Wednesday, Dec 27, 2006 at 21:08
G'day Greg
I used to own a '00 t/d courier XLT,dual cab, and spent a further $5k trying to improve it.
2ND battery,b/bar and winch made the front continuously bottom out (yes you can wind them up)but the standard torsion bars where too soft and back springs where hard when empty(It is a ute!)
I had some trouble with bad
fuel blocking a small gauze type filter in the injector pump,why the primary filter system couldn't catch it,dunno.This was found obstructed 3 times,over 2 years (20000 klm)
another thing I had real issue with was the amount of turbo lag it had,on a steep
hill, say second high,it would charge up, plenty of power to spare,but if you backed off for a wash out or hole, it totally dropped its bundle sometimes it needed low range just to get going again,especially with some weight in it,and on sand,giving me a bit of turbo rage sometimes and slipping the clutch to get revs up.It hasn't got electronics on the motor (for me,a PLUS).
I got around 10 - 11 litres/100kl before acc.,high top canopy acted like a parachute and I put larger 31/10.5r 15 all terrain K/O's caused the
fuel to go to around 13l/100 ( Bris to Melb return,Newell h/way 100-105 kph)
I found that after spending $2k on OME springs/shocks/t bar It made a difference off road but I got constantly reminded of it's limitations (wheel travel)and bigger,more aggressive tyres did make improvements,but still not enough for me.There is an arb air locker available,rear only.
expect funny wear patterns on front tyres(most ifs do the same)
My gear box had to be re-bearing 70k (over 5 years old) $2353,crappy batch of bearings I'm told,pick a make of any vehicle and some one, some where has had the same prob.
I would own one again,I had
mine for almost 6 years,It got me in to lots of
places,just at a higher degree of difficulty.
If it's gunna do some hard work get a heavy duty clutch,I know some blokes that use couriers as service vehicles that constantly carry 7-800 kgs and they had all 3 stuff their clutches early.
I did a thread search and found a few unhappy owners/drivers comments,but if you look hard enough you will find negative posts on ANY fourby
212238
