Battery Current Saver gadget for your fridge
Submitted: Thursday, Jan 25, 2007 at 23:16
ThreadID: 41637 Views:3513 Replies:10 FollowUps:7
Anyone using or got any feedback on this gadget. It is advertised here on EO.
VGR
Allows you to set when and how long the fridge runs every hour instead of fridge controlling the operation thereby reducing excessive 'on & off' current draw. Says current draw can drop below 1amp/hr!! - a decrease of 75%!!
Switching on the unit also allows you to turn fridge off overnight or on again in morning.
Surely by now the fridge companies, who are always looking for an edge over the competition, would've built this feature into their product if it worked.
Cost is $125.
Reply By: Black Beard - Thursday, Jan 25, 2007 at 23:24
The fridge will only turn itself on if your beer is getting warm, it doesn't care what the clock says. The clock doesn't care how cold your beer is - I think I'm letting the fridge do the talking!
AnswerID: 217851
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Jan 25, 2007 at 23:30
WOW !
Old technology. Can't believe the website is still working.
Stay away is my opinion. The following statement will cause some grief.
"There are a number of refrigeration units available; the best one to choose is a compressor driven unit. A unit that will also deep freeze is a 12 Volt unit marketed by a Mount Waverley Victoria based company named DANFOSS"
AnswerID: 217852
Follow Up By: RovingOz (QLD) - Thursday, Jan 25, 2007 at 23:44
So old technology that doesn't work or is the product doubling up with modern day fridges.
FollowupID: 478267
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jan 26, 2007 at 08:56
Hi Rov
It does not protect your battery from discharge and high start up current every 1/2 hour or so could use more power in the long run. It is also user dependent and has space for error.
Derek.
FollowupID: 478285
Reply By: Richard Kovac - Thursday, Jan 25, 2007 at 23:41
I have one and have been running it for years, after stuffing one battery I got one, It seem to work as said (dam better getting to sleep at night) it's in it's second vehicle 9 years 180000 km there abouts.
Richard
AnswerID: 217854
Follow Up By: RovingOz (QLD) - Thursday, Jan 25, 2007 at 23:47
bleep then where have I been!
Saw it in my home page as a new press release.
I'll go back to sleep now....
and buy one tomorrow :)
FollowupID: 478268
Follow Up By: Richard Kovac - Thursday, Jan 25, 2007 at 23:57
not sure that you are having a go at me, but Fred is the guys name and they have been on the form before, lots of people putting them down, (but most can sell you something better) ..LOL
FollowupID: 478270
Follow Up By: RovingOz (QLD) - Friday, Jan 26, 2007 at 00:07
No Richard, having a go at myself for being slow on the uptake.
Know what you mean about the getting to sleep thing. That alone would make it worth buying.
FollowupID: 478271
Follow Up By: Richard Kovac - Friday, Jan 26, 2007 at 00:18
Mine doesnt look like the one on hes site, that would be better as I (we) have knocked the 1-10 timer a couple of time and have discharge the battery to below safety limits, as you set it to freeze didn't take long to stuff the second battery.
Richard
FollowupID: 478273
Reply By: RovingOz (QLD) - Friday, Jan 26, 2007 at 00:14
Forget it, delete the post, stupid just did a forum search on it.
I remember reading one of the posts 2 years ago.
ZZZZzzzzzzzzzz.......................
AnswerID: 217860
Reply By: Member - Andrew K (QLD) - Friday, Jan 26, 2007 at 06:39
I also have a device which cuts the fridge power use but mone is much more efficient, saving up to 100%.
It is the off switch. I use it every time i want hot beer. Same principal as the hourly use one.
I would not use it. Excessive temperature rises in the hour cause food spoilage and hot beer.
AnswerID: 217867
Reply By: Crackles - Friday, Jan 26, 2007 at 08:58
John there are minor savings to be made in power consumption by not cycling the fridge as often but this will ultimately end up with the fridge getting slightly too warm just prior to each time the battery current saver cut in. The fact that the fridges own thermostat is cutting in is telling you things are are warming up inside. Fridges with lesser insulation like the Waeco & Engel that cycle often for short periods would certainly have internal temps getting dangerously high.(warm beer) The one fridge this unit would possible work on is the Autofridge. The makers of these fridges already recomend that they be turned on for 2 hours in the morning & 2 hours in the afternoon then left off for the rest of the day & night. The difference is they have thicker insulation & a Eutectic fluid that holds the temparature steady for far longer. An automatic system like this would at least ensure one didn't forget to turn the fridge back on. From memory Autofridge were suggesting about a 10% saving in power use by turning the fridge on twice a day rather than let it cycle on the thermostat.
75%.....1 amp hour?.........I think they are dreaming :-))
Cheers Craig................
AnswerID: 217871
Reply By: lifeisgood - Friday, Jan 26, 2007 at 09:39
I keep those blue ice packs in the fridge . You can switch the unit off last thing at night and since the thing is kept shut I dont feel there is a problem.
If you have solar cells then you are charging again from sunrise.
Dont know about summer up nth though !
AnswerID: 217877
Reply By: Member No 1- Friday, Jan 26, 2007 at 09:40
a dodgy and misleading claim..."electronic thermostat".....then they go on and say "time cycle" ....
What is it ...a thermostat or electronic timer...the latter I say at about ten times the price it should be
AnswerID: 217878
Reply By: tdf - Friday, Jan 26, 2007 at 09:50
i have one of these units i didnt notice any practycal reduction in power consumption but i didnt measure it scientifically.....if anyone wants to do a proper test i am happy to donate the unit and lets see the results.just leave some details
AnswerID: 217880
Reply By: Alloy c/t - Friday, Jan 26, 2007 at 10:53
Pray tell how any device will save your precious 12v power by switching the fridge fully OFF , the fridge is designed to cycle on/off to maintain a set internal temperature regardless of the external ambient temperature , switching a fridge fully OFF overnight can and in most instances use MORE power due to the internal temp rises even on a "cool" night ,that 2-3 degree rise takes more power than letting the fridge cycle , Do you switch your home fridge off at bedtime every night ?? nah didn't think so.
AnswerID: 217892
Follow Up By: Crackles - Sunday, Jan 28, 2007 at 19:35
A fridge compressor will use far more power starting each time than it will running (for the corrosponding time) so if you can half the number of times the fridge starts & run the compressor a little longer to compensate, in theory there is a small power saving to be made. Inverter air conditioners sort of run on this principle. As I said previously the only problem is risking the temp rise in the fridge going too high (above 4 degree)
FollowupID: 478648
