Prado Diffs
Submitted: Wednesday, May 02, 2007 at 12:46
ThreadID: 45007 Views:3874 Replies:7 FollowUps:0
Hi all,
I've just read a comment on one of the post that states the Prado 120 rear diffs are prone to "blowing up".
Is this likely to happen under normal highway driving and sometimes towing a 1500kg boat, or more likely to happen sand driving on somewhere like Fraser or flogging it in 4w4 over rough ground?
Is it going to be covered under warranty if it does happen whilst driving in these conditions?
cheers,
Dobbo60
Reply By: Member - Tour Boy- Wednesday, May 02, 2007 at 13:59
I've heard of V6 hiluxes blowing rear diffs but I've not heard of any playdoe's doing it. maybe the constant 4wd shares the load enough.
My FIL has a 120 series and to date no dramas (V6 100,000km)
TB
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 237401
Reply By: Robnicko - Wednesday, May 02, 2007 at 15:35
Dobbo ,
I think it should be covered under warranty if it were to happen however I think you would have to be very unlucky to break one, but if it did break make sure you are on a marked track and not 'off road' as it could be a legal technicality.
It's like the old theory of Landcruiser diffs being weak. I have never had a problem with mine and when you see people break them on show like 4wdtv it's no wonder because they are jumping wheels off the ground with lots of speed in the wheel and when it comes down to earth something may give.
If you look after it, it will be fine.
Rob
AnswerID: 237423
Reply By: Steve from Top End Explorer Tours - Wednesday, May 02, 2007 at 15:47
Hey DOBBO60
IMOA if you drive it like you stole it, somethings got to give.
I firmly believe that most of these problems are driver related.
Cheers Steve.
AnswerID: 237426
Reply By: lc_120man - Wednesday, May 02, 2007 at 16:20
It is very unlikelly to happen with normal driving... There was a few cases, which were covered under warranty because it was out mechanical specs...
Mine does 85K over all types of Sand/Rought Terrain/Rocky tracks without any
problems...
AnswerID: 237430
Reply By: Member - Davoe (Nullagine) - Wednesday, May 02, 2007 at 18:17
My sister and BIL did theres doing a fairly innocous hill climb as i understand - was covered under warranty.
AnswerID: 237460
Reply By: SA_Patrol - Wednesday, May 02, 2007 at 22:52
Toyota diffs are cut differently to Patrols. Never do a reverse recovery in a Prado, you could blow the diff
AnswerID: 237568
Reply By: Member - MrBitchi (QLD) - Thursday, May 03, 2007 at 08:22
Think the one you refer too is on a previous thread from Ian S about one he came across in the Simpson. First one I've heard of...
AnswerID: 237602
