitable length of plastic tubing inside the length of the seal. This will hold the seal profile firm, and counter the compaction it has suffered. Silastic up the hole you made with black silastic to restore the integrity of the seal again. Just figure out what size tubing you need and where to place it, but that will solve your problem if I understand it correctly.
Brid (Cost Effective Maintenance)
AnswerID: 183685
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:40
Brid ,
If they are buggered , I think I will replace them with Toyota ones . If I have a go using your cunning method and go on a trip and find out I messed it up , it would be a dust clogged disaster .
Thanks ,
Willie .
FollowupID: 440370
Reply By: Member - Phil G (SA) - Sunday, Jul 16, 2006 at 00:11
Hi Willie,
Plenty of good anwsers above.
So my suggestion is to get a vehicle with no back door.
No back door = No dust
Works great with mine!!!!hehe
phil
AnswerID: 183699
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:23
Sounds like a cheap fix Phil , thanks .
By the way , the other day I was told that you could special order a Troopie with turbo diesel and auto .
Was that true ?
Cheers ,
Willie .
FollowupID: 440364
Follow Up By: Member - Phil G (SA) - Sunday, Jul 16, 2006 at 12:39
Never heard of an auto Troopie, and very much doubt that it would be possible. I gather an aftermarket conversion is pretty difficult too - maybe something to do with the size of the transmission tunnel.
FollowupID: 440378
Follow Up By: G.T. - Monday, Jul 17, 2006 at 16:13
Phil -- No back door = no dust. I suppose you could take the back door off to achieve this? couldn`t you?? Regards G.T.
FollowupID: 440557
Follow Up By: Member - Phil G (SA) - Monday, Jul 17, 2006 at 17:42
GT, I like the way you think :-))
FollowupID: 440570
Follow Up By: Member - Willie , Epping .Syd. - Monday, Jul 17, 2006 at 18:04
Very lateral GT .
FollowupID: 440573
Reply By: Peter & Maureen Cathie - Sunday, Jul 16, 2006 at 12:41
hey Willie we have FJ 73-mrq with two back doors we have had it since new and had the same problem that you have. I found that over time 20 years now that the Back doors do sag under the weight either being used as a table or chair for horizontal opening doors or the weight of the spare and other fittings on vertical opening doors. They all need adjustments over time and travel including all passenger and drivers doors. I dont care what any body else says but that is a fact of off road driving it does put a greater strain on all aspects of the vehicle and one of the main ares that people do tend to forget about.
What you really need to do is check to see if you also have water ingress into your vehicle. Check each time you do a water crossing.(dust and water = crust at the leaking area note not loose dust but dried mud) If no crust then the dust problem is not comming from your seals but as the others have said from your vents. If there is a crust buildup then that is the spot were the dust is entering your vehicle. Another thought is that at some time before you or somebody else may have tried to close your tailgate or door with some thing jammed. This can pinch the seal and could also just slightly dented the body work. This can happen and at the time you didnt think any thing of it .or havnt been told that it has happened ( all the joys of group travelling or family members.)It could have been as little as a piece of rope or a tool of some sort but in the twenty years or so that I have had my land cruiser the seals have leaked everytime I have done this even to the point out on one trip we did the drivers door never leaked until one time I slammed the drivers door and the seatbelt buckle got jammed between the door and door frame Thats right it leaked on the very next crossing and you could see the dust entering through the spot so it does happen
*Shrugs shoulders just a thought cheers happy trails
AnswerID: 183752
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 15:27
Thanks guys ,
I checked and thoroughly cleaned the seals at Durba Springs during our big rest stop . There was a lot of dried mud etc built up BEHIND the seals to cause high spots - the clean helped but did not completely stop the problem . There did not appear to be any damage , but that is not conclusive .
As you and others have said , there is a good chance that the bottom door that I always sit on , has gone out of alignment .
One thing I know is , I must fix the problem before my next trip as it just ruins the driving experience .
Cheers ,
Willie .
FollowupID: 440397
Reply By: Alan W - Tuesday, Jul 18, 2006 at 09:07
Hi Willie,
May I suggest the following.
You have checked the seals themselves, make sure you also check where the seals seal against. Look for build up of mud/dirt chewing gum etc.
Open tail gate fully and try to push/pull tail gates horizontally, this checks for excessive movement by the way of worn hinges.
Close bottom tailgate alone and grasp top edge. Push/pull, check for excessive movement, this checks locking mechanism for looseness and or wear. If can, repeat for top tailgate.
Close both tailgates securely. Run finger along joins between tailgates and body and especially between top and bottom gates. All joins should feel uniform in width. Be especially vigilant between the two gates as you may have "bowed" the lower gate by excessive weight.
Also by the way of maintenance, use armourall or wd 40 etc on the door seals to keep them moist and supple.
As a example, after you armourall your interior such as dashboard, windowsills etc, use the same armourall inpregnated rag to go over all door seals and their sealing edges.
Hope Iam of help.
AnswerID: 184043
