A Diff Housing as a Trailer Axle
Submitted: Friday, Apr 27, 2007 at 17:02
ThreadID: 44798 Views:7506 Replies:9 FollowUps:8
Has anyone made a trailer axle out of a Diff housing?
Due to a spot of luck last year, I obtained a 2000 model troopy wreck for $ 500 and now have a surplus of parts.
I have a rear diff housing, I'm thinking of making a axle for the C/T I'm going to make, I have been told That it would not be strong enough, unless the axle's were joined through the middle.
Any ideas would be appreciated.
Cheers Steve.
Reply By: Wayne (NSW) - Friday, Apr 27, 2007 at 17:26
Steve,
The axle will not make the diff housing any stronger as they are fully floating. They can be removed completely and the wheels will still turn because of the stub axle on the ends of the diff housing.The hub and wheel bearings fit on the stub axle. The axle is only there to drive the back wheels.
You would have to plug the ends of the diff housing where the axle has been removed. Cutting the axle off and just using the plate with the tapered holes would do.
The diff centre and pinion gear would also have to be removed as they are no longer required. The end of the diff would have to be sealed where the uni joint is.
I have seen this set up before, plus you have the brakes already set up on the trailer.
Wayne
AnswerID: 236219
Follow Up By: Wayne (NSW) - Friday, Apr 27, 2007 at 17:29
Steve,
You would also have the shocks set up as well.
Wayne
FollowupID: 497324
Follow Up By: Steve from Top End Explorer Tours - Friday, Apr 27, 2007 at 18:17
Hi Wayne
Yeah the diff centre has already been removed and rebuilt, its sitting on my work bench as a spare.
The have the axle ends courtesy of other incidents, and can have a plate made for the housing made easy, it's just one engineering mob said the housing wouldn't be strong enough on it's own, I just had doubt's on that info.
Thought I'd try here.
Cheers Steve.
FollowupID: 497337
Follow Up By: Ken - Friday, Apr 27, 2007 at 21:35
Steve I think the engineering mob you are talking to about this sound pretty hopeless. As Wayne points out the axles add no strength to the system. I'd reckon the cruiser rear axle capacity would be adequate for a camper. The way to be sure is check the max rear wheel load spec from this model Toyota
Ken
FollowupID: 497376
Reply By: Member - Duncs - Friday, Apr 27, 2007 at 18:52
This is as much a question as an answer.
Wouldn't the axle housing be much heavier than you would want for an axle? I would like to minimise the weight of any trailer.
Other than that I have always thought they would make good axles. I have seen a few used for this purpose. But not off road.
Duncs
AnswerID: 236235
Reply By: hoyks - Friday, Apr 27, 2007 at 19:24
I’ve seen it on old farm trailers. As for load carrying, if it carried a troupie around, it should work being a trailer. As for the extra weight of the axle on a trailer and the mechanical loss due to moving parts, I don’t know if it would be worth the effort, and you also have the diff pumpkin to get hung up on things. So in this case I think the benefit (it was cheap) is out weighed by the problems in this one.
I knew a guy that was going to hook up an electric motor to a live axle on a trailer to help maneuvering it around as well as supply some extra drive when in slippery situations. Landrover had a setup on some of their trailers that were run off a PTO shaft that worked, so I think he was hoping for something similar. At work we have generator carts that have their own electric drive, but I think it all became too hard for him.
AnswerID: 236243
Follow Up By: Wayne (NSW) - Friday, Apr 27, 2007 at 19:38
hoyks,
There would not be any moving parts in the diff housing except for the bearings which you would have to have in any case.
The weight of the diff housing would be heaver than a trailer axle but it would be low and unsprung weight.
Wayne
FollowupID: 497347
Follow Up By: Steve from Top End Explorer Tours - Friday, Apr 27, 2007 at 20:47
Hey Guy's
The idea of this C/T is to be solid, using the housing was to make the running gear standard.
Thanks for your input i will wait to see if anyone else has some ideas.
Cheers Steve.
FollowupID: 497363
Follow Up By: Stu050 - Friday, Apr 27, 2007 at 21:08
What is wrong with L/C hubs and electric brakes on a heavy-duty axle?
Best of both worlds then.
FollowupID: 497370
Follow Up By: Steve from Top End Explorer Tours - Friday, Apr 27, 2007 at 21:39
Hey Stu050
The diff housing cost nothing it's just sitting in the work shed, a 2 tonne axle on the other hand is about $700.
Cheers Steve.
FollowupID: 497377
Follow Up By: Stu050 - Friday, Apr 27, 2007 at 22:38
I don't think you can use diffs as trailer axles any more anyway..at least in QLD.
Might pay to check with DoT.
FollowupID: 497390
Reply By: Member - Olcoolone (SA) - Friday, Apr 27, 2007 at 21:43
You don't want to join them in the middle and make them locked.........you will keep on going around in circles...LOL.
If you join them in the middle it will have no impact on the weight carry factor, what it might do is make it unstable around corners as one wheel is trying to spin faster the the other and try to steer straight.
Whats wrong with the standard trailer axle.
Regards Richard
AnswerID: 236288
Reply By: disco driver - Friday, Apr 27, 2007 at 22:12
Hi Steve,
Not trying to be a wet blanket, but have you spoken to the licencing authorities in your area (if applicable).
It may well be illegal these days.
Many years ago when I had a Landrover Series 2, I built a trailer using the Landy hubs. They were fitted to a made up 3" Hollow axle with flanges to suit the hubs welded on. The hub/axle ends were then bolted to these flanges with HT bolts.
As it was being fitted to an already licenced trailer I omitted to have any certification carried out. (Carried spare axles in the hollow tube).
Worked well for many years but eventually I was stopped for another traffic matter and Mr Plod got quite animated about it (words like Bl**dy illegal, rusty chassis, and Fines encouraged me to retire the old trailer from road use).
Made a damn good firefighting trailer for the farm though.
Disco.
AnswerID: 236297
Reply By: Member - Phil G (SA) - Friday, Apr 27, 2007 at 22:29
Steve,
I have the same rear axle on my 2002 79series.
Rear axle can take 2300kg according to the sticker on the door.
AnswerID: 236305
Reply By: Dion - Friday, Apr 27, 2007 at 22:48
I know of a few single axle road train dollies that have been made from truck diffs. They still get around north of Port Augusta.
They have had the diff removed from the pumkin, and a blanking plate bolted on.
Dion.
AnswerID: 236316
Reply By: Member - Pesty (SA) - Saturday, Apr 28, 2007 at 09:07
Hi Steve
Have thought about this myself as I too have a couple lying around, and yes it would be stonger than a 45mm trailer axle, and it comes with brakes that match up and also it will have the same track.
I dont think it would be all that much heavier either.
The reason I was thinking about it was I wanted an extra axle under my 45 series spray unit and thought this would be perfect for this job.
A mate had a professional job done with heavy brgs and because of the twisting couldnt keep brgs in it.
You also have the same brgs as the car so carrying spares is easier.
As for the legalities, I cannot see that it isnt already rated, as Phil points out, hell I have been overloading my 45 series spray unit , up to 2 ton for 15 years, on a single axle the same as this, and only replaced the brgs a coupla years ago,and that was due to water induction causing rust.
I have a camper top laying here, and need to make a trailer to put it on for the family to use, and will probably make it out of one of these axles.
Go for it mate, the worst that can happen is that it will get a defect sticker, and then you may have to change it.
It wont break.
Cheers Pesty
AnswerID: 236351
Reply By: Hairy - Saturday, Apr 28, 2007 at 11:44
Gday,
Anything is possible, just sounds like a lot of extra weight for no real advantage, also reduces your clearence have an extra diff centre to manouvre around rocks etc.
If using it is you best practical option I would removing the diff housing itself and replacing it with a bit of hollow bar or maybe two bits of chanel toe to toe, just use from hub to the shocker mount and scrap the middle section.
Good luck
AnswerID: 236384
