gas shower
Submitted: Saturday, Mar 08, 2003 at 21:23
1/2slab
Has anyone seen or had an idea of a
water heater/heat exchanger that
you can just throw on a single burner? Maybe a copper coil etc.
Reply By: Michael - Saturday, Mar 08, 2003 at 21:37
I did some research a while back on this type of
water heater. I found one in a
Camping World catalogue, when I tried to purchase it they claimed that it did not pass Australian safety standards so was never actually stocked. It was the exact same unit that is available from this site
http://www.zodi.com/ I contacted Zodi but they don't have an Australian distributor but they do sell direct over the web.
14684
Reply By: 1/2slab - Saturday, Mar 08, 2003 at 21:44
Thanks michael, I will have a look at that web site, but was more interested in some home made ideas.(rough enough is good enough!)
14685
Follow Up By: Truckster - Saturday, Mar 08, 2003 at 22:14
then why not one of them $30 el cheapo ones from Super cheap, plastic things, not sure how they work, probably from a bucket of hot
water...
8880
Follow Up By: Member - Nigel - Saturday, Mar 08, 2003 at 22:25
Trucker, those $30 plastic thingies don't heat
water :)
8881
Reply By: David . - Saturday, Mar 08, 2003 at 22:31
1/2 slab, there use to be a company in
Townsville that manufactured a similar system called the ' SCUD ', it's an aluminium coil that is housed in an round aluminium case & placed over the gas burner, i saw it at the
Brisbane caravan &
camping show a couple of years ago, so i am not sure if it is still around, you could try ringing a couple of
camping stores in
Townsville, they may know, regards, Dave.
14689
Follow Up By: Member - Nigel - Sunday, Mar 09, 2003 at 23:14
It was from
Cairns actually. Geo Pickers
Camping & Canvas (also in
Cairns) stock them.
8921
Reply By: ROX - Sunday, Mar 09, 2003 at 04:06
Campertrailers Wa have a unit $295 blue in colour that heats by gas & 12 volt no affiliation with the company.
14705
Reply By: Tony Cox - Sunday, Mar 09, 2003 at 10:00
These units are dangerous
if the
water boils there is a real risk of scalding or steam forced thru the shower.
if you are going to use a gas ring warm your
water in a drum and buy the cheap shower pump
helton now stock these units and they are dam good
water at 9 ft head
helton .com.au
14709
Follow Up By: Tony Cox - Sunday, Mar 09, 2003 at 10:07
These comments are with reference to a copper pipe on a gas burner not to a proper gas
water heater
Tony
8893
Reply By: oziemale - Sunday, Mar 09, 2003 at 11:39
I built a shower heater for around $150. Consists of a 20litre
tank with a coil of copper tube inside.
Tank is fitted under vehicle & the tubing runs along the chassis rail & joins into the heater system on the engine.
Another heater tap is used which is turned on while driving half an hour before stopping to
camp.This was suitable for 4 people to have a nice shower up to an hour after stopping. Dont need engine running. Dont rely on sunshine & dont have to light a fire. I can supply more info if you are interested. Just email me ok. Lee.
14715
Reply By: diamond - Sunday, Mar 09, 2003 at 12:43
perfect shower is cheap and easy to make
$99 heat exchanger from helton
$30 shower unit from supercheap autos
$4 for extra hose from repco
$7 for 20ltr plastic
water container from supercheap autos
we have never had better showers out in the bush
14720
Reply By: rodeoowner - Sunday, Mar 09, 2003 at 14:28
Use 3/8 copper tube. Coil it, starting with the smallest possible diameter. It can sit on a cast iron gas ring. Use one of those cheap shower kits from Super cheap. The hose pushes directly onto the 3/8 copper. You will probably have to cycle the
water using a large (20 litre) bucket/container to get it to a reasonable temperature. This however can be dangerous as you can't regulate the
water temperature. Also you will need to fix the copper coil to the burner somehow.
14724
Reply By: Ray - Sunday, Mar 09, 2003 at 16:16
whats wrong with a cold
water shower. Toughen up guys!
14728
Follow Up By: diamond - Sunday, Mar 09, 2003 at 16:58
cold showers ill end up with a hole in my belly lol
8910
Reply By: 1/2slab - Sunday, Mar 09, 2003 at 20:27
Thanks guys, those helton products seem pretty damn good for the
price. At under $100 bucks its not worth the stuffin' about with dangerous home-made ideas.
14739
Reply By: Peter - Monday, Mar 10, 2003 at 11:33
I am setting up a shower to go on a ring burner I have cut an air cond condenser out of a hz holden in half (length wise) and soldered up the end with one of the fittings of the othe half)with your normal 12v shower kit it heats up almost instantly and not to hot (two different temps depending on witch way up you put it on the flame.
I am now in the prosses of fitting a 12v gas cut off from a gas conversion car wired to the gas and pump so you have to have the pump running to have the gas on and when you switch off the pump the gas automaticaly switches off .
Hope this helps.
14758
