faulty jayco gas regulators
Submitted: Wednesday, Sep 13, 2006 at 14:03
ThreadID: 37688 Views:8642 Replies:8 FollowUps:8
Hi everyone has anyone other than everyone I know had a problem with the gas regulator
Fitted on all jayco’s I know of 3 owners and my self that has replaced the regulators at lest once one guy has replaced it twice and all the vans are only 1 year old jayco just say there no good but keep selling them and there on all there new vans and they do not cover under warranty. Can any one tell me what we can do as when your away and they stuff up food goes off in the fridge and they make you buy anther one
Reply By: kimprado - Wednesday, Sep 13, 2006 at 15:01
Yes, this also happened to me (my camper trailer is 10 months old). I took it back to Jayco and was informed it came from a faulty batch. They gave me a new one on the spot.
We'll see how the new one go's. If it happens again I'll request a recall.
Kim
AnswerID: 194347
Follow Up By: Gdad - Wednesday, Sep 13, 2006 at 15:13
Hi kim
we where told that the comany thay get the regs from owe jayco $15000 from faulty returns the bad ones were made in texas and the good ones from mexeco
but i now of both stufing up but good luck
FollowupID: 452254
Follow Up By: LastAussieWorker - Thursday, Sep 14, 2006 at 00:08
the problem has nothing to do with the regulators at all or Jayco. Is a problem caused by plastic hose.
FollowupID: 452423
Follow Up By: Gdad - Thursday, Sep 14, 2006 at 15:21
ok lets say it is the hose then why is jayco still selling all there vans with the hose and not the copper pigtails to fix the problem and why are thay stateing that the company that supply the regs owe jayco $15000 in falty reterns if was just the hose dont you think thay would work that out and not try to reclaim money from the reg supplyer
FollowupID: 452520
Reply By: cackles - Wednesday, Sep 13, 2006 at 15:08
Camping last week a Jayco owner came over to see if we had a spare he could borrow, poor guy had to drive an hour to town to replace it.
Worst thing was he missed catching the tide and catching lunch!
Cackles
AnswerID: 194348
Reply By: Member - eerfree(QLD) - Wednesday, Sep 13, 2006 at 17:44
I am not sure if it is only Jayco that has this problem there has been a lot posted on other forums about faulty regulators, it seems one of the problems stems from the reg. being lower than the top of the bottle - raising the reg., I am told helps solve that part of it.
eerfree
AnswerID: 194381
Follow Up By: Gdad - Wednesday, Sep 13, 2006 at 17:58
it is the reg as i have cut open a few and there is a rubber seal in the smaller side on a rocker arm the rubber seems to go soft and puff up bocking the gas flow and that was on the texas and mexeco type
FollowupID: 452308
Reply By: Shaker - Wednesday, Sep 13, 2006 at 17:47
There was a national recall advertised in most newspapers.
AnswerID: 194382
Follow Up By: Gdad - Wednesday, Sep 13, 2006 at 17:59
yer i know but the replacment regs are just as bad
FollowupID: 452309
Reply By: markcas - Wednesday, Sep 13, 2006 at 18:07
We have come across this as well.I understand this is not just a Jayco problem and other van and camper builders are in the same boat.But when you have paid $30000.00 for a van they built with materials they sourced for the best price i think it should be replaced or fitted with another product and recall go out.A friend with a 3mth old van was told by Brisbane Camper that they wont replace it .Isn't that is what the warranty is for???.Jayco Gold Coast told me that Jayco would replace the unit only once.Looks like we all should get a spare fitted when they build the van.
AnswerID: 194388
Follow Up By: Member - John R (NSW) - Thursday, Sep 14, 2006 at 08:38
Mark, I would have thought that a warranty covered the whole unit and its fittings? I'm on my first camper, and I just insist on any warrantable items being rectified. Fortunately, I had a good relationship with the dealer and got everything (even the smallest item) fixed under warranty (not that there was much to be done).
The usual excuse is "XXXXXX (insert manufacturer name here) won't cover that". My answer is "Not my problem" (diplomatically, of course).
They know that's a line to throw you off the scent, but if you stick to your guns you should get satisfactory results. Plus they know once you're hooked on the lifestyle you'll probably change vans a few times over the years. If they want the repeat business they'll take care of you.
**** Takes off rose-coloured glasses **** :-)
FollowupID: 452445
Reply By: roosey - Wednesday, Sep 13, 2006 at 19:01
Hi Guys,
Let me tell you Jayco are not the only caravan manufacturer who ducks and dives so as to avoid warranty. Seems to me that unless you have a massive problem it is cheaper to DIY, & isn't that just what they want.
But what to do?
AnswerID: 194397
Reply By: nonon - Wednesday, Sep 13, 2006 at 19:49
Yes it is far cheaper [in the long run] to just go and buy a new one and fit it yourself. Don't even bother driving to the caravan yard. While your at it, get yourself a new trailer plug, a steel one, not the cheap plastic one that Jayco use.
There is nothing worse than faulty lights and indicators on a wet day when your already a few hours behind and you can't figure out why the indicators are stuffed.
A common problem with Jayco vans/campers
AnswerID: 194408
Follow Up By: Doggy Tease - Wednesday, Sep 13, 2006 at 21:21
Dmanit Muzz,,,ya beat me to that one.
meow.
rick.
FollowupID: 452377
Reply By: LastAussieWorker - Thursday, Sep 14, 2006 at 00:14
Problem is an issue of the gas hose and not the regulator or caravan manufacturer
The caravans with copper pig tails have no problems with the same regulator
To fix the problem you need to have the regulator mounted above the level of the tap of the gas bottle. That will stop it from causing a problem. The damage may already be done to your regulator and replacing prior to remounting higher is recomended. If you unscrew the hose from the regulator and there is oily stuff in any quantity the reg will be on its way to heaven.
AnswerID: 194455
Follow Up By: Member -Dodger - Thursday, Sep 14, 2006 at 17:29
Yep this is the way to go.
Many have had a prob with the regulator and the simple fix is a new one placed higher than the bottles.
Seems like there is some goo in the gas that wrecks the reg.
Cheers Dodg.
FollowupID: 452546
