Garmin Quest Track Demo
Submitted: Saturday, Feb 03, 2007 at 21:24
ThreadID: 41939 Views:2623 Replies:2 FollowUps:5
There would be some of you that wouldn't know the capabilities of the little Garmin Quest GPS when it comes to Track , I have done a little demo on the web, If you have the need to record your every move then this one don't miss much,
Site Link
Doug
Reply By: Bonz (Vic) - Saturday, Feb 03, 2007 at 22:51
Wow top speed of 107 km/h and only 48 times out of 3515 at 100km/h or more...amazing!
AnswerID: 219553
Reply By: Member - Captain (WA) - Sunday, Feb 04, 2007 at 09:36
Hi Doug,
Have you ever found errors in the log? I was checking my return trip from Pemberton on my Garmin GPS V and I have a few readings that are way out of whack.
For example I had a single speed reading of 138 km/hr, yet either side it read 101 km/hr and the time between readings was less than 10 seconds! - and all this while the cruise control was set for 100 km/hr!!! So i decided to check further and my best reading was 209 km/hr yet either side was 76 and 81 km/hr - as well as the leg course changing from 340 to 47 and back to 341 degrees in that time.
1111 29/12/2006 6:59:06 PM 102 m 116 m 0:00:02 209 km/h 47° true S34.51364 E115.99593
As this reading was only for 2 seconds, either I hit a time warp continuum or there is some inaccuracy in the track log. I once thought I could use this log to prove I wasn't speeding, but after seeing this well I would lose my license for 209 km/hr!!!
Anyway, my question is have you seen anomalies like this in your logs or is it simply that my GPS V has an older processor and at times doesn't keep up with all the functions it is doing?
Captain
AnswerID: 219591
Follow Up By: Robin - Sunday, Feb 04, 2007 at 09:51
Most Errors Captain are a result of insufficent antenna field of view and not the device.
Robin Miller
FollowupID: 480162
Follow Up By: Member - Captain (WA) - Sunday, Feb 04, 2007 at 10:02
Hi Robin,
I have a remote antenna mounted on my snorkel and at the time I was travelling on the main road from Northcliffe-Pemberton.
I agree a loss of sat cover would give this type of thing, but I would not expect that to have occurred at this instance . Besides, I never received the GPS warning that I had lost sat cover. And given that I found several anomalies like this, it has certainly cast doubt on my presumption that one could try and use this if caught speeding.
Captain
FollowupID: 480164
Follow Up By: Robin - Sunday, Feb 04, 2007 at 10:29
I have also observed that type of reading without satellite loss indication Captain.
Your snorkel sounds like a good spot. I believe that this however is the main reason and suspect you would have had more when internally mounted.
Never really got to the bottom of these things , but its feasible that radio signal
multi-path reflections can cause them.
I have verified that the "Planar" type of antenna mounted on a flat steel car roof causes less than the helical whip type I more commonly use.
Robin Miller
FollowupID: 480173
Follow Up By: Member - Doug T (W.A) - Wednesday, Feb 07, 2007 at 18:36
Captain
I have read your query and the answers by others , Could be the old GPS your using too GPS V is going back a bit plus they don't have the acurate mapping we have now , I do know that the maximum speed has read way over what Ive done , it seems to acumilate if not zero'd , but No i have not noticed any errors in my logs.
Doug
FollowupID: 481018
Follow Up By: Member - Captain (WA) - Wednesday, Feb 07, 2007 at 18:49
Hi Doug,
I have updated my maps to version 7. Actually, I used the second unlock code of the Nuvi 660 to upgraded my GPS V - a bit of a bonus!
I think it is some form of processing error and given its only 1 or 2 readings in 1,000 I am not too worried.
Captain
FollowupID: 481023
