Thursday, Aug 02, 2007 at 18:29
Polyairs ARE the problem, The "Stock standard Ute would have Had the bumpstop plates broken off from overloading which compresses the
suspension so harshly that the bump stops are smashed again and again into the bumpstop plate.
If it was standard with no poly airs inside the coils this would have definately been what had happenned.
The better solution would have been to have put up with thicker coils on the patrol that were higher than standard giving you more distance between bumpstop and bumpstop plate.
Unfortunately people try and market a quick fix load carrying solution like "polyairs" and then when the user takes the vehicle off the highway and into the tough stuff the
wheels and axle cannot freely articulate up and down as they have a polyair shoved up inside them !
PS the pajero was an NM as
well just like the one you described as having owned except it had standard coils with the poly airs inflated more to compensate.
This is just one example of another vehicle that has come to grief from the dredded airbag ( I owned a TD 2.8 NM myself for years)
I am only stating fact and simple Physics so if you can't grasp what I have been trying to get across , then good luck and happy welding!
516661
