lpg - does injection avoid airflow meter damage?
Submitted: Friday, Jun 01, 2007 at 14:51
ThreadID: 46146 Views:2891 Replies:3 FollowUps:0
Hi - I've heard that injected lpg overcomes traditional problems of backfiring etc and associated damage to airboxes/airflow meters etc. Intuitively this would seem correct as lpg is being injected directly into the cylinder, but does injection overcome all traditional lpg problems and reduce the need to have electrics/ignition absolutely spot on?
I presume injection also results in better lpg power/economy, but presumably still not as good as petrol despite the hype?
Reply By: hl - Friday, Jun 01, 2007 at 15:28
You will find that the injection is done into the inlet manifold, not directly into the combustion chamber. Therefore the same problems could still happen.
AnswerID: 243989
Reply By: Andrew-rodeo - Friday, Jun 01, 2007 at 19:15
YES, having lpg injection avoids all problems associated with lpg in the past. You no longer have an inlet manifold full of lpg vapour, the injector is located as close as possible the the petrol injector and only injects the lpg vapour as required. The lpg computer is linked the the factory ecu and emulates the petrol injection.
AnswerID: 244025
Reply By: Dallas from Team Green Autogas - Saturday, Jun 02, 2007 at 18:18
G'day Pathfinder,
Andrew is spot on mate. The problem in the past has been that you have an inlet manifold full of lpg so if you get a crossfire from your ignition system then you ignite the entire manifold wurth of lpg resulting in backfires, blowing the airbox & airflow/mass meters to pieces.
With the new vapour injection system you have brass fittings fitted into the inlet manifold as close to the inlet valve as possible so you don't have a complete manifold full of fuel. This means there's not as much opportunity for a backfire as such. The worst that you'll get is a stutter / miss as you would get on petrol.
The vapour injection system will give you better efficiency than the standard venturi system so over the long run it would be the better investment but just remember that you'll really need to do more K's before you reach your payback point.
Dallas Green
AnswerID: 244205
