Nissan RB30 stalling.
Submitted: Thursday, Aug 23, 2001 at 00:00
John Wood
Hi all! Having read Dean's question about his Disco stalling I need help with a similar problem with my 1992 3.0 litre petrol GQ Patrol.
For the last 4 months I have had many occasions where the engine starts to slow down to the point that it is doing about 10k/hr flat out. (No wisecracks please!) On stopping and with the clutch disengaged the vehicle will rev to about 2000 revs or so, full acceleration. If you turn the engine off, wait for a short while then restart generally it will come good, but not every time. The loss of power can occur while you are driving, continue for a few kms then come good while you continue to drive. It feels like loss of
fuel flow but when this problem is happening the sight glass in the side of the carby's float chamber is full. To date I have replaced the
fuel pump,
tank filter and the in line
fuel filter. The carby has been removed, checked and cleaned. Nothing was found inside the carby that may have been causing a blockage.
Fuel pressure was measured as OK (but I have not done a
fuel pressure check when the problem is evident as this would require me to fit a
fuel guage in an accessable location and drive around for a week or two like this). I have run the vehicle with the
fuel filler cap loose in case there was a vacuum problem stopping
fuel flow. No luck! The problem may disappear for a week or two then happen 2 days in a row. It is intermittent. Nissan, Muller & Jacka, my 4x4 mechanic, Nissan dealers, auto electricians and a myriad of others cannot help. Can you?
Reply By: JohnF - Monday, Sep 10, 2001 at 00:00
Have you looked at the possibility that the
fuel line might run too close to the engine case, and when travelling low gear and/or range, the
fuel in the line vaporises, causing the carby to starve for
fuel. I know this happens with Disco's as I've seen it happen on previous 4WD trips. The problem cleared when engine cooled, and
fuel line next to engine case wrapped with insulating material.
1052
Follow Up By: John Wood - Tuesday, Sep 11, 2001 at 00:00
Thanks for your reply John.
Yes this has been one of the considerations. This problem did not occur in the heat of a November Simpsons crossing but has occured at
Mansfield at 5°C when the engine hadn't even got to operating temperature. Normally when the
fuel vapourises the engine runs rough and can stall. My beast doesn't run rough and will actually come good if you keep going.
Thanks again John.
300
