Refilling water tanks - Quality
Submitted: Wednesday, Mar 07, 2007 at 14:04
ThreadID: 42990 Views:3288 Replies:12 FollowUps:7
We have a 55 litre water tank in the back of the ute, once it is cleaned out, and put in fresh water, all will be ok.
What methods would be best to top the tank up with water without having a plastic type taste?
one was to buy 10 metres of water quality hose (blue stuff) and connect it direct to taps. Not sure if there are other ways people have overcome the plastic/rubber taste.
Reply By: Moose - Wednesday, Mar 07, 2007 at 14:29
Just use a normal garden hose, but make sure you let the water run thru a bit first. It's the stuff that's been sitting in the hose for a while that tastes funny. Turn tap on and just take a sip from hose now and then and you'll soon know when you can start filling the tank.
AnswerID: 225820
Reply By: Sea-Dog - Wednesday, Mar 07, 2007 at 14:57
Just buy the food quality hose pipe.. mine is white and there is absolutely no plastic taste in the water of my camper... from memory it isn't too expensive either... of course it will cost more than the hose in the back yard but it will only take one load of foul water to make it worth the while though...
You can buy it at most camping stores and I am sure it will be able to be picked up at somewhere like Clark Rubber etc..
AnswerID: 225825
Reply By: Member - John L G - Wednesday, Mar 07, 2007 at 15:34
You can buy 10 metre lengths of specified water grade hose at Bunnings. Found it amongst the other garden hoses when I needed some for the boat and cost around $20 from memory.
AnswerID: 225834
Follow Up By: Member - Phil G (SA) - Wednesday, Mar 07, 2007 at 15:44
John, you just have to be careful to get the Nylex brand blue braided hose. They also stock the smooth blue Pope brand drinking water hose and I found it was pretty bad for plastic taste, and had to chuck it.
FollowupID: 486722
Follow Up By: Im.away - Wednesday, Mar 07, 2007 at 16:02
I'll second what Phil said. I got some of the smooth blue stuff from Bunnings and was using it to fill the camper. Couldn't figure out why the water tasted bad. I flushed the tank with bicarb soda and filled it again. Same thing. Then I ditched the hose and got the proper stuff from a camping place. End of problem.
The thing is, the stuff from Bunnings was sold as "food grade". So you do have to be careful.
FollowupID: 486724
Follow Up By: Member - John L G - Wednesday, Mar 07, 2007 at 16:19
Perhaps I was lucky and picked up the right stuff, because I fitted this about 6 weeks ago and its on the main supply to the galley and is permanently in line.
Still have some left and its blueish-white in colour and reinforced.
Tastes fine and no hint of any taste apart from the crap the water authority puts in our mains.
FollowupID: 486728
Reply By: disco1942 - Wednesday, Mar 07, 2007 at 16:06
Purchasing food grade hose does not guarantee freedom from bad tasting water. It just guarantees freedom from the carcinogenic components that leach out of the hose while the water is standing in it. Some food grade hoses are known to taint the water but not make it dangerous to drink.
I carry food grade hose for connecting the van to town water supplies. However at home I just flush the garden hose out and immediately fill the tank so that I am not using water that has been standing in the hose.
AnswerID: 225839
Reply By: Member - Doug T (W.A) - Wednesday, Mar 07, 2007 at 16:36
Never mind what Moose says, if you use green garden hose it will give a bad taste, unless it is very old and well used, I use a short lenght of the proper drinking water hose and force the back through the tap , but you must have a breather to let the displaced air out, with mine I have the breather at the back under the bed [In a Troopy] and connect a 400mm length so when it is full I don't have a pool of water inside, my tank is a 80lt . " target="EOF" class="lbg">www.dynaplas.com.au/
AnswerID: 225848
Reply By: Gerhardp1 - Wednesday, Mar 07, 2007 at 16:47
In addition to using food grade hose, I use a charcoal filter. You can get the housing for about $30 and the filters pretty much anywhere for $20-$30
The benefit of this is the removal of pretty much all of the (foul tasting) crud in the commercial water supply, and you can fill tanks with safety wherever you are - eg from an outback tap you know nothing about, or even from creeks with a pump.
It also removes dangerous bacteria which are not removed by boiling - some bacteria/bugs or whatever are converted by boiling into even more dangerous substances than pre-boiled.
AnswerID: 225855
Reply By: Member - Norm C (QLD) - Wednesday, Mar 07, 2007 at 16:53
Yep, the food grade hose is the go. Very cheap. I also carry the connectors required to connect to a tap. I roll the hose up pretty tight and put it in a cotton draw string bag with the connectors. My wife just loves making me bags for everything. This keeps it all together and stops dust, insects etc from getting in the hose.
With the connectors, you can fill up whereever you find a tap with decent water.
Norm C
AnswerID: 225857
Reply By: Member - Alastair D (NSW) - Wednesday, Mar 07, 2007 at 17:49
All of the above re hose and taste, but might like to consider getting one of these in line filters:
www.bestwaterfilters.com.au/
If you use the standard clip connectors you can use it very flexibly. Use it between a tap and tank when filling unless you are sure of the water quality. Can use it to recirculate the water in your tank if you have an in line pump - ie pump it out of tank through filter back into tank. Good when it has been sitting and you can't dump and refill.
Also have a cheap bilge pump put in bucket, fill from creek or bore etc and pump through filter. I tend to have several plastic jerry cans so I don't have all water in one tank. Good to have a store of good water and separate stuff for washing etc if not sure of quality.
just my way
alastair
AnswerID: 225871
Reply By: DIO - Wednesday, Mar 07, 2007 at 18:20
Buy a 10 litre container of water, from supermarket, cheapest you can get, once the container is empty use it to top up your tank. Food grade plastic, cheap, disposable and easily replaced. use them all the time. Good way to carry an extra 10 litres too.
AnswerID: 225881
Reply By: camwill69 - Wednesday, Mar 07, 2007 at 19:03
Hi Guys and Girls,
Just read all of the above and wish to advise that their is a difference between "Food Grade- chemical resistant" and "Drinking Water Grade" hose.
You will still get a mild taste (plastic) out of "Food Grade" hose but will not out of "Drinking water" hose.
Never fill out of a garden hose as these hoses are not bacteria resistant where food and drinking water hoses are.
E-coli and salmonella are often found in garden hoses.
Nylex make both hoses.
Regards,
Camwill69
AnswerID: 225897
Follow Up By: kimprado - Wednesday, Mar 07, 2007 at 20:00
Are you guys for real!!!
Kim
FollowupID: 486815
Reply By: Gramps (NSW) - Wednesday, Mar 07, 2007 at 22:25
LOL I just can't believe how sensitive we've become over the years. Spent a whole childhood and a good many years after that drinking regularly from whatever garden hose was available at the time, wherever we happened to be.
We are becoming picky are'nt we :))))))))))))))))))))))))
AnswerID: 225952
Follow Up By: Member - Banjo (WA) - Thursday, Mar 08, 2007 at 01:13
I've got to agree with you Gramps.
I just use the garden hose, whether for a quick drink or to fill the tank.
I think that maybe the marketing people have 'conned' us into thinking that one hose isn't all we need.
Anyway, some have had what they consider bad tasting water from standard hoses so if one of the 'better' types helps them good luck to them.
Banjo (WA)
FollowupID: 486889
Follow Up By: Moose - Thursday, Mar 08, 2007 at 14:33
I'm glad to see a few "normal" people frequent this site. But looks like we are a minority:-)
FollowupID: 486958
Follow Up By: Gramps (NSW) - Thursday, Mar 08, 2007 at 15:39
Normal naaah .... we're just "special" :)))))))
FollowupID: 486967
Reply By: vcbb - Friday, Mar 09, 2007 at 09:58
What experiences are out there in relation to the use of the carbon type filters, do they really take the bad taste etc. out of the water?
Thanks everyone for their replies to this thread, much appreciated
AnswerID: 226300
