Getting into the Bungle Bungles
Submitted: Friday, Mar 09, 2007 at 13:30
red up
I have a 94' Subaru Sportwagon RV.
Think it is also called an L Series
I am going on a long road trip around Australia in it and am under no illusions that it will go anywhere although I am hoping that we can take it into some
places 2wd can't.
It has all standard parts and normal clearance.
Does anybody know if it would get me into the Bungle Bungles in the dry?
A friend of
mine hired a Patrol and drove in but has limited 4wd experience and was not sure if it would be a good idea to take the Subaru in, as it does not have the clearance of a bigger 4wd.
The last thing I want to do is be a burden on some other driver having to tow me out or wreck the car.
What is the best way to find out about 4wd
routes before I attempt them?
Have seen a few on this site, which was very helpful.
Hope you can help.
Cheers.
Reply By: briggzee (WA) - Friday, Mar 09, 2007 at 14:19
red up. We were in the Bungles in late July last year and we saw several "soft roaders" in there. There was even a 2 wheel drive there who was promptly escorted straight back out as it is a 4wd road only. The subaru should be fine but there are a couple of river crossings which might be tricky if they are fairly full. Of course it will depend on how you drive, but if you have experience it should be fine.
226351
Reply By: cowpat - Friday, Mar 09, 2007 at 14:51
The road in is very tame, in my opinion really no need for a 4wd in the dry except that maybe then too many people would go into an already way busy area...I suggest you call the
ranger beforehand just to check all is
Re other
routes: I have always found the rangers to be very helpful. Give the nearest
ranger's office a call. They will have first-hand knowledge about what the roads are like right now. Have a good trip, Casper.
226360
Reply By: Member - Steve T (NT) - Friday, Mar 09, 2007 at 15:07
Hi red up
May I suggest that if this is a once in a lifetime trip, that it would be a great idea to up grade the Subaru to a larger 4wd.
This way you could go nearly every were and not miss out on some of the great
places we have in this great country of ours.
Just my thoughts Steve.
226364
Reply By: MEMBER - Darian (SA) - Friday, Mar 09, 2007 at 16:14
I endorse the bovine comment above - best idea is ring the
ranger first to check - we went in last July - the only
water was about 5m across and about 500mm deep at most, as I recall. Depending on the season and your timing , this depth could vary a lot I guess. The road is very rocky, but there are no real hazards as such - we just lower the tyre pressures and take it real easy on such terrain.
226379
Reply By: Member - Phil G (SA) - Friday, Mar 09, 2007 at 16:42
Haven't done that road, but having owned several of the old Subarus, they amazed me with what they could do, and how strongly they were built.
226387
Reply By: Kumunara (NT) - Friday, Mar 09, 2007 at 16:43
Red Up
Have been to the Bungle Bungles and it is
well worthwhile. It is an easy drive and does not require 4WD. The road had been graded shortly before I went in and was very smooth and easy going.
Others have suggested checking with the
ranger first - excellent advice as road conditions can change.
226389
Reply By: Garbutt - Friday, Mar 09, 2007 at 19:12
We were there last year in June and I don't think you would have any trouble in the Suby. I had a 92 Subvy before the current Hilux and would have been happy as larry to take it into the Bungles. Enjoy.
gb
226419
