valve clearance on 1HZ!
Submitted: Tuesday, Jan 09, 2007 at 21:10
husky01
Hi chaps,
I've taken the rocker cover off the 1991 1HZ landcruiser and measured the valve stem clearances.
they are all either below spec or right on the bottom margin. 300,000Km on vehicle.
the #6 inlet is on zero and I take it this means danger of burning valve and needs immediate re-adjustment?
quick question: is it OK to sink the followers with 2 screwdrivers to remove the shims?
Is it best to order in some geniune toyota shims?
Thanks very much for your help and advice if you've done this before, I'm just checking before I go ahead.
Husky
Reply By: Member - Robert (WA) - Tuesday, Jan 09, 2007 at 23:10
if you only have one or two to adjust then you can use 2 screwdrivers to remove the shims make sure that the piston is not at top dead when you push the shim down as you could bend the valve
regarding the shims you could find a machine
shop that has a surface grinder to grind the amount of clearance you need
or the engine recondition
shop might have some second hand ones with the right size
What i do when if i am doing all the tappets in the car is measure all the clearances
then take the cam out and place the shims in a egg carton one side exhaust one side intake make sure you mark the egg carton in & ex 1TO 6 and mark the shims (1e or 2I and so on)
If you do pull the cam out make sure you set the cam up so the timing marks on the cam are at the 9 o'clock mark that way when you put the cam back in and bolt it down the valves will not hit the pistions
Robert
214334
Follow Up By: husky01 - Thursday, Jan 11, 2007 at 12:22
Hi Robert,
I have taken the cam off and now waiting for the shims to be delivered. Above, you say to make sure that the timing marks on the cam are at the 9 o'clock position - isn't that TDC? I have set the cam to BDC (12 o'clock on the cam sprocket) before I took it off - can I just check this with you???
474930
Reply By: Mikee5 (QLD) - Tuesday, Jan 09, 2007 at 23:15
Hi husky,
I guess if you have steady hands you could use two screwdriver. I made an SST out of 1 inch flat steel so that its width was tapered and would hold the bucket down. I can post a photo tomorrow if you want, I just started with the flat and fine tuned it with an angle grinder until it worked. I also bought a magnetic pickup to lift out the shims, they seem to stick in because of the oil film. Free them first with a fine screwdriver. You will need a micrometer to measure the shims. I bought genuine Toyota shims - I didn't know of anywhere else to get them. I have an Excel spreadsheet that computes the required shim. Let me know if you want me to email it.
Many posts here said don't try it youself when I put up a similar query - LOL.
Try an archive search.
Mike.
214336
Follow Up By: husky01 - Tuesday, Jan 09, 2007 at 23:25
Thanks mike if you could email a piccie tomorrow that'd be great. i think i'd prefer to make up a tool than to remove camshaft. i've got a really strong little magnet (out of a deceased hard drive) that might come in handy also. I just read through some of the other threads with some good advice. i'll re-measure stong cold in the morning and order some shims off toyota. because one is at zero, I may have to do it twice as I can't measure it properly as is.
oh, and yes I've got a spreadsheet (off LCOOL) I presume this is the same one? Its a ripper.
thanks mike and robert appreciate your time
husky
474566
Reply By: Mikee5 (QLD) - Wednesday, Jan 10, 2007 at 14:25
Husky,
Photos of SST now in my photo gallery.
The spreadsheet is the same one I used.
Mike.
214426
Reply By: Member - Robert (WA) - Thursday, Jan 11, 2007 at 19:15
Hi Husky
What you have done is ok by setting the cam at 12oclock it just means when you put the cam back in you have to make sure the that the cam is set up at 12oclock
Because at 12oclock number 1 and 6 pistons are at top dead centre and if the cam is out by a bit when you tighten the cam down the valves can hit the pistons
When the cam is set up at 9oclock timing marks the pistons are are down the
bore so when you tighten the cam down the valves will not hit and also you can turn the cam with out hitting the pistons so you can check the valve clearance with out the valves hitting the pistons
on the cam cover there is two timing marks 1 at 9oclock as witch is for taking the cam in and out and one at 12oclock for top dead center witch is for setting the timing with the pump gear
the
fuel pump gear cover has the same two marks one at 9oclock and one at 12oclock
When you tighten the cam down make sure you tighten it down evenly
hope this helps
Robert
214766
Follow Up By: husky01 - Thursday, Jan 11, 2007 at 22:33
Thanks Robert,
I am not sure if there are differences between our engines, but
mine definately has TDC at 9 o'clock (on both the cam sprocket and injection sprocket) and BDC is 12 o'clock on both. Before I went ahead I double checked and the manual, timing gear cover and sticker on the rocker cover said the same. I was a bit worried there for a minute! I can only guess that yours is different to
mine??
Thanks again for your help,
475086
Reply By: husky01 - Thursday, Jan 11, 2007 at 22:39
LOL!
Robert, I have just seen on your profile and I see that you have indeed a different vehicle. Juct for clarification, for anyone else reading this post looking to do their shims on a 1HZ diesel:
on the 1HZ TDC = 9 o'clock, and BDC = 12 o'clock
214814
