Dyno tune
Submitted: Sunday, Apr 01, 2007 at 21:23
ThreadID: 43896 Views:2484 Replies:3 FollowUps:4
Just thinking about taking my 100 series to get dyno tuned, it has an turbo and have had problems with getting hot. I was wondering how good the dynotuning works and would love to hear all good and bad stories from other members/visitors.
Crawf
Reply By: Member - Bucky (VIC) - Monday, Apr 02, 2007 at 06:23
How hot is hot ? Some vehicles run hotter than others
What is the EGT ? My Navara runs at 590c a little on the high side but acceptable according to Dyno Tune @ 100 k speedo ( thats after the turbo )
Does it have Turbo Lag ? I did have a bad case of it from new, and the local Nissan agent refused to believe me, or do anything about it, so I took my business elsewhere, and had it fixed @ 20 k on the speedo. Never have been back to that agent. I have a great mechanic, and went back to him, and is about 1/4 the price of the Nissan agent ,, and is more thorough..
Do you just switch it off after a hard drive ?,,naturally you have to let the turbo cool down, I do not like the idea of all that heat under the bonnet, and not to mention that the turbo is still spinning, so it needs motor oil for lubrication. A turbo timer will help there, if not a 2-3 munite wait before shutdown.
These are some of the questions that you need to ask yourself, ?
Yes a good Dyno tune may fix all, and with a bit of luck get your LC 100 up and running real good
Cheers mate
Bucky
AnswerID: 231141
Follow Up By: fishaholic - Monday, Apr 02, 2007 at 20:59
Dont know what my EGT is, but I imagine HOT, the car gets very hot, not just a bit like your suggesting. I have an intercooler which is in front of the radiator which i dont like much, but i still dont turn the car off for atleast 5 minutes after a long run. I hope the dyno idea works, cause i've spent alot of time and money trying other things to stop it getting hot. Thanks again for your advice.
Crawf
FollowupID: 492213
Reply By: Member -Signman - Monday, Apr 02, 2007 at 09:21
Had the Troopy dynotuned last week- and very impressed with the results. But like anything- it's not how good the machine is- it's how good the operator can read and diagnose the results !!!
AnswerID: 231172
Follow Up By: fishaholic - Monday, Apr 02, 2007 at 21:01
Cheers for that, I hope im impressed to, did you do the dyno test for a specific reason, or just to get a bit more power or something?
Crawf
FollowupID: 492214
Follow Up By: Member - Bucky (VIC) - Tuesday, Apr 03, 2007 at 04:22
Thats very true Signman,
Cheers Bucky
FollowupID: 492241
Follow Up By: Member -Signman - Tuesday, Apr 03, 2007 at 10:16
G'day fishy
The dyno analysis is just part of the diesel shop's tune up procedure. Sure, a good tuner can pick up performance on a road test- but I think a dyno can put the engine under various loads and readings can be gathered for optimum performance (& economy & reliability). Things like injector nozzles are checked on another bench, but fuel pump efficiency & turbo operation can be adjusted more precisely with the operator monitoring the readouts.
Also, it's handy to have a reading before & after just to see what differences can be achieved.
Let me know how it goes !!!
FollowupID: 492315
Reply By: fishaholic - Wednesday, Apr 04, 2007 at 07:41
yeah cheers for the response, some very good advice there, will let you know the results, probably won't be heding to Adelaide for a couple of weeks tho, got too much fishing to do first.
Crawf
AnswerID: 231583
