dual battery system for LC100 turbo diesel
Submitted: Wednesday, Jan 03, 2007 at 14:46
ThreadID: 40829 Views:10487 Replies:8 FollowUps:11
Hi there,
I'm in the process of outfitting my 06 turbo diesel land cruiser (with 2 cranking batteries) and am interested to know how other owners have set up their dual battery systems in this vehicle - will need an anderson plug off the tow bar as well. Currently have a rotronics 3 stage unit in the Discovery and have been really happy with the performance but have been quoted well over $2000 for a similar unit in the cruiser. I would really appreciate any advice people have to offer... cheers, Dave.
Reply By: aeiou - Wednesday, Jan 03, 2007 at 14:59
Hi Dave,
I recently added a 3rd Battery to my 06 TD 100 series.
I ended up buying the ARB kit with a GEL battery it only fits a smaller battery.
The smaller sized battery (50a/h) is good enought for what i needed.
There are battery trays out there to suit larger batteries (70 a/h). But not sure where you can get them. (Maybe TJM stores) or derek form ABR sidewinder??
Some people rewire the factory batteries, but i was advised that it could void the 3 year factory warranty, and was going to be more expensive than adding a 3rd battery.
Good luck and i look forward to hearing what you end up with.
Dave
AnswerID: 213028
Follow Up By: joc45 - Wednesday, Jan 03, 2007 at 15:25
Re warranty, a while back, ARB did a friend's 100 series by separating the two batteries with a simple solenoid. Reckoned it would be fine. I didn't think it was a great installation.
FollowupID: 473277
Follow Up By: David78 - Thursday, Jan 04, 2007 at 15:40
Thanks for the reply Dave... where did you put your third battery? also, what was the approx cost? By the way, I have spoken with toyota and they reckon that even if you put a third battery in instead of splitting the two factory fits, if a fault can be attributable to that installation, the warranty would be void for the repair work required.
Thanks again,
Dave.
FollowupID: 473536
Reply By: Member - Tim - Stratford (VIC) - Wednesday, Jan 03, 2007 at 15:06
Dave,
I've got a thrid battery in my '04 GXL T/D - the ARB/Pirahna system. As said above, you can't fit a huge third battery on this tray but it will power the engel for days when camping in cooler weather (this is when we camp mostly).
I've also fitted an anderson plug to the rear - I made a small plate and had it welded to the kaymar tyre carrier so it's out of the way. I initial ran it directly from the third battery with a fusable link - I've now changed this to include and isolator. Haven't had any probs with it, its been on for 18mths +.
The truck now charges the two main batteries, then the thrid, then the camper batteries.
As already stated there are ways to split the two cranking batteries and then replace with larger batteries etc, but this does void the warranty which I'd rather keep!.
The cost was well under the $2000 - estimate at $600.
Tim - Stratford.
AnswerID: 213030
Reply By: tomjones83 - Wednesday, Jan 03, 2007 at 16:45
Hi Dave,
Definately speak with Derek from ABR. he looked after me with a Flyer setup including a 100ah battery for my TI Patrol (no underbonnet room). the system works a treat (just tested it out at fraser) powering a 110l waeco with no dramas.
(no affiliation - just another happy customer :-))
Tom
AnswerID: 213050
Follow Up By: acdc - Wednesday, Jan 03, 2007 at 18:50
Just did a dual battery system today on a new 4.8TI patrol no problem if you put some thought into it.
FollowupID: 473326
Reply By: acdc - Wednesday, Jan 03, 2007 at 18:53
David78
The best system is to use a TJM battery frame this takes a 12" battery, use this battery as your starter battery and make the two original batteries your aux, run your fridge for days and days!
And your batteries will last longer due to shallower cycles.
AnswerID: 213065
Follow Up By: ev700 - Thursday, Jan 04, 2007 at 01:35
David78
Sounds good. What would be cost of this set-up?
thanks
EV70
FollowupID: 473421
Follow Up By: Mainey (WA) - Thursday, Jan 04, 2007 at 10:29
David,
Toyota fit 2 x Cranking batteries to this model vehicle for what reason ? ?
So is Toyota wrong in using (or is that needing) 2 x Cranking batteries ? ?
Why not use a "deep Cycle" battery to run your fridge ?
If you read the battery manufacturers specifications of their own products you will see the actual difference between a Cranking battery and a Deep Cycle battery.
The benefits of using a DEEP CYCLE battery below is from Exide's web site:
"Deep Cycle" Batteries are designed to provide "deep cycle" power - making them very different from ordinary car batteries.
Starting a car requires a high amount of energy for a short period of time (about 5 seconds). Only a small amount of the battery's capacity is used. Once the engine starts running, the battery is recharged quickly by the alternator, which carries the basic electrical load.
On the other hand, "DEEP CYCLE" batteries supply a relatively low amount of current for a long period of time.
They are specially designed to power electric trolling motors and other electrical accessories in boats and Recreational Vehicles.
Unlike ordinary car starting batteries, they can be run down and recharged (deep cycled) repeatedly with minimum loss of capacity.
When a car starting battery is deep cycled, it loses capacity very rapidly and in some cases has lost its useful capacity in 50 cycles (discharges and recharges) or less.
These limitations make car batteries a poor investment when used for marine and Recreational Vehicle deep cycle applications.
A single DEEP CYCLE marine/RV battery will outlast 2-4 car batteries.
They are not my words but direct from Exide batteries, in simple English they actually sum it up by stating;
"One DEEP CYCLE battery will outlast 2 to 4 car batteries" and I suppose they could be wrong, and those who use car Cranking batteries instead of Deep cycle batteries have their own reasons but just can't substantiate them when Exide actually states "DEEP CYCLE batteries will outlast up to four (4) car Cranking batteries", it just does not make any sense to use a less efficient Cranking battery to do the work that a DEEP CYCLE is specifically designed to do.
Hoping that will clarify the situation for you!
FollowupID: 473472
Follow Up By: Member - Phil G (SA) - Thursday, Jan 04, 2007 at 16:36
Mainey,
Since the fridges became more efficient, the need for a true deep cycle battery is less common for many of us. Most of the people I trip with are on the move or using the vehicle every day. So we use twin cranking batteries. It also means that if you have a battery failure in the desert, then both batteries can easily start the vehicle. It also means that we can use both batteries for winching.
Wet cell deep cycle batteries have their downsides. You might have also seen on the Exide website that an Exide Endurance Deep Cycle battery has a 6 month warranty, while an Exide Extreme cranking has a 24 month replacement warranty. And the deep cycle battery takes longer to recharge, especially when it gets a bit sulphated.
AGMs are a different story, and once they can sort out their longevity under the bonnet of a 4wd, I'll be interested.
FollowupID: 473545
Follow Up By: Mainey (WA) - Thursday, Jan 04, 2007 at 17:47
Phil,
Yes, when your travelling and driving each and every day, as you have stated you and most of the people you trip with actually do, you could use any type of budget priced battery.
However;
for those that believe a holiday is where you go and stay at a place that you love to be, enjoying the company of fellow campers, or even the pure solitude of a deserted beach or similar enviorment, with-out driving at all, often for weeks at a time, then the DEEP CYCLE battery just can't be matched by any Cranking battery even when they are wired in parallel.
As to the 6 months warranty of the Exide Endurance, that is Exides choice, if it were a Delkor Deep Cycle battery it would have a far better battery performance and also much longer warranty as well.
If you pay a cheap price you can't expect to be getting the some performance as 'better' batteries.
As to your comment that a Deep Cycle battery takes longer to recharge than a Cranking battery that's totally true, and reason is as stated by Exide, the Deep Cycle battery is built different to a Cranking battery, as the Exide web site clearly explains.
Your point of a sulphated battery is relevant equally to both Cranking and Deep Cycle batteries.
Yes, AGM's are a very different story, on that point it appears we can agree, that's the sole reason I use them myself they are a very superior source of reliable 12 volt power when camping.
They recharge far quicker than a Cranking battery, when used as a 'storage' battery, they will discharge lower and also hold a positive charge for a much longer period of time and last for years longer than any wet cell Cranking battery.
I find that people who have not used a "good quality" DEEP CYCLE battery will still be using Cranking batteries as an Aux battery and it's only when they have advanced to the DEEP CYCLE or even further up the tree to the (yes more expencive) AGM battery, do they realise how truly fantastic it is to have a reliable power source on tap that you don't have to drive on a daily basis just to 'top it up' because the better quality DC & AGM batteries will hold their charge for much longer than a Cranking battery when powering a fridge as is explained on the Exide web site.
FollowupID: 473562
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Jan 03, 2007 at 19:42
Hi Dave
There are a few configurations but you will still need a 3rd battery or at least change and isolate the two you have.
Here is a picture for thought.
Derek.
AnswerID: 213070
Follow Up By: ev700 - Thursday, Jan 04, 2007 at 01:38
When you say 'change and isolate the two' do you mean replace them with larger (what size) capacity? What is the best alternative?
thanks
EV700
FollowupID: 473422
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Jan 04, 2007 at 10:57
I use the MRV70 Batteries. Rated at 105 A/H and 760cca each. Fit a Redarc or ABR sidewinder isolator.
FollowupID: 473477
Follow Up By: David78 - Thursday, Jan 04, 2007 at 17:11
Thanks for your reply Derek... I'll be in contact with you when you open again next week - I'm after a tekonsha prodigy installation as well as the dual batter sys. In the mean time....What's your take on the benefits of 2 vs 3 stage units when charging a camper trailer battery as well? Also, do you install/ recommend Rotronics units?
cheers, dave.
FollowupID: 473558
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Jan 04, 2007 at 18:18
Hi David
I will look forward to you call. There are many good isolators on the market as well as battery chargers. I will go through them with you when you call.
We have a new isolator on its way. They are the latest technology and even took me by surprise when tested.
Derek.
FollowupID: 473565
Reply By: Member - neville G (QLD) - Thursday, Jan 04, 2007 at 07:01
for what it is worth I have a 06 T/D cruiser with the paralel battery setup. All I did was put a low voltage cut out switch in the line and I run a 60lt. Engle from that. Lasts for ever just driving around town, have never had a problem. Email me if you want more information.
Cheers, Nev.
AnswerID: 213147
Reply By: Member - Phil G (SA) - Thursday, Jan 04, 2007 at 16:27
Just finished a dual battery installation on a mate's 100series TD.
He replaced the two original batteries with the bigger N70s, which drop straight in.
We simply wired in a Rotronics MH10 isolator.
All done for $250 for the isolator plus the two batteries.
It starts first flick on the N70. I still have no idea why Toyota gave the 100series two smaller starting batteries - perhaps they wanted it to start at 30 degrees below zero???
AnswerID: 213234
Reply By: raunchy - Thursday, Jan 04, 2007 at 22:37
Hi Dave,
Have an 01 TD GXV, Batteries are split, ie one is the Starter and on is the deep cycle. Have a marine cranker so a bit of both ways. Can use to jump or winch as well as run the fridge. Have run across the Simpson with a fridge and a freezer no problems with the split batteries, but drove the car every day or two. No room for a third, mounted the twin tongue there. I would say thats the best set up, have no idea why they have the two starter batts, am let to believe it is to do with European regs. The 1HDFTE has no more compression than the 1HZ!!! If Toyota arent going to warranty for the split batts, then it would only be for the starter motor.
Ray
AnswerID: 213303
