Chescold into the van?
Submitted: Saturday, Jan 27, 2007 at 14:28
ThreadID: 41665 Views:2919 Replies:5 FollowUps:11
My caravan fridge no longer works and as I already have a large blue 3 way Chescold frig/freezer was wondering if there were any reasons why it could not be mounted into the space where the old frig was.Would have the benefit of using it as a freezer too
Thanks in advance,Cheers,
Mary
"Some people walk in the rain,others just get wet."
Reply By: Motherhen - Saturday, Jan 27, 2007 at 16:37
If it fits, give it a go. Is it a top opening style? We had to replace our (compressor) caravan fridge with a similar one to fit in. My husband would have preferred to put a car style fridge with top opening in as there is no chance of things like freezer or shelves falling down, door swinging open etc (although ours has a good latch the latter was not an issue).
What caused ours to fail, was going on a long corrugated road without deflating tyres, with the little internal freezer packed full. Only one screw secured it at the back and when that broke, the freezer section dropped and severed the gas tube. The replacement model has 2 screws holding the freezer, and we now know to watch them.
AnswerID: 218044
Follow Up By: Member - Mary W (VIC) - Sunday, Jan 28, 2007 at 11:21
Yes motherhen it is the top opening style and can be securely clamped down when in transit.There is enough room for the lid to open for access
FollowupID: 478596
Reply By: Mike Harding - Saturday, Jan 27, 2007 at 16:56
Ensure it has good ventilation (add a computer fan if necessary) and be aware it will flatten a car battery in about 3 hours on 12V if the engine is not running.
I'm a big fan of 3 way fridges - when camped in one spot for a while and running on gas there is nothing to touch them.
Ensure it is _LEVEL_ - but your caravan probably is, usually? :)
Mike Harding
AnswerID: 218049
Follow Up By: pixiemops - Sunday, Jan 28, 2007 at 17:02
Hi Mike
Today in Perth it was very hot and I decided while I was watching the cricket to do another test on the rc1180. I did have it running inside on 240v beforehand.
I took it outside and plugged it in to 240v. Last time I connected it up to gas. Inside the freezer I had 1 packet of sausages ,1 packet of mince and 2 magnum ice-creams.The outside temperature reading on my thermometer was 40.2 degrees and inside was -15.2. All day the inside freezer temperature was between -15 and -17degrees and this was on 240v.
I ate one of the ice-creams and it was perfect. Very happy with the chescold rc1180 even in 40 deg heat . Looking forward to ice-cream while camping now.
regards
FollowupID: 478631
Follow Up By: wazzaaaa - Wednesday, Jan 31, 2007 at 07:28
Yes pixiemops in that circumstance on 240v at home comming from inside the house being already cold in that mild heat may be, but prolonged use on gas out in the elements We found it different, see my post below, I do wish our experence was different, as gas for two weeks from one gas bottle was great.
Wazzaaaa
FollowupID: 479188
Follow Up By: pixiemops - Wednesday, Jan 31, 2007 at 19:03
Wazaa
I did that test on 240v because my experience is that on gas my other finch fridge performs the best. In the bush camping it used to freeze up and that was the fridge model.
If you do some research the general consensus is that they perform the best on gas. followed by 240v then 12v. ( a repairer stated this also). This is because the element get the hottest on gas. Therefore i would expect even better performance on gas. Not arguing with you just stating what I have experienced.
regards
FollowupID: 479292
Reply By: LastAussieWorker - Saturday, Jan 27, 2007 at 19:43
Mary doing that would be illegal in all states and damn dangerous for personal safety. What you want to do could cost you and your family your lives.
Contact your local state gas inspector.
Energy Safe Victoria
They will give you a minimum of 10 excellent reasons not to do what you are thinking off.
AnswerID: 218075
Follow Up By: Mike Harding - Saturday, Jan 27, 2007 at 20:15
No - you're the one pontificating - _you_ give us the reasons?
All too typical of this forum!
Mike Harding
FollowupID: 478534
Follow Up By: wazzaaaa - Sunday, Jan 28, 2007 at 00:32
&Yes be carefull,
besides being dangerious in confined spaces 3 way fridges are only good in winter in colder climates.
FollowupID: 478561
Follow Up By: Member - Mary W (VIC) - Sunday, Jan 28, 2007 at 11:29
As I live in the Mildura area I have found this fridge to be able to cope very well when it's 40c as it often serves as second frig for Christmas etc.Why should this chescold 3 way fridge be dangerous when the existing gas /electric on isn't.?There will be even more ventilation available to this one than the existing one.When it was used in the ute used to turn off 12v when stopped and frig still stayed cold.it's the ability to run on gas when stopped for a few days thats the main reason for using plus saving the expense for getting a new caravan type frig
FollowupID: 478597
Follow Up By: pixiemops - Monday, Jan 29, 2007 at 20:12
Disagree Wazaaaa see my post above . Will never by a compressor fridge/freezer. 3 way suits me fine and works great . I respect that everyone has a camping fridge be that 3 way or compressor that is right for them . What annoys me is posts providing misleading information.
regards
FollowupID: 478871
Follow Up By: Mike Harding - Monday, Jan 29, 2007 at 20:32
Spot on pixiempos.
FollowupID: 478875
Follow Up By: wazzaaaa - Wednesday, Jan 31, 2007 at 06:59
I think the experence we have had with our 3 way fridges is that on gas they are far worse than on 240v in a camping setup under canvas in 40+ deg heat. We did not measure the exact temp. under the tarp, but it would of been high as the forcast temp. was 42deg out side, the point we are making is the engle and waeco fridges coped where as the 3 ways did not. At home it is always miss leading as ours also worked better on 240v in the house or on the patio but out where you really need them in the bush was another thing.
That was four of our group of camping friends experence so am not trying to miss lead anyone one just passing on our experence with them as it cost money to change them.
Wazzaaaa
FollowupID: 479185
Follow Up By: pixiemops - Wednesday, Jan 31, 2007 at 19:38
They perform the best on gas and my test was done in a garage with no air circulation under a hot metal roof.
FollowupID: 479305
Reply By: Motherhen - Sunday, Jan 28, 2007 at 13:10
Mary and others following this thread
I NEVER use a fridge on gas in a caravan anyway (paranoia of mine - and a few stories). I am not familiar with the Chescold, but if you are replacing a 3 way, i presume there is ventilation as required already there.
When my family had a motor van with a gas only fridge, we just used it like an Esky (open at night and shut in the day).
When we bought our previous van, the 3 way didn't work, although the previous owner said he used it on electricity only. We ascertained it was totally defunct, threw it out and bought a 12/240 v Engel caravan fridge to fit in the space. It is excellent. The current caravan had compressor fridge which we have just replaced with the same (Vitrifrigo with remote compressor).
AnswerID: 218171
Reply By: Member - jeff M (SA) - Wednesday, Jan 31, 2007 at 21:29
Hi Mary W
I purchased a Cub Camper a few years ago and it came with a 3 way
Blue Chescold frig/ freezer installed.It works fine it has a vent behind the unit
and a exhaust pipe vent to the outside.
Have never as yet had any safety concerns.
It works fine in most conditions but did struggle in the extreme heat on last trip to Karumba FNQ.
Hope this is some help,IMO I would go for it.
Jeff M. (SA)
AnswerID: 218888
