Draining Prado Fuel Tanks
Submitted: Friday, May 11, 2007 at 20:08
Member - Trevor
Hello Everyone who wants a good laugh at my expense.
With my brain in neutral gear this afternoon I managed (with no trouble at all) to put 114 litres of unleaded into my diesel Prado. I have drained the sub
tank but am lost with the main
tank and how to drain it. I have taken the
tank shields off and on the main
tank there appears to be no drainage plug. I can see two rubber looking "things" in the bottom of the
tank but can not see a way to easily remove them to see if there is a plug behind.
Any advice on how to proceed to get rid of the petrol will be appreciated.
Cheers, Trev
Reply By: GerryP - Friday, May 11, 2007 at 20:19
Trevor, don't feel bad mate - I've done it twice already. First time I realised after topping up with 10 litres in the main
tank. Drove home on the sub
tank, but eventually worked up the courage to simply run it on the mixture with no ill effects at all.
Second time I filled up the whole main
tank and put some 15 litres in the sub
tank before I realised. I then topped up the sub
tank (185 litre) with diesel and drove home on the resultant mixture.
Providing you don't go more than about 10% ulp in the mix, I am told it won't hurt. Not that I would do it deliberately mind you.
Don't know about you mate, but maybe it's got something to do with getting older? :)
Gerry
239360
Follow Up By: Member - Trevor - Friday, May 11, 2007 at 20:48
Hello GerryP - The main
tank was about 1/4 full so the mixture is pretty strong. I just can't believe there is no drainage for the main
tank. It has to be there somewhere. Cheers, Trev
PS Getting older could be the problem. Walking into a room and saying "what am I here for" is a problem
500377
Follow Up By: Blaze - Friday, May 11, 2007 at 21:04
Hi Trevor with a mate having
water possibly in his
fuel system of his Nissan he took it to the dealer and home made cupboards had to be removed so diesel could be pumped out from the top and the
tank wiped out. Seems manufacturers don't believe these vehicles will ever need the
fuel tanks drained..
500382
Follow Up By: D-Jack - Saturday, May 12, 2007 at 02:20
The other day I went to fill up only for the 2nd time with my new LPG injection. Filled up with LPG, then went into the store to tell the console operator that I wasn't driving off, I was just moving to go and get some diesel. Drove to the diesel pump area, took the nozzle off the hook, wouldn't squirt any diesel. By about 20 seconds I was getting really sick and tired of waiting for the operator to activate my pump, then he runs out and tells me that I'm trying to put unleaded in my diesel
tank! Do you think I was thankful firstly I had told him what I was doing and secondly that he was switched on enough to know what I was doing wrong! In my defence, there are three pumps together in a completely separate part of the station, one is large nozzle diesel, the other small nozzle diesel, the other ULP! I assumed they were all diesel!
D-Jack
p.s.good luck working out how to drain the
tank
500443
Follow Up By: Blaze - Sunday, May 13, 2007 at 20:57
D-Jack, it sounds scary to me if a Diesel/LPG vehicle with ULP. I am hoping that it wouldn't run if it had been filled like this. I can only imagine the vehicle starting on what was left in the pump and then getting a gut full of ULP/LPG mix Hmmmmmmm.
500772
Reply By: Stu050 - Friday, May 11, 2007 at 21:05
Can you get a hose into the filler to siphon or pump out the petrol?
does the workshop manual indicate a drain bung on the main
tank?
A phone call to toyota may help.
239382
Reply By: Member - Doug67 (NSW) - Friday, May 11, 2007 at 21:15
I have the current model Hilux and did the same, full
tank load, towed it home without starting the motor.
Mine was a
tank out job, I used the chance to put in a long range
tank not that the Parado needs one of those. What happens when your in the outback and get a bad batch of diesel with no drain plug. You'll have no luck siphoning either, I would say get the
tools out and start removing.
239392
Follow Up By: Graham & Lynne - Friday, May 11, 2007 at 21:33
How I do it as I work @ a service station & have 2 customers a month with your problem use a 12volt electric
fuel pump & connect it to
fuel supply line at
fuel filter
a just pump
fuel out.
Other option take
fuel line off at
fuel filter and pressurise
fuel tank with compressed air it is a bit slower but cost less.
from graham
500390
Follow Up By: Member - Trevor - Friday, May 11, 2007 at 21:57
Hello Graham & Lynne - Thank you for your advice. I'll give the compressed air a go as time is not a problem. I still can't believe there is there is no drain plug. Trev
500403
Reply By: Member - Royce- Friday, May 11, 2007 at 21:53
Did the same with my wife's hilux. Had to use a hose to syphon out. Got 50litres left of the diesel
fuel mix. Slowly adding it here and there to various vehicles. A few 100 mls at a time.... not going to waste it!!
239408
Reply By: nowimnumberone - Friday, May 11, 2007 at 23:33
i havnt had to fill a diesel for years but i do remember when you pull the hose out there used to be a lever you had to push before it starts pumping.
have they got rid of that idea and if not how do you fill a diesel
tank after
tank and push the lever time and time again and then not notice it when you put in unleaded?
lol
239445
Reply By: TassieDave - Saturday, May 12, 2007 at 07:52
The workshop manual for my 2001 prado show a drain for the main
tank about 4 inches to the side with no need to take the guard off. You don't say which model prado you have, if its the same latter on when it warms up I'll have a look on
mine.
Dave
239478
Follow Up By: TassieDave - Saturday, May 12, 2007 at 10:13
Just had a look at
mine, has a drain plug on the drivers side just like the workshop manual said. There are 3 cutout's in the cover the drain is in the one closest to the side.
Dave
500477
Follow Up By: Member - Trevor - Saturday, May 12, 2007 at 13:22
Hello Tassie Dave - My Prado is a 2006. I've had another look and there are no drain plugs. Cheers, Trev
500511
Reply By: Footloose - Saturday, May 12, 2007 at 09:46
Trevor, it's a lot more common than you think ! I've done it before, and my wife once put diesel into her Corona. Couldnt work out why it was blowing smoke and the consumption was crazy, until I smelled the
fuel.
Easy to do, especially if its an unfamiliar
fuel station.
239501
Reply By: LCRUZA (VIC) - Sunday, May 13, 2007 at 12:04
We did the CSR in 2005 and ended up with 10Lt of
water in a Prado
fuel tanks from a jerry can.
We ended up drilling a hole in the main
tank to empty it.
Good luck.
Ron
239693
Follow Up By: Member - Trevor - Tuesday, May 15, 2007 at 22:49
Hello LCruza - The thought did cross my mind!!!!!! The drill was close by. I suppose I could get a plug fitted? Cheers, Trev
501217
Follow Up By: LCRUZA (VIC) - Wednesday, May 16, 2007 at 11:30
We used a 2 part epoxy to plug the hole which was OK but it weeped a little. I think in the end a new
tank was fitted when he got home.
Ron
501279
