Annex pole carrier
Submitted: Wednesday, Sep 12, 2007 at 13:39
Member - Ken I (QLD)
I have searched the site but I cannot find where to purchase a tube that goes across the back of the van to carry the poles for the annex. Apparently the are available with locking end caps. I would appreciate a contact to purchase this item.
Reply By: Wizard1 - Wednesday, Sep 12, 2007 at 13:55
www.camec.com.au
261709
Reply By: Member - Cruiser (NSW) - Wednesday, Sep 12, 2007 at 13:55
I just measured the length I wanted and went to the local plumbing supplier and asked for 90mm diameter pvc pipe and the appropriate ends for it, one fixed and one screw type and made my own. I also bought some saddles and then fitted it in
the spot of my choice.
I think from memory,
mine was about 2 metres long and with everything it cost about $70.
261710
Reply By: Pajman Pete (SA) - Wednesday, Sep 12, 2007 at 14:20
Any plumbing supply company. Get sewer grade pipe - it is more robust. We have one fixed cap and one screw on one with a hole drilled through it to take a fencing wire safety pin. Some people use a small hasp and staple with a padlock.
Most caravan spares
places can sell you the clamps - get these first so that you know what size pipe to buy.
A circle of timber or sheet metal siliconed inside the endcaps can stop the poles bashing their way out on rough roads.
Pete
261717
Follow Up By: disco1942 - Wednesday, Sep 12, 2007 at 17:23
If you
shop at Bunnings you will find the bits you require for an annex pole are dearer than the price of Camec model (available from any caravan accessory
shop) if you build it out of sewer pipe. Try storm
water pipe if you are on a budget.
523167
Reply By: Member - Norm C (QLD) - Wednesday, Sep 12, 2007 at 15:00
Or you can make your own from 100mm (or larger) sewer pipe with screw on ends. Hasp and staple style locks can be added pretty easily if you wish, but I've only done this on one of
mine.
I've made a number of these. Have two on the CT for poles and fishing rods. Also have another 2 for the 4b. One is for a pull out awning, the other for longer fishing rods.
Norm C
261721
Reply By: Member - SKI er (NSW) - Wednesday, Sep 12, 2007 at 20:17
We made our own from sewer pipe as described in other posts BUT wish we had put screw ends at both ends. Shorter in length poles (TV) always seem to get down the tube and out of reach. 2 screw ends lets you reach in from both ends or let you push littl'uns through.
SKI'er
261771
Follow Up By: Member - Oldplodder (QLD) - Thursday, Sep 13, 2007 at 15:51
Had your problem too with poles ending up at the sealed end.
Now I collapse the poles so that they are about 100mm shorter than the carrier and do them up again.
Also ensures they don't get up any speed and break out the ends.
523349
Reply By: Member - Brian H (QLD) - Thursday, Sep 13, 2007 at 16:09
Use sewer pipe its stronger and will last. As for the ends I used the wifes cutting board trimmed to size it was about 10mm thick and I glued it to the ends so the poles would not break out.
Wife was not impressed ...... when she found out LOL, but i'm over that now. You will need something in the ends otherwise sooner or later a pole will come out. if your not wanting to stir the wife up like me ..... use ply :) but I preferred the look on the wifes face :) PRICELESS
As for your short pole problem I just gaffer tape them to one of the long poles and no problems. You could also use a bit of velco similar to what some people use to hold fishing rods.
Brian
261914
Follow Up By: Member - Norm C (QLD) - Thursday, Sep 13, 2007 at 16:28
I like the cutting board solution Brian. Didn't think of that. Might have got a similar reaction. I used ply in one of
mine.
I think this strengthening is more important when the carrier runs along the length of the vehicle. If it runs across the vehicle (or CT / caravan), there is less likely hood of momentum from the poles inside the carrier.
I haven't strengthened
mine that go across and no problem so far. But it doesn't hurt to be sure I guess.
523356
Reply By: Member - Ken I (QLD) - Thursday, Sep 13, 2007 at 16:25
Thank you for your advise. I will buy the sewer pipe and make it up.
261916
Reply By: Member - Niss42 - Sunday, Sep 16, 2007 at 15:13
Ken,
Don't use 90mm stormwater pipe as it wont last more than one trip on stonney tracks such as Ooddanatta.
I arrived at Dalhousie to find both ends bleep tered and no poles.
Barry
262481
