Does Salt Extend Block Ice Life?????
Submitted: Friday, Mar 14, 2003 at 20:53
Jack
Hi all ....
Dumb question number 99. A guy came over to my camspite recently to check out the performance of my ice box, and he suggested that I should spread salt over the ice and wrap it in newspaper to extend the life of the (block) ice.
Is this correct? I had always thought that salt caused the ice to melt more quickly, which is why they used it in those
places were streets were covered in snow/ice etc.
Many thanks in advance .. and no, I am not blonde.
Jack
Reply By: Bruce from Budget Signs - Friday, Mar 14, 2003 at 21:14
jack
i would think that the paper its self would act as an insulator & slow the process of melting down as to the salt im not sure other than that salt will not freeze & is actualy exclued in the freezing process if my chemistry lessons serve my memory right, which is why all the ice at the poles is made up of fresh
water, try sprinkiling salt on an ice block & place one unsalted next to it be interesting to see which melts first
Regards BruceBudget Signs
15216
Follow Up By: Member - Rohan K - Friday, Mar 14, 2003 at 21:33
I thought it was the other way around. They use salt to help melt ice, not stop it melting.Be good, or be quick.
Rohan
9254
Reply By: GaryInOz - Friday, Mar 14, 2003 at 21:22
A salt
water ice block will freeze at a lower temperature depending on how much salt you add. The downside is it becomes liquid at a lower temperature as
well and may "salt" the surrounding food.
15218
Reply By: Eric - Friday, Mar 14, 2003 at 22:15
Jack.
THe bloke with the salt story, was he driving a triton and did he have a eperb straped to his belt? Eric.
15224
Follow Up By: Jack - Friday, Mar 14, 2003 at 22:36
Hi Eric.
Yes ... and I think he was attracted to me wearing a huge sticker across my forehead which read "sucker" ..
But thanks for the replies .. I think I will just stick to straight ice.
Jack
9257
Follow Up By: ThePublican - Saturday, Mar 15, 2003 at 13:44
Ozi rides again.
9286
Reply By: Hardy - Saturday, Mar 15, 2003 at 00:36
Adding salt lowers the chemical potential of
water giving a depresion of freezing point and elivation of boiling point. What that means is the ice will melt at a lower temperature, as such lowering the temperature of your eski. However you will use your ice up quicker maintaining this lower temp. So it doesn't really help your situation. Good for making an Ice/salt
water slurry to intantly cool your coldie. Can get apprx -10 degrees by adding salt.
15235
Follow Up By: Jack - Saturday, Mar 15, 2003 at 07:19
Hi Hardy:
OK, that explains it for me. Many thanks .....
Jack
9274
Reply By: Suzuki Viagra - Sunday, Mar 16, 2003 at 03:47
Hardy explained it
well - Ice (
water) freezes at 0 degrees- Salt
water at -18 Degrees. Putting Salt on ice melts it, but the conversion of ice to
water requires energy.
In your bath of Ice and
water, the energy to emlt the ice with salt on it comes from other water/ice and is absorbed as heat, cooling the nearby ice and
water. Hence you can us this to temporarily reduce the ice temperature further (down to the potential maximum -18) - great for quick freezing or at least cooling down your beer quicker.
If you need to keep stuff frozen but don't have a freezer (and have a heap of ice) then it's a good trick to know too.
The ice is cooler - must stay frozen longer huh? Uhuh - The downside is that the ice now will thaw at -18 not 0 degrees.....
Dammit! nothing in life is free.
Another thing worth considering is that that
water in the esky with your ice could save your life if you're broken down in the middle of no-where on a hot day. Drinking Salt
Water will kill you really quick.
15290
Reply By: Lloydy - Sunday, Mar 16, 2003 at 08:06
Suzuki Viagra
With that answer I think you seriously need to get out more :)
Jack
I have heard the same theory never really tested it. Hate ice so I am going to buy a fridge.
I would be interested as to why it would have been suggested to anyone in the first place, is there something we don't know?
Lloydy
Off to Accessorise some more
15293
Follow Up By: Jack - Sunday, Mar 16, 2003 at 08:24
Hi Lloydy:
I have an Engel fridge and an ice box (and even an Esky) ... and depends on what sort of trip I do as to what I take (or all three) ....
Fridge (and often ice box) goes with me for long trips, esp where there is a lot of driving (think battery charging). Ice box goes on shorter trips where the vehicle is stationary for long periods (eg fishing,
camping up to 4 or 5 days), Esky for a day/weekend trip, mainly due to size.
Ice question came when a guy was chatting to me recently on a fishing trip (an ice box trip) and suggested the use of salt and wrapping the block in newspaper. I was just curious and thought I'd ask.
My block ice usually lasts between 4 to 6 days in the cooler. I make ice on the road (in the fridge) on a long trip ... usually using a couple of bladders (wine cask type) filled with fresh
water, then transfer the frozen bladder from the fridge to the ice box .. result is cold water/cold ice box along the way. Works fine for me ....
Jack
9301
Reply By: Bob Y. - Sunday, Mar 16, 2003 at 09:40
jack, Back around 1970, was at
Kununurra races, and a keg was supplied at one of the camps, for consumption, for us
young blokes, and a few others. The temprite used must have been home made because it was set up in one of those frail foam eskis. However, the beer was cold, and the ice in the eski/temprite didn't thaw one bit, it was covered in a few mm's of salt. That lasted like that until after the keg was finished, I'm sure, because I was finished long before the keg was! Hooroo...
15301
Follow Up By: Jack - Sunday, Mar 16, 2003 at 11:15
HI Bob:
Yep that figures .. a friend of
mine (connected with the fishing industry) has contacted me privately as
well to let me know that the professional fishing boats use a salt/ice slurry to freeze pilchards which are then scooped out and pressed into blocks for use by recreational fisherpersons (politically correct term, I think ...) throughout Australia as a preferred bait for pelagic fish.
No, I don't know what "pelagic" means .. this was part of *his* reply ...
Thanks, I appreciated your input.
Jack
9303
Follow Up By: Bob Y. - Sunday, Mar 16, 2003 at 15:20
I didn't have a clue what it was either, Jack. Pocket Oxford says"of, on, in, the open sea." You learn something every day, eh. Hooroo...
9318
Reply By: relax - Tuesday, Mar 18, 2003 at 10:21
Fellows,
Pelagic in fishing terms mean fish that are not bottom feeders. Some of these fish include snapper, mackreal and tuna. As for the ice question. I do a lot of deep sea fishing here ( on great barrier reef) and we use salt a lot to bring the temperature of the fish down quickly and keep it in good condition. Yes, you do need a lot of ice, but for us getting the fish home and keeping it fresh for a few days is essential.
Hope I have enlightened you all.
15470
Follow Up By: Jack - Tuesday, Mar 18, 2003 at 10:40
Thanks relax:
You are definitely in God's country up there .. I worked in
Cairns for a few years and loved it. I sneak back every 12 months or so for a short stay.
Pelagic fish? Thank you .. I am now fully enlightened, and richer for the experience :) (Can't wait to roll that one out at the next party ....).
Take care, good fishing ....
Jack
9407
