First off try not to get stuck in the first place.
To do that let the tyres down, between 20 and 15psi.
Make sure that you are in 4WD
Keep the momentum up
Don't turn the vehicle sharply. Make the turns are as big a possible
If you have to stop,
park the vehicle facing down
hill.
Drive in the other vehicles tracks, the sand will be already compacted.
If the vehicle starts to slow to a stop don't spin the
wheels trying to get out. You will only start to dig in.
If the vehicle stops or is bogged, dig the sand away from all around all 4 tyres. If the vehicle is sitting on the sills or under body, dig the sand from there as
well. Dig as much sand away as possible. The more sand is cleared the essayer the vehicle will be able to drive out.
Try a little AC/DC. Rock and Roll.
Drive the vehicle a bit forward and then a little back.
Slowly increasing the length of the track that you are making.
This will compact the sand and will able the vehicle to drive out. Don't spin the
wheels or you will end up bogged again.
How much of a track that you will have to compact will depend on how soft the sand is and how quick you can get the momentum up again.
Most times you will have to be dragged out by another vehicle, so don't go alone.
Wayne
242027
Thursday, May 24, 2007 at 12:51
good advice will help greatly
503025
