Moving map
Submitted: Monday, Feb 19, 2007 at 10:41
ThreadID: 42471 Views:2987 Replies:7 FollowUps:8
well finally I have the gps, lap top and ozi now I just need the maps
I assume this is what I need?
Site Link
Hopefully I will get it up and going for thiss week
any tricks to calabrating the maps?, is it straigh forward? I heard you need to convert the maps to a file Ozi will recognize?
I am off to Kalgoorlie tonight so wont get much chance to nut out any problems so any tips would be appreciated
Reply By: SCUBADOO - Monday, Feb 19, 2007 at 11:03
The maps are great.
No need to calibrate.
OziExplorer can do it for you, but it is easier to simply download from:
http://www.gpsoz.com.au/OziExplorer_Users.htm#map
or:
www.oziexplorer3.com/eng/aussie.html
It's all been done before.
Good luck
Neville
NZ
AnswerID: 222638
Follow Up By: Member - Davoe (Nullagine) - Monday, Feb 19, 2007 at 11:18
cheers i will give it a crack
FollowupID: 483489
Reply By: V8Diesel - Monday, Feb 19, 2007 at 12:54
Best thing you'll ever do. All my mates gave me heaps for taking a laptop bush, now they are getting them too. The best navigational tool ever. You can find all sorts of interesting stuff and 'fly by instruments' at night too if need be.
I got a piece of high density foam cut to suit the shape of my centre console. Wrap some of that nonslip lumpy stuff around it and it's going nowhere. For really rough stuff I wrap a couple of those small cloth type straps around it and it stays put through thick and thin and is easy to read too. I have a direct feed to the battery for the 12V adaptors of the laptop and GPS so it runs all the time. Just open the lid.
AnswerID: 222654
Reply By: joc45 - Monday, Feb 19, 2007 at 13:14
Davoe,
Those maps are a good start, but drop me a line;
g e z z a 90 at t p g d o t c o m d o t au
I'm in Perth
Gerry
AnswerID: 222661
Reply By: equinox - Monday, Feb 19, 2007 at 13:47
Hi Davoe,
I just bought the Cd version of that not 20 minutes ago from the map shop. Cost me $99. I intend using them for trip planning and then using them on the new PDA with Oziexplorer CE.
AnswerID: 222665
Follow Up By: Member - Davoe (Nullagine) - Monday, Feb 19, 2007 at 13:56
If it was the one in the city i would have nearly bumped into you - I grapped the DVD version
FollowupID: 483512
Follow Up By: equinox - Monday, Feb 19, 2007 at 15:51
Yep the one on Hay street
FollowupID: 483525
Reply By: garrycol - Monday, Feb 19, 2007 at 14:13
Why not download maps from the GeoScience Aust website - for free after you register - calibration is easy and some formats may not need calibration.
I downloaded my local area around Canberra 1:250,000 a couple of weeks back and it works a treat. If you need lats and longs for the calibration - google earth will provide them.
Just an option tha that works out cheaper but is a bit of mucking around.
Garry
AnswerID: 222672
Reply By: Topcat (WA) - Monday, Feb 19, 2007 at 15:30
Hi Davoe, if you have any paper maps of areas you want to look at & have a scanner, set the scan DPI to 120 & save as a Bitmap @ 24 bit window. Use OziExplorer to calibrate the image by using the co-ordinate positions taken from the paper map. I have done this several times (especially on maps of 100,000:1 & 50,000:1 scale) with great success & very small error(if any) when using with moving map & checking positions with the GPS. Cheers
AnswerID: 222685
Follow Up By: Member - Davoe (Nullagine) - Monday, Feb 19, 2007 at 15:38
thanks I do have a scanner. Looks like I have a bit to learn
FollowupID: 483523
Reply By: fruers - Monday, Feb 19, 2007 at 16:30
Is there any reason why people get Natmap Premium instead of the Hema 4wd raster map collection? I know there is the mosaic which is quite handy on the PC (too big for pda), but for an extra $40 you get Hema 4wd maps for about 13 different regions as well as the 514-map geoscience topos. I have access to both so i will load them up tonight and see if i can find a difference.
AnswerID: 222705
Follow Up By: Member - Davoe (Nullagine) - Monday, Feb 19, 2007 at 16:38
yea i got a Hema map once and it was hopeless
FollowupID: 483533
Follow Up By: equinox - Monday, Feb 19, 2007 at 17:07
Yes - my reason is that Hema, although good for most roads and tracks, are pretty well useless for topography. I didn't know that you got the Natmaps with the Hema pack though.
FollowupID: 483537
Follow Up By: fruers - Tuesday, Feb 20, 2007 at 12:07
The hema maps aren't that bad, they're tourist maps so they include a lot of good information and cover a whole region but are usually at a lower resolution like 1:1M. In relation to what is available in digital mapping they are very good. They provide the geoscience topos anyway so you choose the map you want. I just loaded the maps that come with the hema 4wd pack and they look to be based of the same data as natmap premium (i looked at a couple of areas on the east and west coast). You don't get the mosaic and are poorer quality but it's inconsequential for the purpose of getting somewhere or working out where to go.
I think for the extra $40 you are getting a pretty good deal.
FollowupID: 483718
Follow Up By: fruers - Tuesday, Feb 20, 2007 at 12:16
Also, i realised the difference after i'd bought the natmap premium and the guy was happy to exchange it for me (after i'd copied it) so i have both versions. I've only been using the hema maps and topos on the PDA.
FollowupID: 483724
