Different type oils and fuel consumption
Submitted: Saturday, Aug 26, 2006 at 14:18
phil
Does anyone have any experience with the improvement, if any, in
fuel consumption when changing from mineral grade 15W-40 oil to 10W-40 semi synthetic or to 5W-40 fully synthetic. I am talking about turbo diesel motors in particular.
Phil I
Reply By: Member - Stephen (WA) - Saturday, Aug 26, 2006 at 15:09
I've done a similar thing to you - moving to the 10W 40 oil. I did it for the easier starting on cold mornings.
I haven't noticed any change in
fuel economy by doing this. I guess it's probably because the hot viscosity (40) is the same for all these oils.
Stephen J.
191125
Reply By: Mark R - Saturday, Aug 26, 2006 at 17:33
Hi Phil,
Unable to answer your question but you may be interested in my experience. 100 series TD 5 speed. On the same day I fitted a full length roof rack and started using Castrol Magnatec instead of the oil being used by Tojo dealer (dunno what it was). No other changes. Previously I had been getting a very consistent 10K per litre. Expected from the experience of others to drop about a kilometer per litre because of roof rack. In fact there was absolutely no change in
fuel consumption to my astonishment. This was tested repeatedly over several tanks full so not a flukey result. This must be because of no influence from roof rack on consumption OR alternatively the change to Magnatec was worth a K per litre. I feel it is the latter and I am impressed. I am not going to stop using the Magnatec or remove the roof rack to sort it out more scientifically! Very happy with Magnatec. No conflict of interest etc.
Regards,
Mark
191143
Reply By: madfisher - Saturday, Aug 26, 2006 at 20:17
Hi Phil, I have been told by truckies that if they run full synthetic in the driveline all things being equel its worth 4% in improved
fuel Ecomony. B ecause of the advanced technology in magatec i would believe the improvement. Wished my mechanic stocked it. Cheers Pete
191175
Reply By: 120scruiser (NSW) - Saturday, Aug 26, 2006 at 20:18
Hi Phil
I have a story for you. One of my customers came back to me after a service of his Nissan Pulsar and asked "what we did to his car?"
I was concerned and questioned him and he said he was getting an extra 50 km to a
tank of
fuel.
My employees brother is fanatical about his car and after we serviced it he claimed he was getting better
fuel economy.
We never said anything to them just did our normal service.
We used a 10w/30 mineral oil in both vehicles. Both were Nissan Pulsars around the 1996 range.
We were previously using a 15w/40 oil in them.
120scruiser
191176
Follow Up By: Member - Phil G (SA) - Sunday, Aug 27, 2006 at 00:01
My daughters have N15 Nissan Pulsars - we've used the 7.5W30 Nissan special blend oil in them since new - about $25 per 5 litres, so no issues with the price. They run like clockwork, and we've got up to 770km from 44 litres.
448922
Reply By: Member - Oldplodder (QLD) - Saturday, Aug 26, 2006 at 21:48
I always remember what a friend told me who raced in formula ford.
Those cars are so evenly matched, any little advantage counts.
Friend changed from the standard 30 grade racing oil used by every one else to a special light grade oil of about 10w.
Reckon it was worth about an extra 300 rpm on the straight, enough to make a difference. Always reckoned it took about 4 hp to turn the oil pump.
He used to rebuild the engine every 2nd race, so he checked every out anyway.
191195
Reply By: bigcol - Sunday, Aug 27, 2006 at 02:43
We ran a 1969 XWGT up on a dyno one day using new Valvoline XLD and then did an oil change with Castrol GP50 an oil specialy formulated for big
bore V8's and picked up around 10 HP more.
191215
Reply By: Brid from Cost Effective Maintenance - Sunday, Aug 27, 2006 at 07:29
Oil manufacturers do claim small
fuel efficiency improvements with synthetic oils, as they have done with locomotives going to multigrade 15W40 from SAE40.
I think viscosity selection is one of the most important characteristics of an oil, and believe there is a fine balancing act between efficiency with a light viscosity oil and engine protection. High loads and high ambient temperatures are more demanding on oil, so you need a higher viscosity. The synthetics seem to provide this...but I have noticed that valve tapper noise is less apparent when running a slightly higher viscosity than recommended.
Modern engines run finer clearances between ring and liner, but I suspect that if valve noise is more apparent, there will be more wear in this area, so I will sacrifice the small
fuel efficiency benefit in favour of peace of mind...especially with QLD mid 40s during summer.
Brid
191221
Reply By: phil - Sunday, Aug 27, 2006 at 14:02
Thanks everyone. It seems that it is worth trying. Even a small improvement in
fuel economy will pay the difference in oil cost.
Phil I
191267
