High Lift Jacks
Submitted: Wednesday, Mar 14, 2007 at 21:01
ThreadID: 43261 Views:4004 Replies:15 FollowUps:5
Will the people on this forum respond to this question???
Are they dangerous, in everyday ''bog'' situations? Has anyone on this forum had really bad experience's with them? I would never ever own one, but i do know a couple of young fellas, who are going up the gulf and intend on buying one. I once seen Malcom Douglas documentry about the jacks, he jacked the back of the vehicle up and kicked the vehicle with his left foot, the jack almost took him out (and he knew what he was doing) If any person on this forum think that they are safe, i would like to know please. Are they only as safe as the person using them?
Reply By: Member - Rob P (NSW) - Wednesday, Mar 14, 2007 at 21:14
That is correct! Only as safe as the person using them....Take care...
AnswerID: 227504
Reply By: Willem - Wednesday, Mar 14, 2007 at 21:19
High Lift Jacks are safe as the person using them.
If you do stupid things with them they can bite you. If you are careful when using them, they can save the day. Just take your smart pills with you....lol
One night I got my Suzuki's front wheels stuck over a log in a rising creek. The electric winch wouldn't work and I had to do something in a hurry. So I used the Hi Lift Jack to jack the front of the little car up and then push if off the jack. Did this about 10 times in quick time and got out of trouble.
These days I carry a Bottle Jack, a Trolley Jack and a Hi Lift Jack to cover all occasions.
AnswerID: 227507
Follow Up By: hz75 - Wednesday, Mar 14, 2007 at 21:27
Thanks for that imput Willem! But did you mean that your winch didnt work because it was broken, or because the winch couldnt do the job??
FollowupID: 488247
Follow Up By: Willem - Wednesday, Mar 14, 2007 at 21:49
Hahaha. It was a Warn 5000lb. I had rather neglected it (living in the tropics) and water had ingressed into the electrics a corroded some terminals making it unuseable at that moment. It would have done the job had it been working.
FollowupID: 488253
Follow Up By: Member - JohnR (Vic)&Moses - Thursday, Mar 15, 2007 at 18:26
Bro, " a Bottle Jack, a Trolley Jack and a Hi Lift Jack to cover all occasions" I have made the point before that trailer towing 4by owners do that. Just because they have the space.
FollowupID: 488432
Reply By: Crackles - Wednesday, Mar 14, 2007 at 21:31
They are certainly as dangerous as you want to make them but are a tool that is extremely versatile. (bead breaker, winch, clamp, jack, stump puller) Have clobbered myself on the head when the pin didn't locate but that was probably just a reminder to me that it needed cleaning & a bit of lubrication ;-) In tough offroad situations 5 minutes with a High lift jack can often save an hour of winching.
2 hands on the handle at all times, don't put your head over the jack, don't get under a suspended load, use a base plate on soft ground & keep the jack clean. Should work fine then.
Cheers Craig............
AnswerID: 227510
Reply By: Member - Jack - Wednesday, Mar 14, 2007 at 21:35
Chain saws are dangerous ... soldering irons are dangerous ... high lift jacks are dangerous. As everyone else has said, it depends on the user. I carry a high lift and it got me out of a difficult situation near Kalgoorlie when I was seriously bogged and well out of the path of any passing help.
The fact that you can tip them off, when used correctly, is a bonus, as it was for me.
Obviously you would never get underneath a vehicle that was held up by a high lift.
Jack
AnswerID: 227513
Reply By: The Rambler( W.A.) - Wednesday, Mar 14, 2007 at 22:37
As others have said they can be dangerous when used without care but can be the best thing ever when the need arises.Make sure that your vehicle has the proper support brackets for their use as without this you will not only have the chance of personal injury but you will almost certainly damage your vehicle.Make sure the jack is kept clean and well lubricated and ALWAYS make sure the handle is in the down position before moving the up-down lever.
AnswerID: 227529
Reply By: Scrubcat - Wednesday, Mar 14, 2007 at 22:41
One of the handiest tools I have around, I have two, use them for lifting out fence posts, tree stumps, bogged vehicles, straightening bent gates or machinery,use like a tirfor, etc, etc.
Like others have said they are only as safe as the operator. Just as dangerous or as safe as a motor vehicle I reckon. If you consider your vehicle safe or dangerous it`s up to you. One thing I think is essential is to ALWAYS have the handle in the vertical ( closed ) position before changing the direction lever.
Scrubcat.
AnswerID: 227530
Reply By: Footloose - Wednesday, Mar 14, 2007 at 22:42
If you're inexperienced, Hi Lift Jacks can seriously damage you.
They require constant lubrication and cleaning to get the best out of them when needed.
I've used one to break a bead, and to re build a sink hole and get the vehicle out.
Some people find them difficult and hard to carry.
Make sure it's a good quality one and not a cheap bit of you know what.
AnswerID: 227531
Reply By: Hairy - Wednesday, Mar 14, 2007 at 22:47
Gday,
I never go any where without one.
But as everyone has said......In the wrong hands???...Look out!
AnswerID: 227535
Reply By: Member - Phil G (SA) - Wednesday, Mar 14, 2007 at 22:52
To make mine stable, I have dedicated Hilift jacking points on all 4 corners.
Its also the only beadbreaker I take these days. And it backs up the barely adequate 1800kg mechanical jack that comes with the vehicle.
AnswerID: 227539
Reply By: Member - Davoe (Nullagine) - Thursday, Mar 15, 2007 at 08:41
more dangerous if you arnt bogged If you are theings stay put much better. if you have a cruiser then get hub lifters as that increases the safety of them. high lift jacking points are of limited use on a coil sprung vehicle and a standard hight jack.
I have used them fo Boggings and hangups wouldnt remotely entertain the thought of going bush with out one as the last time i did i had to walk 40k
AnswerID: 227598
Reply By: Member - MrBitchi (QLD) - Thursday, Mar 15, 2007 at 08:57
The Rambler says;
"ALWAYS make sure the handle is in the DOWN position before moving the up-down lever."
Scrubcat says;
"ALWAYS have the handle in the VERTICAL ( closed ) position before changing the direction lever."
Who's right?
AnswerID: 227603
Follow Up By: kev.h - Thursday, Mar 15, 2007 at 18:09
The instructions clearly printed on the side of mine says
"ALWAYS have the handle in the VERTICAL ( closed ) position and firmly located in the clip before changing the direction lever."
in the manual there is a clear warning that if the lever is in the down position the handle can fly up violently( with possible serious injury) when changing the up/down lever position
Regards Kev
FollowupID: 488429
Follow Up By: Middle Jeff - Thursday, Mar 15, 2007 at 20:32
Hi I noticed that to, mine is closed when you do anything. The other thing you need is a can of wd40 and spray it like mad before you use it.
Have fun
FollowupID: 488457
Reply By: Steve63 - Thursday, Mar 15, 2007 at 09:49
hz75,
HiLift jacks have lots of uses. They can be dangerous and I wouldn't use it to just change a tyre. But have used mine as a bead breaker and as a hand winch. With care they can be a useful tool.
Steve
AnswerID: 227613
Reply By: Rosco - Qld - Thursday, Mar 15, 2007 at 19:41
Basically what they all said ... great bit of kit, but use with your brain in gear.
AnswerID: 227702
Reply By: Member - Kiwi Kia - Thursday, Mar 15, 2007 at 19:43
I don't reckon they are worth the effort of carrying them just for the 4wding that most people do ie. back country touring. If you are really into the hard yakka then you will find a heap of uses for them. If you don't fully understand what some people are refering to when they say the jacks are dangerous then seek out someone who can show you. Once seen never forgotten !!
AnswerID: 227704
Reply By: ross - Thursday, Mar 15, 2007 at 23:07
I carry one but if your concerned take an exhaust jack. it will do many of the functions of a hilift but not all.
AnswerID: 227759
