Laptop housing while using external touchscreen
Submitted: Friday, May 04, 2007 at 08:53
ThreadID: 45078 Views:3060 Replies:9 FollowUps:21
Where/how do you house your laptop when you've got a touchscreen floating around the dashboard?
Not sure if this is a common setup, but I like the larger screen (larger than PDA) as it shows much more map, but don't want to mount a cumbersome laptop at dash level.
Have got an 8" touchscreen and have the mounting for that presently sorted. But what the hell can I do with the laptop? Fortunately I've not tried to run it all with lots of people in the vehicle (dual cab). It needs to be somewhere it can be accessed to turn on, but that's about it. Don't want it to heat up too much.
There's not really enough room under the seats.
Does anyone have any creative ideas?
Reply By: Transient - Friday, May 04, 2007 at 09:15
Get a laptop bag with a shoulder strap and put the strap around your headrest and let the laptop hang down behind the seat your are sitting on. Then all the cables can come around to the touchscreen.
AnswerID: 237834
Reply By: Blaze - Friday, May 04, 2007 at 09:22
Hi John,
I have setup quite a few of these units in vehicles. In wagons we usually make a small box (timber or Ali) and put it just behind the rear seats. In my old dual cab I bought an Ali brief case that fitted under the passenger seat and had the laptop in this.
Of course you will have to make an entry hole into whatever you put it in for all the leads and some sort of exhaust fan setup. We have used 80mm 12 volt fans for ours (the same as is in the power supplies of a standard PC)
Hope this helps if you need any further info or parts just msg me.
AnswerID: 237836
Follow Up By: John R (SA) - Friday, May 04, 2007 at 09:46
Hi Blaze,
Is it possible to get a fan which runs off a usb port?
I've tried putting it in the bag before, as suggested by Transient, but it gets rather warm.
FollowupID: 498941
Follow Up By: Blaze - Friday, May 04, 2007 at 13:02
Yep fans from USB ports are fine for fans, we actually have in a stock a cooling base for Laptops with 3 fans in it that runs from USB
FollowupID: 498972
Reply By: SA_Patrol - Friday, May 04, 2007 at 09:37
Hi John, what make is your screen, and do you have trouble looking at it when driving around during the day time.
Cheers SA_Patrol
AnswerID: 237839
Follow Up By: John R (SA) - Friday, May 04, 2007 at 09:52
Make & model unknown - dodgey cheap arse ebay job, ex hong kong for memory. I'll have a dig and see if I can find the invoice, but it was a little while ago.
It works quite well during the day. Quite easy to see, though it's worth keeping the screen clean so the sun doesn't catch too much dust.
The only issue I've had (and it seems to have stopped lately) was with the power lead. Not sure if it was the cigarette lighter end or the screen end but it would drop out momentarily and flick on again.
Gave it a hammering in the scrub on the weekend and it seems happy now!
FollowupID: 498942
Follow Up By: John R (SA) - Friday, May 04, 2007 at 18:28
Very similar to this one SA_Patrol; Site Link
Though I don't recall spending that much money on it. Mine's only 7". Sometimes I feel very inadequate.
FollowupID: 499025
Follow Up By: SA_Patrol - Friday, May 04, 2007 at 20:21
It's not the size but the way you use it. Hang on are we talking about the same tihng here :-) . I'm not sure about the one's with TV. Do you watch tele with yours.
FollowupID: 499051
Follow Up By: John R (SA) - Saturday, May 05, 2007 at 10:22
Used the right way, it can indeed be very satisfying.
I haven't used the tv, though it does have the ability. It's just a matter of me figuring out the right wiring (didn't get an adaptor, and the socket looks like a PS2 or S video) and giving it a crack. Though why I'd bother I'm not sure - more inclined to watch a movie than the crud that's on commercial tv.
Oh, and one of those $30 belkin transmitters which plugs into an earphone jack allows me to get sound from the laptop into the vehicle stereo. Surround sound at the movies indeed!
FollowupID: 499158
Reply By: Member - Kingsley N (SA) - Friday, May 04, 2007 at 10:33
I am interested in the experience of people running laptops as moving map displays while on corrugations etc. I have stuck with a PDA (a bit hard to see sometimes but good enough when approaching an intersection or way point) preloaded with OziExplorer routes, waypoints etc.
It is preferable to keep your head up and navigate I reckon. Wheel tracks are easier to follow than lines on maps. Follow your progress on your paper map and only use the GPS as a back up.
The PDA is a solid state device and provided you have sufficient maps on SD cards and you have a direct connection to a GPS receiver, it is pretty well bullet proof as far as corrugations go. I bet there are plenty of Laptop hard drives that have come to grief due to harsh operating conditions.
The perfect set up in my mind would be one of the new GPS mapping displays from Garmin or Magellan, provided the device can be loaded with good offroad digital maps. You could still use a laptop for trip planning but only when stationary. It would also be good with a wireless internet connection on NextG. That plus a Satphone and you are home and hosed (provided you don't suffer battery failures!)
Kingo
AnswerID: 237844
Follow Up By: Member - Troll 81 (QLD) - Friday, May 04, 2007 at 11:35
Kingo
I run a touch screen that slides out of the top DINN slot and makes my life allot easier for navigating for sure
FollowupID: 498957
Follow Up By: Member - Oldplodder (QLD) - Friday, May 04, 2007 at 17:15
I do the same Kingsley with a PDA.
Also, using a map for the main reference means I know where I am if the PDA (or whatever) should go down.
FollowupID: 499010
Reply By: DIO - Friday, May 04, 2007 at 10:40
John R (SA) you purchased a touch screen, 'make & model unknown - dodgey cheap arse ebay job, ex hong kong'. So what, your choice, why 'bag it and where you purchased it from' ! Bet plenty of others have made very satisfactory purchases off e-bay that have shipped out of Hong Kong.
AnswerID: 237846
Follow Up By: Russ n Sue - Friday, May 04, 2007 at 11:50
Huh???
FollowupID: 498960
Follow Up By: John R (SA) - Friday, May 04, 2007 at 13:39
I'm not sure what makes you think I'm unhappy or bagging it DIO.
FollowupID: 498981
Follow Up By: Member - Willie , Epping .Syd. - Friday, May 04, 2007 at 22:52
Double Huh ?
FollowupID: 499112
Reply By: Member - Troll 81 (QLD) - Friday, May 04, 2007 at 10:51
My laptop is under the drivers seat and it works a charm for me. I have a USB hub on the side of the center console so that I can plug things into. I had to remove the aircon vent under the seat so that I could sit it in there properly
AnswerID: 237849
Follow Up By: Member - Duncs - Friday, May 04, 2007 at 11:55
Troll,
I don't know if you have the passenger airbag or not.
Have you considered using the empty space which the airbag would go in if you had it.
I know there is a "glove box" kit available to fit in that space. I considered putting a draw in behind there. My thinking was that I could fit the Laptop to it and slide it out when I needed it. Front seat passenger would then have the laptop on a desk just where it was wanted.
Duncs
FollowupID: 498962
Follow Up By: Member - Troll 81 (QLD) - Friday, May 04, 2007 at 11:58
Hey Duncs
I don't have the passenger airbag and have thought of that idea but in the end it was just all to hard for me...and from looking at the picures I don't think it will be deep enough to fit a laptop in there
FollowupID: 498963
Follow Up By: Member - Duncs - Friday, May 04, 2007 at 13:23
I had a pretty good look around in there and I reckon there would be plenty of depth for a closed laptop. There is a structural member in there which the aftermarket glove box is designed to fit in front of. However, if you put the draw on a slight angle, down at the front, I think it would slide above this bar.
The thing that concerned me was the width of the allowable opening. I think my laptop was just too wide by only a couple of mm but too wide is too wide.
I was a bit scared of cutting holes in my dash if it was not going to work.
Duncs
FollowupID: 498975
Follow Up By: Member - Troll 81 (QLD) - Friday, May 04, 2007 at 13:33
Yea that's why I have not done anything I am scared that I will stuff it up
FollowupID: 498979
Reply By: festy - Friday, May 04, 2007 at 12:43
Mine is mounted to the front of my cargo barrier, behind the rear seats.
It's in a docking station, which has a momentary switch connected to the docking station's power switch so I can start/stop it from the driver's seat.
AnswerID: 237859
Reply By: Member - Phil G (SA) - Friday, May 04, 2007 at 16:11
Not sure whether you have enough room between the front seats, but in the Prado, I mounted the laptop on a pedestal - simply attached to it with velcro.
AnswerID: 237893
Follow Up By: Member - John (Vic) - Saturday, May 05, 2007 at 00:36
No picture Phil??
FollowupID: 499123
Follow Up By: Member - Phil G (SA) - Saturday, May 05, 2007 at 08:04
It shows up on mine - the link is in Yahoo and I'm guessing it's locking others out. Heres the picture
!MPG:32!
FollowupID: 499138
Follow Up By: SA_Patrol - Saturday, May 05, 2007 at 08:43
I can see it too, are you using the laptop as your reversing screen :-)
FollowupID: 499145
Follow Up By: Member - Phil G (SA) - Saturday, May 05, 2007 at 10:22
Nah, I've got eyes in the back of my head :-))
FollowupID: 499157
Reply By: Member - Straps (SA) - Friday, May 04, 2007 at 17:22
Forgive me for asking a silly question, but if the laptops are closed on behind you, what are you looking at..??? Do you have a monitor slaving / feeding from you PC into the front driver compartment.???
I have been toying with trying to ring up a stand to support a laptop in the front to allow me to use mapping / mobile mapping etc. (Any ideas on this would be appreciated)
However, I am more intrigued if there is a way to use the laptop without having being cumbersome in the front..???
Shane
AnswerID: 237912
Follow Up By: Member - Straps (SA) - Friday, May 04, 2007 at 17:25
Is something like this what others are talking about..???
Site Link
Looks like I will have to read how to insert hyperlinks... Sorry
FollowupID: 499013
Follow Up By: John R (SA) - Friday, May 04, 2007 at 18:22
G'day Straps,
I have the laptop tucked out of the way & a slave monitor in the front. The monitor is a touch screen so the computer can still be controled by without pulling it out.
The monitor is more like this: Site Link
In an old Prado I had the laptop mounted at dash height - it was easy to knock something using the jesus bar for support primarily. However I don't really like the bulk of a relatively unsecured item in that area, even when it was strapped down well (added to seeing the aftermath of some vehicle accidents = I want as little as possible between me and the windscreen or airbag). I also found very little need to use the keyboard while traveling.
I've made up a mount which stradles the centre console to hold the slave monitor (similar to the one in the link above). It's basic at present, but I tend to knock something up, try it for a while then wander back to the workshop when I think of an improvement.
FollowupID: 499024
