Dual fuel stoves
Submitted: Wednesday, Dec 27, 2006 at 19:01
MartyB
I am considering buying a Coleman Dual
Fuel stove, I have read the archives & most people seem happy with them. A couple of questions for those who have them.
I have a family of five and we have a camper trailer. I am looking at the compact 2 burner model 424A700 plus the single burner 533B705. The idea being I could fit a BBQ plate to the 2 burner and still have the single burner for saucepans. Does this sound like a good setup of would I be better off with two of the 2 burners?
I have an idea of fitting a box to my trailer sidestep (in front of the wheel) to store both stoves, this is why I went for the compact model instead of the 3 burner model. This area currently has 2 * 4.5 kg gas bottles which I would remove if I went to dual
fuel. Lots of space savings by having the stoves outside of the main trailer area.
Plus where are the good
places to buy the shellite from and what should I expect to pay?
Also what type of container should I buy to carry the shellite, original plastic container does not seem strong enough.
Any other suggestions with these stoves?
from Marty.
Reply By: Member - Tim - Stratford (VIC) - Wednesday, Dec 27, 2006 at 19:16
Marty,
I've got a Coleman dual
fuel cooker and lantern - they both work
well on unleaded - there is actually less 'smell' from
fuel when turned off when using ULP. I still run about 1:5 tanks of Coleman
fuel vs ULP. The Coleman
fuel has a rust inhibitor added - I'm led to believe this may be a small quantity of methylated spirits. I find the Coleman tin can good for transporting
fuel when not using ULP in a 20l jerry. You may be able to modify or fit a jerry holder to your trailer to make carrying
fuel easier.
If carrying your stove in a box outside your trailer you may want to think about some form of padding. The stoves do rattle around a bit. I had some heavy wear marks on my
fuel tank due to it vibrating in the stove whilst driving on bush tracks and country gravel roads. I found a good solution to this was the
young blokes pj's - I cut a leg off and this slides over the
tank and prevents rubbing.
It also pays to follow the instructions - I have 'over-pumped' my stove a few times and instead of working better for longer it just burns with a dirty yellow flame - something to remember. I also release pressure by loosening the fill cap after use. I'm not sure if this will prolong seals etc but only takes a second.
Tim - Stratford.
212216
Reply By: Member - Phil G (SA) - Wednesday, Dec 27, 2006 at 20:23
We have the smaller 2-burner model you mention. Works fine, provided you get your head around working the pump to keep the pressure up.
2-burner + single sounds like a good setup. The stoves last forever, so you don't want to be lumbered with a 3-burner when the kids no longer want to go
camping.
Coleman make a BBQ plate, but I don't think it fits the smaller 2-burner stove - worth checking. We used to find a steamer to be good for veges on a single burner when the 4 kids used to coma away with us.
We buy the Coleman
fuel - is usually marginally cheaper than shellite - about $16 for 4 litres normally. Lasts a long time. I have friends who have always used ULP without any problems for many years. We store ours into a 5 litre Rheem
fuel container.
Like Tim said, they can rattle around on corrugations. I put a couple of strips of sticky velcro on the
tank to stop rubbing.
212230
Follow Up By: Outnabout David (SA) - Wednesday, Dec 27, 2006 at 21:54
Hey Phil,
Merry Xmas and happy New Year.
"4 kids used to coma away with us."
Didn't realise you used the left over laughing gas from work to put the kids in a coma!
David.
Must try to catch up with you this/next year
472511
Reply By: Brew69(SA) - Wednesday, Dec 27, 2006 at 21:00
No need for shellite. Just use ulp. (much cheaper)
212237
Reply By: MartyB - Wednesday, Dec 27, 2006 at 22:08
Thanks for the replies.
I will buy them & start practising.
Marty.
212246
Reply By: Kumunara (NT) - Thursday, Dec 28, 2006 at 16:08
Marty
I have a two burner Coleman Dual
Fuel stove fitted in my camper trailer>
I have a single burner which I keep in my vehicle.
I find them excellent. I would not go back to gas. I use the coleman steel
fuel containers. I have found it difficult to buy shellite. If you want to save money you can run it on unleaded and occasionally use the coleman
fuel. I however always use the coleman
fuel / shellite.
I also have the Coleman Dual
Fuel Lantern.
You will save a lot of space using Coleman Dual
Fuel and you will no longer need gas bottles.
212309
Reply By: Member - bushfix - Thursday, Dec 28, 2006 at 20:05
G'day mate,
re place to buy shellite...if you can find a petroleum distributor willing to accomodate a customer such as yourself, I believe their name for this stuff is Solvent 143 (i have incorrectly referred to it as Solvent 103 in the past I think) and you may be able to score a 20L drum to save some dosh.
anyway, they are a ripper I reckon, from one person to a mob of six and beyond, can use the
camp oven :) on them also if weather is crook.
212326
Reply By: Member - Darren T (VIC) - Friday, Dec 29, 2006 at 00:39
I bought a Coleman "multi fuel" single burner stove about 3 years ago. I still maintain its the best peice of
camping gear I have ever bought. I don`t know if the dual burners were on the market then, but if I had seen one or known about them I would have bought one.
The multi
fuel stove is the same as the dual
fuel stoves in the way it operates (fill with
fuel, pump up and light etc) but intstead of gas it runs on either Coleman
fuel or Kerosene.
I choose to run it on a kero/ULP mix instead of the Coleman
fuel because it was cheaper basically. I found straight kero wasn`t volitile enough to give a hot flame on its own and it took a while to boil the billy, so I mixed about a cup of ULP into 1 litre of kero and it works really
well, boils the billy in no time.
Using the stove about 5 times a day for all cooking (used in conjuction with 2 butane gas stoves), boiling the billy and heating up
water for doing dishes, 1 litre of the kero/ULP mix would last around 4 days.
212360
Reply By: MartyB - Friday, Dec 29, 2006 at 10:25
One thing that stands out is every reply is positive, not one person saying they prefer gas. No one even said my idea of having double & single burners was a bad idea. So far the only
fuel I have noticed is the shellite. I will look for the coleman
fuel if only to get the container. I will also see what price I can buy a 20l of Solvent 143 for. I will probably only use ULP when I run out of the other fuels, handy backup.
I had thought of padding the box I am going to make but had not thought about padding the
fuel tank so I’ll do that. Also I will check that I can get a BBQ plate for the model I am looking at, might have to go up to the next model.
I recently bought a dual
fuel lantern which works
well, that is what go me thinking on converting my cooking away from gas and removing the gas bottles from the camper.
From Marty.
212394
Reply By: pixiemops - Tuesday, Jan 02, 2007 at 20:52
The duel
fuel are simply excellent. Out of all the
camping equipment I have the duel
fuel stove and the lantern are the best .
I dont even bother using shellite and havent had a problem for years. When i do (have replaced light once)i will simply put a new generator in . Im no handy man and even i can do that its a sinch. By the time you need to spend 15 bucks on a new generator I figure you will have saved the cost by just using unleaded.
will never bother with gas again.
212917
Follow Up By: MartyB - Tuesday, Jan 02, 2007 at 21:46
Thanks for the reply, my only aversion to using unleaded is cooking toast. Do you
cook toast on unleaded and can you taste it at all?
from Marty.
473119
Reply By: pixiemops - Tuesday, Jan 02, 2007 at 23:40
Hi Marty
All the time we
cook toast and no different to cooking on gas . We dont have a proper toast thing we just put the bread straight ontop of the coleman bars. It would be better to have one of those toast holders as sometimes i loose a crumpet in the holes .
No taste of any fumes whatsoever it burns as clean as gas as far as i can tell. Infact it burns even hotter . You can boil the kettle in no time at all and at the other end of things turn it right down low to do your toast carefully. My experience is no different to gas just no bother with cylinder burns hotter and to start it you will have a yellow flame for 1 minute till it cranks up. Just follow the instructions . Otherwise it is great . Liked the coleman stuff so much just bought the coleman hot
water on demand system for our last trip . Best toys for
camping .
The stove we have is the powerhouse 414 you can get a smaller one too.
happy
camping
212951
Follow Up By: pixiemops - Tuesday, Jan 02, 2007 at 23:52
Sorry Marty I see your question was directed specifically to use of unleaded petrol.
It is all I use as mentioned and no food taste whatsoever.
473145
