100 series 1hz engine rattle
Submitted: Wednesday, Jan 03, 2007 at 16:42
bandk
Afternoon all,
Can anybody help me with a noise that is progressively getting worse.It sounds like a ball bearing in a soft drink can getting shaken real fast and only occurs from 2500 rpm to 2600 rpm mainly in second and third gear.It doesn't do it in neutral so its real hard to pin point.It seemed to start after I gave it a
tank full of bio diesel.
Any ideas/solutions much appreciated.
Thanks Brad.
Reply By: Member - Tour Boy- Wednesday, Jan 03, 2007 at 17:52
After you used all that bio up did you change the filters and run normal diesel in it to see if the noise is still there. Sounds to me like a bit of crap stuck in one of the injectors that the bio loosened up. Maybe a bottle of injector cleaner will sort it out?
Tour Boy
213060
Follow Up By: bandk - Wednesday, Jan 03, 2007 at 18:17
Thanks Tour Boy,
Just had an 80'000 k service so presumed they changed the fuel filter.I'll try some moreys or chemtech cleaner and stay the hell away from bio. Ever had any results from injector cleaner yourself ?
Brad.
473321
Reply By: Member - Tour Boy- Wednesday, Jan 03, 2007 at 18:26
Was the service b4 or after the noise started. If b4 you may need to do the filters again (try the inj. cleaner first)
I've had good results with injector cleaner in both petrols and diesels. But now I add 500ml of unleaded to 90lt of diesel every couple of months just to keep everything clean. Last set of injectors lasted 270,000km and still not smokey but naturally a bit worn in the tips.
Tour Boy
213063
Follow Up By: luch - Wednesday, Jan 03, 2007 at 18:38
Yep Thats the Secret good clean fuel & filter change every 10 000km,
My Injectors have never been touched 273 000 kms still getting good economy no excessive smoke getting any where between 11.5 to 14 litres per hundred 1hz Turbo
473323
Follow Up By: bandk - Wednesday, Jan 03, 2007 at 18:38
Service was after the noise started.Had a long range
tank fitted at the same time as the service and the mechanic asked me if I'd been running it on cooking oil because what was left in the
old tank was thick as. Definitely be trying the cleaner.
473324
Reply By: Member - Tour Boy- Wednesday, Jan 03, 2007 at 19:09
Mate do the injectors as a last resort as the later 1hz injectors are around $700 whereas the early 1hz are $350. Brother in law had similar symptoms (noise and power loss) in his hilux after going the bio (now he knows why it was cheap) but a new
tank of diesel and a good flogging and it came good by itself.
Tour Boy
213069
Reply By: Gold Member (WA) - Wednesday, Jan 03, 2007 at 20:00
Bandk
i know the noise your talkin about, my 99 cruiser does it and so does my mates 02 model 100 series, i went to a mechanic and questioned him and he reckons its a common thing form the 1hz, its the valves and they need adjusting. ive put all about thison the
forum before about 3-4 days ago.
good luck
213072
Follow Up By: atoyot - Wednesday, Jan 03, 2007 at 20:27
Does anyone know for a fact if many Toyota dealers actually have shims to adjust the valves? All I ever get from them is that they are within tolerances, but a mate in the diesel business reckons he ends up doing them for the local dealer.
Andrew
473351
Follow Up By: bandk - Thursday, Jan 04, 2007 at 08:22
G'day Gold Member,
I've had a look through the
forum but could only find your post about the transfer case oil. Part of the 80 000 k log book service is a valve clearance check.After a certain 4wd service centre in Wangara had my truck for ten days my wife had to pick it up as I had flown back to work.It was then that they came up with some bull bleep story about why they couldn't do the valve clearances.I will be taking it back as soon as I get home.As I am in W.A. as
well, just wondering if you could let me know the name of your mechanic in the hope of finding some one reliable.
Thanks Brad.
473438
Follow Up By: Member - Phil G (SA) - Thursday, Jan 04, 2007 at 08:30
Andrew,
If you order the shims, they usually have to get them from interstate!! I think its also common to machine shims down until the clearance is correct, rather than replace.
"Within tolerances" usually means they have had a listen to the motor and it "sounds OK".
473441
Follow Up By: cowpat - Thursday, Jan 04, 2007 at 13:51
Haha why am I not surprised. At least here locally (Heidelberg VIC) the Toyota dealer has them in stock. They are not cheap so I am surprised why they wouldn't charge for them and use as many as possible! Casper
473519
Reply By: 666toy - Wednesday, Jan 03, 2007 at 22:16
Definitely sounds like a valve problem have it checked pronto.
I doubt it is the fault of biodiesel just unlucky for you . Biodiesel does loosen up a lot of crud in your
tank but thats a good thing once it is clean you wont have any fuel problems.
213103
Reply By: Member - Karl - Thursday, Jan 04, 2007 at 09:50
Give the guys at Robson Bros in Bentley or TLC in O'Connor a call. They have a good reputation for working on 4WD here in
Perth. TLC only do Toyotas and are very knowledgeble.
Personnally I don't think that the problem it is because of the Bio other than it cleaning out your fuel lines.
Karl
213173
Follow Up By: bandk - Thursday, Jan 04, 2007 at 10:07
Thanks Karl,
Now I know why I should have gone to Robson Bros.Sometimes trying to save some hard earned ends up costing more.
Brad.
473470
Follow Up By: Member - Karl - Thursday, Jan 04, 2007 at 20:34
Brad,
No problems - being mechanically and technically challenged I am used to breaking things and then having to take it to an expert to fix :-) so I tend to get to know who the good ones are :-)
Whilst I haven't used Robsons I know a number of people who have and they speak highly of them. I tend to use TLC as I have an 80 Series 1HZ with an after market turbo and they do a good job and take time to slap me around and tell me where I went wrong - also they are closer to Rockingham, where I live.
Hope you get the problem sorted out. One piece of advice - look at fitting a Lucas CAV filter adaptor. Costs about $140 but the cartridges only cost $5 - $8 dollars and you can see when they need changing - esp using Bio. I change
mine every 10000 kms.
Karl
473583
Reply By: Gold Member (WA) - Thursday, Jan 04, 2007 at 20:22
Brad
i usually go to a place called TLC Auto centre in
perth that is 23 stockdale road O'conner (08)93143714
213279
Reply By: bandk - Friday, Jan 05, 2007 at 09:55
Thanks one and all
Brad
213371
