80 Series Aircon
Submitted: Saturday, Jan 06, 2007 at 11:11
ThreadID: 40923 Views:3513 Replies:5 FollowUps:1
Hi all,
needs some guidance as I am not much at aircon...
I have a '96 multi valve diesel and in the last month it has developed a little quirk... the aircon works well for say 2 to 4 hours and then goes hot the compressor appears not to cycle. Next day same scenario. It appears that it needs to cool down and then is fine.
The little window in the pipe near second battery is half full when cold and appears to have gas when hot.
I have looked for signs of leaks in the loop but cannot see any obvious ones.
Suggestions will be appreciated....
thanks,
dasher
Reply By: Member - Brian (Gold Coast) - Saturday, Jan 06, 2007 at 11:58
dasher,
Sounds to me like it is suffering from low refrigerant level.... "short-of-gas."
BUT.......
Although I am a fridgie, I have very little knowledge on auto air conditioning.... I had mine serviced recently as it was showing similar symptons, although mine doesn't have a sight glass. It was short, and now works a treat!
Just my opinion
Brian
AnswerID: 213611
Reply By: drewab - Saturday, Jan 06, 2007 at 12:16
Dasher,
Had a similar problem on my 80 DX a few years ago, AC would just come on/off when it pleased, the fix was a new TX valve.
Cheers Drew
AnswerID: 213614
Reply By: 666toy - Saturday, Jan 06, 2007 at 13:19
Most likely low gas or faulty valve within the system
AnswerID: 213628
Reply By: Member - Stephen M (NSW) - Saturday, Jan 06, 2007 at 13:58
Hi there Dasher, is it genuine air or after market ?? Genuine will be nippondenso and will be tagged on the compressor, it sounds to me that the evaporator under the dash is freezing up after a period of time which will stop cold air flow till it defrosts itself. Next time it happens especially on a hot day put your fresh/recirculate control onto fresh and suck some hot air through and see if that solves the problem if so then the thermostat will need turning up a bit. BY about 1 to 2 mill clockwise. If its genuine air then as mentioned above it could be the tx valve playing up. If its genuine air then you cant adjust anything. Does it cycle on and off ok eg can you hear the compressor cut in and out. You will hear a click from inside the engine bay and if genuine, idle speed should increase and then drop back to normal idle speed when compressor cuts out.This can also be observed by the clutch on the front of the air compresor spinning when engaged and not spinning when compresor disengaged. The sight glass you are talking about should show a small amount of gas sitting there when air is off. When you turn air on this will show bubbles for a quick second or two then should be clear no foam. If foaming while air compressor is engaged then it is low on gas. (I dont think this is your problem) The other thing it could be is the high/low pressure switch playing up. An easy way to test that is next time it happens grab yourself a bit of 4mil wire or the likes and disconect the two wires running into pressure switch then just bridge the two wires with the 4 mil wire if this makes the compresor cut back in then its the switch. Hope this gives you a few things to look at ans save a few $$$. Regards Steve M
AnswerID: 213637
Reply By: Dasher_Syme - Saturday, Jan 06, 2007 at 14:44
Hi Stephen M,
it is genuine Toyota,
where is the pressure switch that you mention located?
Many thanks,
dasher
AnswerID: 213643
Follow Up By: Member - Stephen M (NSW) - Saturday, Jan 06, 2007 at 16:33
Hi there Dasher, it is usually next to the receiver dryer which for memory is just behind the grille. The receiver dryer is where the sight glass is it will have two wires running from it. If its not there just follow the two lines around the system and you will find it. The last air I fitted to one of the 80 series cruisers was back in 93 so not sure wether they have located them in a different spot but it will 100% have one fitted to it. Could even be located next to the radiator around the headlight area. MInds gone blank at the moment. I fitted airs for toyota for a few years and did hilux's, corolla,camrys, hiace's etc so trying to remember where each item was fitted now is annoying me for not remembering must be old age catching up with me. Let me know how you do if you cant find it, but it will have with out fail 100%. Regards Steve M PS just a note when you want to ask a question to one of the replys go to the follow up link otherwise your question will go to your email as posted the original question. I only saw your question cause I had a look back at the original post. Just a hint thats all no problems.
FollowupID: 473985
