aerial mounts
Submitted: Thursday, Jan 11, 2007 at 06:30
Member - Peter A (VIC)
Hello All,
Can anyone give me some good advise on the best mounts for aerials UHF and CB to overcome corrugations as last time I went away the normal rubber mounting fell apart, also what type of aerials would be the best
Thanks Peter.
Reply By: snow - Thursday, Jan 11, 2007 at 07:31
I use an elevated feed with a spring base...can't say I have had any problems as you describe.
214580
Reply By: Member - Karl - Thursday, Jan 11, 2007 at 09:18
IMHO I would use a spring base aerial as this allows for aerial to take the vibrations and to move with them, rather than being solid and shaken loose.
Without starting an arguement on which brand of aerial is best - I use the Benelc brand that you by from Dick Smiths,
Supercheap etc - they work for me.
214602
Reply By: Steve63 - Thursday, Jan 11, 2007 at 09:40
I've had better service from spring bases rather than solid mounts. I have noticed that the rubber mounts tend to fail. I have an odd setup for my HF and it has a small whip on a rubber mount. I usually take a couple of spares as they seem to self destruct. I have never had a UHF base fall apart but any number of antennas have fallen apart or snapped. I chucked out the remains of 4 or five the other day. I think the base has an effect on the life of the antenna. A good spring base with a one piece wire or glass antena (GME) is what I have now and has done a lot of kms on corrugate roads. Not saying GME is the best, it is just what I am using. As an observation, different setups seem to do better on different vehicles. The old Jack had very high frequency vibrations and it snapped various mounts, even a Predator mount. The Cruiser seems to be much lower and as a result there seems to be less destruction.
Steve
214612
Reply By: Member - Phil G (SA) - Thursday, Jan 11, 2007 at 19:00
Simple is best. A small 6 inch rubber stubbie aerial on a ground independant base on the roof. It works as
well as a bullbar mounted aerial and survives the corrugations. I have fixed many of the elevated feed aerials over the years. The coax seems to come adrift where it slips into the base.
214764
