utm numbers
Submitted: Tuesday, May 15, 2007 at 13:37
ThreadID: 45505 Views:2299 Replies:3 FollowUps:0
hi all, I'm having success using my gps to give my location in UTM numbers and I can locate my position on the map. But I don't understand why sometimes I have to leave off the first one or two digits to get it all to work. Do different maps in different areas change things? Any ideas ...I don't want to rely too much on this thing until I've ironed out all the bugs!
thanks
Tony
Reply By: Robin - Tuesday, May 15, 2007 at 13:46
Hi Tony
Your off to a good start
The format of UTM numbers is that there are two ,
1st gives meters in an easterly direction and the other gives meters in a northerly direction.
Each number is 7 digits long but sometimes people leave of the leading zero's which makes things confusing. Even seen some leave off last couple and hence just give position to nearest 100meters - very confusing.
To complete a "UTM number" it also has a sort of area code which is two numbers and a digit e.g. 55H in victoria
Robin Miller
AnswerID: 240131
Reply By: The Explorer - Tuesday, May 15, 2007 at 15:32
Hello - typically on your average topo map the full UTM coords are only shown in one corner (eg bottom left on the 50K topo series) ...it appears to be a space issue more than anything else i.e. to keep the map edge uncluttered. Its up to the user to identify what abreviations are being used if they wish to identify a point fully using UTM coords.
I am not sure if there is a standard but on the 50K (for example) maps I have the Northing has the first two digits and last three digits left off (except at points where the first two numbers change in which case they are shown). The eastings are shown with the first digit and the last three digits omitted (except at points where the first number changes in which case it is shown).
Once you get your head around it it is easy to use - always start reading your coords from the corner containing the full UTM numbers and work along the grid to the point you want. The numbers being omitted will then be obvious. A pencil and paper come in handy.
Robins comments relate more to how people record and pass on UTM coords as compared to what is actually written on map...that is a differnt story.
AnswerID: 240147
Reply By: tcmcdcac - Wednesday, May 16, 2007 at 21:28
Thanks!
It makes sense what you both said. I'll keep practising and keep that in mind. I was getting tricked and looking at the wrong part of the map. These are amazing gadgets but there are plenty of traps for the inexperienced!
Tony
AnswerID: 240426
