Inverter Installation Trouble
Submitted: Wednesday, Dec 20, 2006 at 08:19
Member - Alex K (NSW)
Hi Guys,
Yesterday I began the simple procedure of installing the 500W PSW inverter into the LC80. Location of choice to be under the front passenger
seat.
Let's say simple procedure... not really!!
First problem, the cable that came with the JayCar kit was 4G and 1.5M long. Completely useless! It won't even reach the battery when the inverter is at on the ground.
So I walked into JayCar yesterday to express my dissatisfaction at this inadequate length and look at a longer cable but at $8 a metre I thought I'd confirm my measurements. I now know I need around 4.5m for each cable.
Second problem, the only hole available in the firewall (think that's what's it called) that would fit this over size cable (12mm thick) will only take one. Now i'm at that position of having to drill another 'large' hole.
Question: What have other people done here? Is there a thinner (less gauge) cable I should buy?
Thanks in advance...Alex
Reply By: Nick R - Wednesday, Dec 20, 2006 at 08:37
I managed to poke quite a few holes through when I had an 80, just through the rubber grommet, inverter, UHF, etc
NickR
211309
Reply By: Robin - Wednesday, Dec 20, 2006 at 08:38
Hi Alex
Stick with the 4G cable. My Jaycar Cat. lists it at $5.95/m retail
While its not the best practise, you do only technically need 1 wire
with the other going to a good body earth.
But I wouldn't suggest this unless you feel you can make a good
connection and test it.
Where I do this I use two wires to two seperate points. I.E. 2 X 8g
instead of 1 by 4G. (sometimes this can help get thru firewall to)
In my car, Nissan Patrol, body earths are used now and near the front
seat
where handbrake goes to floor are some really good bolts into bodywork
for doing this.
Robin Miller
211310
Follow Up By: Member - Alex K (NSW) - Wednesday, Dec 20, 2006 at 11:06
Robin,
I like your price but can't seem to find it. The web
Site Link
Says different...
471374
Follow Up By: Robin - Wednesday, Dec 20, 2006 at 11:40
Hi Alex
Yes note your link - I'm just looking at page 116 of current 2006 catalogue showing red WH 3070 at $5.95 and black WH 3066 same cost
Its a common size wire and I haven't checked around for prices but I would expect to pay less actually - maybe someone else will know?
Instant check Altronics have same thing $6 cat. W4200 red
So I guess thats about going retail price
Robin Miller
471387
Reply By: Willem - Wednesday, Dec 20, 2006 at 08:40
Hi Alex
12mm thick, Bloody hell. why?
Admittedly my inverter is only 150watt PSW. I have it installed on the dash, velcroed to the dash mat. It is covered by a colour coded towel to keep the heat of the sun off it :-D Towel is removed when inverter in use.
I extended the same size wires to the Pos and Negative of my aux Batt and the extra earth to the body.
Have had capacitor blow outs but that is because my laptop is too power hungry for the inverter(bad advice from jaycar salesman)
No other issues.
My thinking is that anything stored under the
seat should not be electronic as all manner of
debris collects there...and if you negotiate lots of
water crossings, that is another worry.
211311
Follow Up By: hl - Wednesday, Dec 20, 2006 at 09:08
Robin's suggestion is probably the easiest (and cheapest) to implement.
It is also very likely that your would rarely draw 500W anyway.
In which case the heavy wire is actually overkill.
Most appliances people want to run off
inverters seem to be either less than 200 Watts or more than 1000Watts (like chainsaws).
471360
Follow Up By: Mainey (WA) - Wednesday, Dec 20, 2006 at 10:15
As a regular Inverter user I can say I often wish I had double or triple the 300wt I have, as to the size of the cable if you go small you will loose power.
471368
Follow Up By: Member - Alex K (NSW) - Wednesday, Dec 20, 2006 at 11:28
I'm not the most technically electrical....
So positive from battery to inverter (through fuse), then negative from inverter to solid earth.
You say that I could run 2x 8G cables to the inverter from the battery and again from inverter to earth, instead of 1x 4G (which is obviously very thick and hard to get through things).
471380
Follow Up By: Mainey (WA) - Wednesday, Dec 20, 2006 at 13:51
Alex
read the fitting instructions in the box first.
I believe they would suggest you run from + on battery to inverter and back to - on battery.
as was posted..."run 2x 8G cables to the inverter..........instead of 1x 4G which is obviously very thick and hard to get through things"
2 x 8g cables are wider (in total) than 1 x 4g cable when the 2 x 8g cables are laid side by side, so the hole would have to be wider for the two 8g cables.
You have to remember that there is 4 x widths of insulation in the 2 x 8g cables and only 2 x widths of insulation on the 1 x 4g cable, each cable has insulation on each side with the cable in the centre when laid down side by side.
471417
Reply By: Member - John - Wednesday, Dec 20, 2006 at 09:11
Alex, I am with Willem, not under the
seat please. If you doa
water crossing and the inverter is on,
water into car, 240 volts running around car, not good. Sure it is fused, but.......... Don't worry, I did the same to once, then relocated it when I thought about it more.
211314
Follow Up By: Robin - Wednesday, Dec 20, 2006 at 09:32
Hi John
That's a fun thought isn't it.
Mine's under front
seat , but mounted for quick removal
and with local 175amp Anderson connector so that its
actually not operational till
camp.
Also because leads of 4 meters or so bring another
factor into play "Inductance" .
This reduces the
inverters surge capacity at about
twice the rate that it reduces it wattage supply.
So have another 175 Anderson wtih 500mm leads to battery under bonnet for
when I run my 1500w jackhammer.
Robin Miller
471362
Reply By: F4Phantom - Wednesday, Dec 20, 2006 at 09:20
Man, your not simple job is my dream run. Whenever I attempt a new car project I could only wish for a few simple problems like this, in my case I usually end up breaking some inportant part of the car, end up with 'spare parts', snap plastic clips so the plastic part wont go back in without glue, have mechical components out that cant be refitted without a special part from the shops which are now closed (because the job has taken me over 5:00pm) or the part is in another state, I have to work the next day and the car is undrivable, I am bleeding from every knuckle and skin is all over the floor and oil is in my cuts, my wife is angry because the new expensive thing I wanted do do cost to much, and is not compatible, the new item also needed to be modified and I accidently broke it making the long term use of it annoying (unlike everyone else who's thing just went it like the directions say!) and I am feeling frustrated and annoyed after having to risen to every challenge all day long, being positive against all opposition and now dont have any mental ability to overcome the last fatal problem knowing I cannot finnish this short half hour job in the space of 1 day. Also I didnt mow, clean up the house, fix the roof and all the other things I was going to start at 10:00am having started my job at 9:30am giving half hour to finnish. BTW, try fitting it in the passenger foot
well under the dash, its high up and out of the way.
211316
Follow Up By: Member - Karl - Wednesday, Dec 20, 2006 at 09:32
It's good to see that I am not the only one who has these experiences - I always measure twice, cut once and then hammer to fit :-(
Being as mechanicaly challenged as I am I now tend to pay someone to do a lot of the more difficult chores on my car - it saves my sanity in the long run.
471361
Follow Up By: Member - Jack - Wednesday, Dec 20, 2006 at 14:00
I am (almost) with you Karl - except I can cut out two steps by just hammering to fit. Saves all that cutting and measuring. And generally once it is fitted it stays fitted ... even when I want to "unfit" it.
Jack
471418
Follow Up By: Gramps (NSW) - Wednesday, Dec 20, 2006 at 16:45
LOL I think we have a quorum :))))) I thought everyone else on this site was a mechanical/electrical/DIY genius
471449
Reply By: Member - Norm C (QLD) - Wednesday, Dec 20, 2006 at 09:24
Alex, you have a couple of things conspiring against you here. First, the size of the inverter and therfore the current it will draw at maximum load. Second the distance you plan on placing the inverter from the battery.
I have a similar set up, with inverter permanently wired to deep cycle battery in engine bay and positioned just behind the front passenger
seat, but up off the floor (we have removed our rear
seat). But I only have a 300W inverter that is never used anywhere near it's full capacity. I was therefore able to get away with 4 guage (I think that's what it is, possibly a bit bigger) wire which is protected by a 20 Amp fuse. Fuse will blow
well below
inverters maximum capacity.
If you are going to ever use your inverter at or near it's capacity, you will need to use heavier cable, but I doubt that you will need cable that is 12mm thick, particularly if you mean 2 @ 12mm. Sounds way too big. Because of all the different ways of specifying cables, it is hard to say. This article by Collyn Rivers covers this issue:
www.motorhomesaustralia.net/cable.html
I tend to always talk in terms of mm squared of conductor. I'd have thought 10mm squared cable (which is about 8mm overall diameter) would be plenty big enough for your purpose. Smaller if you will never use the inverter at full capacity (and you protect the cable with an appropriate fuse).
As for getting through the fire wall, I just found a gromett where other cable went through. Pushed a piece of wire through it (like a wire coat hanger), tape your cable to it and pull through.
211317
Follow Up By: Member - Alex K (NSW) - Wednesday, Dec 20, 2006 at 11:35
Hey Norm,
The cable that came with the inverter says 4G on it and approx measuring with ruler, it's about 12mm diameter (wire and insulation).
The replacement cable I need from JayCar is still 4G but only 10mm think. I've heard of the mm squared way of measuring but not sure how that translates to G's (gauge).
Site Link
I have grommets I could go through but nothing that would accept 2x 10mm cables.
Alex
471384
Reply By: Raymond from Wanderin 4 Wheelers - Wednesday, Dec 20, 2006 at 09:31
Hi Alex
Keep the inverter high as others have stated, the cargo barrier is a good place for
inverters and HF radios if the
water gets that high you will have other problems than the 240 volts. No holes are allowed to be drilled through the firewall, you have to use existing holes. The 4g wire should take the current unless you are going to draw 500watts constantly
Ray
211318
Follow Up By: Member - Alex K (NSW) - Wednesday, Dec 20, 2006 at 11:17
Ray,
Why can't you drill an additional hole in the firewall and use a rubber/plastic grommet to protect the wire?
Unfortunately, I don't have a cargo barrier yet.
Alex
471377
Follow Up By: Raymond from Wanderin 4 Wheelers - Wednesday, Dec 20, 2006 at 11:51
While in the dealer who sold us the chassis for the motorhome I inquired about putting a new hole through the firewall and was told NO it is illegal. We found there was more space than we thought and the wires have all fitted through the existing holes.
Ray
471393
Reply By: Keith_A (Qld) - Wednesday, Dec 20, 2006 at 09:46
Hi ALex : First, you are aware of the need to avoid voltage drop by using large cable - so you are ahead of the pack. The low voltage cut-out is a great feature to protect the inverter, but a PITA when it happens. A larger cable will avoid that.
Naturally the load on the inverter - and hence the 12V wiring - depends on the current draw of the 240V device you need to power. What is the 240V current needed? This may give you some room to use smaller cable.
Have you seen the articles and formulea on Collyn Rivers site :
Voltage drop equals (cable length (in metres) X current (in amps) X 0.017) divided by cable CROSS SECTION in mm.sq.
His site has numerous articles on all things electrical for
camping, including wiring.
In particular - check out the 'wiring woes' article.
Site Link
So - if the device pulls 240watts, then DC current draw is a bit over 20 amps (
inverters are never 100% efficient).
So - (4.5m + 4.5m) x say 20amps dc x .017 / 12mmsq = 0.255V drop.
Recommended maximum is 0.36V (3% of supply 12V). The inverter alarm/cutoff probably works around 11.5V
Finding access through the firewall can be a challenge.
On some vehicles, there is no option but to drill a new hole.
Have you checked out the grommets in the floor drain holes? This could be an alternative (& Silicon seals
well).........Best of luck with the project - hang in there.
nb I use 18sqmm cable to my car anderson plugs, van battery and fridge. The old adage - do it once - do it right. (takes the same amount of time).....Keith.
211324
Reply By: Shaker - Wednesday, Dec 20, 2006 at 09:49
Under the
seat is a little vulnerable during river crossings.
A friend of
mine lost his radio because of that!
211325
Reply By: Member - Alex K (NSW) - Wednesday, Dec 20, 2006 at 11:23
I hear a lot of people have concerns about
inverters under seats, and probably rightly so. I don't do many river crossings and haven't yet don't one that has come close. I guess as a precautionary measure, I can always unplug the inverter from the battery before attempting the crossing, just to make sure.
211335
Reply By: kev.h - Wednesday, Dec 20, 2006 at 11:32
The earthing issue is easily solved by using a bulk head fitting as used in fibreglass boats - its a brass bolt about 50mm long threaded both ends with a thin hex 20mm from one end and a nut and spring washer on the other - you drill a 8mm hole in the firewall poke the long end through then fit
the nut and washer, fit a battery type earth lead from the engine bay side to the point where neg battery lead attaches to the body you now have a threaded fitting inside the car to attach any earth returns this means you only have to run one positive cable through the firewall use a heavy cable and an insulated terminal block (also from boat) this gives you a distribution point inside the car as
well all this cost less than $100.00
Regards kev
211337
Reply By: On Patrol - Wednesday, Dec 20, 2006 at 20:24
Hi Alex
I am using a 1500watt constant (3000w Peak) inverter with 2G cable attached to my cargo barrier, the cables passed along the sill cavity, and I have found a grommet in the floor under the passenger foot-
well close to the sill cavity (Nissan Patrol), that will accomodate these cables (12mm each) after being sure they dont hang too low to be hung up on anything, and they are protected from chaffing by the grommet, they were sealed with a silastic compound to prevent
water ingress and secured to the chassis to be sure they are very secure, and a cover plate fitted to the chassis to be sure to be sure as additional protection.
I calculated the wattage peak and decided that 4G was too small for the possible load. My setup has never caused me any concern due to VD or overheating.
So what I am saying is, with your 500w inverter 4G is correct, 8G I feel is too small for your task and would cause VD (Voltage Drop)and possible hating problems.
NB. I am not an auto electrician, this is just MHO.
Colin, On Patrol.
211423
Follow Up By: Member - Alex K (NSW) - Wednesday, Dec 20, 2006 at 21:06
Hey Colin,
Sounds like you have a good set up.
Just a quick question regarding running the cable. So you have run both pos and neg cables from aux battery down under the car and attached it to the chassis, then the cables come up through a standard grommet under the rear (right) passenger foot-
well? Where exactly would that be, sorry, little confused and have never seen such a grommet under the LC80?
Alex
471496
Follow Up By: On Patrol - Wednesday, Dec 20, 2006 at 21:18
Alex,
I am sorry if any confusion has occurred!!!
My car is a Patrol, and the (2) cables run to the Battery(100AH Deep Cycle) via the side sill cavity (under the trim panels and carpet, on my GU, and go through the floor under the front passenger foot
well near the fire wall. This set up does not cause any cables to be causing the carpet or trim to bulge in any way. I would imagine the Tojo has a similar cavity along under the door apertures.
On Patrol.
471497
Reply By: obee - Wednesday, Dec 20, 2006 at 20:55
when I fit the inverter that I am yet to get, I will put it close to the battery and run the 240 volts to a socket in the cab. That way there is no loss on the 12v cable and of course there would be negligible on the 240v cable which can be any old extension lead. The unit is out of the way too.
Owen
211431
Follow Up By: Member - Alex K (NSW) - Thursday, Dec 21, 2006 at 09:59
Hi Owen,
Great idea, had a similar one myself originally, however I couldn't (for the life of me) find a suitable place under the engine bay where it wouldn't get wet. Unless of cause your battery isn't in the engine bay??
Would appreciate your thoughts.
Alex
471574
Follow Up By: Alloy c/t - Thursday, Dec 21, 2006 at 11:05
OBEE , having a longer 240v ac cable will perhaps solve the 12v dc voltage drop but what the ---- happens if / when the 240v cable chaffes thru /gets wet ect ect 1x "live with 240v" ZAp Zap ZAp ,fried obee.
471584
Follow Up By: Mainey (WA) - Monday, Dec 25, 2006 at 01:02
Yep, fried, '
well cooked' and not 'medium rare', with 240 volt running riot throughout the chasis....
472139
Reply By: obee - Monday, Jan 01, 2007 at 09:32
Hi Alex
sorry so long getting back.
As a rule water does not get up in the engine bay unless you are doing a
river crossing that I myself would never attempt. Some people love swimming their cars so I would recommend an isolation solenoid or manual switch (heavy duty) on the 12 volt feed for them. Also you can isolate it that way to stop losing amps when it's not being used. A bit of silastic might be worth applying to the plug for peace of mind.
A couple of replies suggested it is unsafe to run 240 through a car but they do it ships and boats and
well, you know, I have it in my house and garage with the same considerations for safety. I reckon more water splashes around my kitchen and bathroom than my engine bay. You could even build an earth system into it in case of appliance shorts if you wished but most of the stuff we use does not require an earth.
Mounting a plug on or under the dash provides some minor problems but you could simply hang the plug that comes with the extension somewhere convenient and out of sight. If you use the typical wall plug make sure there are no exposed wires is all.
I suppose you should have a sparky look it over for peace of mind but that it your responsibility.
good luck
Owen
212676
