LC100 Trailer Fuse
Submitted: Sunday, Apr 01, 2007 at 11:28
ThreadID: 43873 Views:7415 Replies:3 FollowUps:1
Does anyone the purpose of the 30Amp "Trailer" Fuse in the main fuse box of a LC100.
Is it switched with the accessory, or ignition switch? Does it actually go the the genuine trail hitch trailer plug?
I have a Supreme Territory Van with Anderson Plug, which doesnt supply the 12V 3 way fridge. Never tried the 12V in the fridge as I assumed it was wired up to the Anderson plug, however now that I have it (the A plug) wired up, and I did crimp it finally after all the debate on the thread on that issues, and it (the plug) works fine, but the fridge doesnt.
It occurred to me that perhaps the 12V side of the fridge is connected to the normal trailer plug, and if this is prewired with 12V courtesy "Trailer" fuse no further work is required, except fridge draw 200W on 12V, that's nearly 18amps. I my view that is a lot to go through the small 7 pin plugs.
Reply By: disco1942 - Sunday, Apr 01, 2007 at 12:00
If you wish to run your fridge through the trailer plug (and it is the 7 pin flat variety) replace it with the 12 pin one. The extra 5 pins are rated at 30-35 A. If you have other trailers with 7 pin flat plugs they will fit into the 12 pin socket - the sockets are designed to accommodate the smaller plugs.
If you are using the small 7 pin round plugs you will have to change your system for connectors with larger pins - or add a second socket if you do not wish to have to change other trailer plugs. I would keep the fridge system separate from the Anderson system as I like to control the fridge feed from the ignition switch with a relay - saves a lot of flat batteries after forgetting to switch off the fridge when stationary.
AnswerID: 230983
Reply By: Geoff (Newcastle, NSW) - Sunday, Apr 01, 2007 at 14:35
I think you'll find if you pull the trailer fuse that none of your trailer lights will work. At least if you have the genuine Toyota trailer wiring harness fitted.
The 100 Series have a grey plug up under the back that the genuine trailer wiring harness connects into. Then all you do is add that 30 Amp fuse and away go all your trailer lights. (The 70 Series have the plug but none of the rest of the electricals to support it, the 70's require you splice in the trailer harness)
It has nothing to do with supplying 12 volt accessory power to your trailer.
Hope that helps,
Geoff
Geoff,
AnswerID: 230995
Reply By: Go-N-Grey (WA) - Sunday, Apr 01, 2007 at 15:34
Thanks, I have the genuine towbar and harness, and I did find the grey plug you refer to when I fitted the electric brake controller. The trailer plug was also prewired for the electric brake connection complete with blue tinned connection neatly taped to the rest of the harness. That is what I call attention to detail.
Looks like further work to get the fridge going, I have the Anderson plug wired through a relay as I was intending to install an Arid Twin charge in the van, and it comes with a relay and relevant protection diodes.
I guess it is good to know the trailer lights are fused through the main fuse box, and not from the individual light circuits in the LC. I would never have looked there, and certainly know about trailers blowing fuses on the car lighting circuits when towing boats.
The van is fitted with one of the big round 7 pin plugs and I am using an adapter to get it down to the small 7 pin connector on the LC. Here hoping the big connector on the van IS wired separately for the fridge, if so will save a lot of work.
AnswerID: 231007
Follow Up By: Geoff (Newcastle, NSW) - Sunday, Apr 01, 2007 at 20:17
Yep, the trailer wiring in the 100 Series is very well done. The only thing that disappoints me is Toyota didn't finish the job in my 78 Series Troopy.
Glad we where able to answer the question,
Geoff
Geoff,
FollowupID: 491964
