Welding to the Chassis, Is it Legal? Is it Safe?
Submitted: Thursday, Oct 04, 2007 at 13:27
ThreadID: 50243 Views:23499 Replies:13 FollowUps:18
Hi All,
Just bought some rock sliders that are bolt on(after you weld the mounting plate too the chassis). Will this weaken the Chassis? It is in my new 80 Series pics and write up soon (and will my old 80 will be on the trader!)
Matt
Reply By: Member - Karl - Thursday, Oct 04, 2007 at 14:26
Matt,
I can't see how they would weaken the chassis and I have seen pictures of other Cruisers with mounting brackets welded to the chassis - IMHO if you can drill a hole into it to mount recovery brackets then it should maintain it's integrity when welded.
BTW - I have fitted the side steps/scrub bars and they look good. Are you still interested in selling the roof bars?
Karl
AnswerID: 265016
Follow Up By: Member - Franga (QLD) - Thursday, Oct 04, 2007 at 14:39
Sorry to hijack your thread Matt.
Karl I noticed you have a DTS turbo setup on your cruiser, is that with the intercooler as well?
Was wondering what sort of fuel economy you are getting.
I have DTS & intercooler as well on my 95 80 series and i'm a bit disappointed with the economy.
Have only had mine since beginning of the year, it had only been on the vehicle for approx. 12mths before i bought it.
Franga
FollowupID: 526840
Follow Up By: Matt(WA) - Thursday, Oct 04, 2007 at 15:46
Hi Karl,
I am still sorting out both cars at the moment. Once I have them sorted I will let you know. Glad the steps fitted.
Matt
FollowupID: 526855
Reply By: madcow - Thursday, Oct 04, 2007 at 14:38
I'm probably wrong but welding could create a weak spot due to the heat applied and could take away the structual integrity of the steel.
AnswerID: 265017
Reply By: Kev M - Thursday, Oct 04, 2007 at 14:43
I thought you were sticking to the "Devil you knew"
Cheers Kev
Russell Coight:
AnswerID: 265018
Follow Up By: Matt(WA) - Thursday, Oct 04, 2007 at 15:39
Yeah I was but I ended up seeing gone bush's 80 in the trader and bought it. So I have added a few bits I wanted too keep off mine and some oh so comfy seats(Stratos xlltss x 2) and am just finishing it all off at the moment. When its finished I will put up some pictures
Matt
FollowupID: 526853
Follow Up By: Kev M - Thursday, Oct 04, 2007 at 15:46
How did you go about getting the seats paid for??
They wont pay for my office chair due to getting it while still in the ADF :((
Kev
Russell Coight:
FollowupID: 526856
Reply By: Member - Olcoolone (S.A) - Thursday, Oct 04, 2007 at 14:57
Hello Matt, this is a tricky question and the answer is yes and no.
It is illegal to weld to a chassie between suspension mounting / steering points, it is all to do with the Australia Design Rules unless you have it re engineered and approved.
The person welding it should be certified to Australia Standards AS1796 I think.
I personally don't think you would have a problem if you can or you can find a competent welder to do it.
You have to remember we aren't talking about the strength of the weld or where it is welded, just that it does not comply with the Australia Design Rules for that vehicle.
If the Police, or State Transport Authorities feel like picking on you or your insurance company may use it as an easy way out of paying a claim but I don't think they would because with the insurance company they would have to prove that that mod was the cause of your claim.
By welding it if welded correctly it will not weaken the chassie unless they use something like "HSLA" steel (high strength low alloy) in it whereby a different technique is used.
If it is normal steel, by welding it you will increase the strength in that area by increasing carbon grain growth in the steel itself.
Regards Richard
AnswerID: 265020
Follow Up By: Matt(WA) - Thursday, Oct 04, 2007 at 15:44
Thanks Richard,
I am handy with a welder but have a couple of mates that are HP Welders so I might get them to do it for me. Wasnt sure so just wanted to check.
Matt
FollowupID: 526854
Follow Up By: Hairy (NT) - Thursday, Oct 04, 2007 at 17:21
I second that..
FollowupID: 526875
Follow Up By: Shaker - Thursday, Oct 04, 2007 at 22:44
As long as your friends know to only weld logitudinally & never weld transversely on a chassis.
FollowupID: 526962
Follow Up By: Shaker - Thursday, Oct 04, 2007 at 22:45
try again, longitudinally
FollowupID: 526963
Follow Up By: Bonz (Vic) - Sunday, Oct 07, 2007 at 16:21
And I think you have to use stitched welds for a chassis
FollowupID: 527382
Reply By: Robin Miller - Thursday, Oct 04, 2007 at 16:37
Hi Matt
The 80 series cruiser chassis used higher tensile steel than Patrols and this should not be welded casually, you are better to bolt/screw to it.
Robin Miller
AnswerID: 265028
Reply By: Member - John - Thursday, Oct 04, 2007 at 18:24
Matt, ARB welded tabs to my chassis for the brush guards, not sure if it is legal or not, but it has been done. GU patrol ute.
John and Jan
AnswerID: 265049
Reply By: Shaker - Thursday, Oct 04, 2007 at 18:25
2.2 WELDING
2.2.1 A novice must not carry out the construction or modification of a chassis.
Numerous effects such as twisting and loss of strength can be caused by incorrect
penetration, preparation, or timing of weld deposits. Inspection of all welds and
the requirement for rework will be at the discretion of the Examiners. Structural
chassis welding is recommended to be carried out with the chassis fixed in a jig.
An example of a chassis jig is shown in diagram 2 (a) on the next page.
{Advisory Note: Those persons who have experience, but do not possess
certification, are advised to attend a TAFE or Private Provider Certified welding
course.}
AnswerID: 265051
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 04, 2007 at 19:02
Was discussing this very thing with a welder at work today and his opinion is.
DONT drill it and bolt is better
He maintains that weldiing can weaken the chassis and I said so does drilling hole in it. He said not as much as a bad weld that has overheated it or similar
I guess it depends where and how big the holes are.
He is by the way a certified welder so guess I believe him.
FollowupID: 526915
Reply By: Member - Kiwi Kia - Thursday, Oct 04, 2007 at 19:57
Hi Graham H., After you drill a hole put a plate over the hole in the chassis (both sides) and you have spread the clamping load over a large area of the chassis - this area is probably now stronger then it was before drilled the hole.
AnswerID: 265074
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 04, 2007 at 20:25
Oh another Kiwi but whats with the Kia
Yes but was thinking about twisting and spanning If you drill holes in the wrong place you can weaken things. I want to fit a bigger sub tank in my cruiser and was going to use a 95 litre GU one ive got. decided to make brackets to go around rather than through, like spring U bolts. Make sense????????????????
FollowupID: 526940
Follow Up By: Member - Kiwi Kia - Thursday, Oct 04, 2007 at 22:45
Graham, not long ago I had a long and a short Sportage (& Troopy & Pajero).
Now only have the Troopy in Oz, Pajero and long Sportage in NZ. Both the long & short Sportages are in my members rig pics. Very underrated vehicles, solid ladder chassis but a little low underneath.
Yes you can weaken if you drill to many holes but that's why you double plate the chassis and bolt right through so you have plate - chassis - space - chassis - plate. The clamping effect of the plates spreads the load along the chassis rails. Stronger then original.
FollowupID: 526964
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 04, 2007 at 22:57
Oh My neighbour had one of the new (6 months ) ago Kias and went on a trip with his van. Cost him $1500 for fuel for 5,000 km so he swapped it for a 98 1HZ croozer with 180,000 on it.
I reckon hes mad as he wont get much better out of that.
Im from Dunedin Where u from
FollowupID: 526968
Reply By: Ted (Cairns) - Thursday, Oct 04, 2007 at 22:58
Matt
I have no idea BUT I've seen stickers on a number of truck chassies stating "DO NOT WELD"
Ask someone who knows (???) from Toyota?
AnswerID: 265097
Follow Up By: Member - Olcoolone (S.A) - Friday, Oct 05, 2007 at 20:02
Ted, Truck chassis are made of high tensile steel.
You can weld the rails and most of the time there is not a problem however it is illegal and you can get in heeps of sh*$ if they find out. It is not something I would do or reconmend but some people like to cut corners and repair insted of replace and use bog to cover the welds.
It is also illegal to heat rails aswell
The correct way is to use a new smaller rail inside the original rail and bolt it, then you can weld the outer rail legally.
You can drill the rails but not the top or bottom flanges and the holes have to be more then 50mm's from the flanges.
It is however differant for 4x4 rails.
Regards Richard
FollowupID: 527120
Reply By: Member - Borgy.. (SA) - Friday, Oct 05, 2007 at 00:04
Matt , give my son Littleborgy S.A an MM , he is a fully qaulified truck body builder and specialises in chassis modification ......Cheers ......Dave
AnswerID: 265103
Reply By: Willem - Friday, Oct 05, 2007 at 07:02
In another life a long time ago, a wandering cow came into my sights and got smacked hard by the bullbar of my old FJ55 at 100lmh.
One of the results of this altercation was that the cross member at the front of the vehicle cracked at the join to the chassis. A mate and I used a power jack to push everything together and he welded it for me. This weld lasted about a year until one day it broke again while towing the 27 footer. The steering became rather valgue and we limped into a small country town. There a mechanic bloke dragged a welder(it looked abit like a Dalek) out of the depths of his untidy workshop. We used a come-along handwinch to pull the bits together and he melted some very thick welding rods over the damaged part.
Years later, when the old Cruiser was traded in, that was the only bit of the vehicle that was till intact. The rest of rusted out...lol
The moral of the story is that if you can find a real competent welder, that knows what he/she is doing, then you could strengthen the chassis instead of weakening it. As for the legality of welding to the chassis....who cares?
AnswerID: 265110
Follow Up By: Member - MUZBRY (VIC) - Friday, Oct 05, 2007 at 09:06
Gday Willem
How did you go with the "Spring Post" crack.
Murray
FollowupID: 527016
Follow Up By: Willem - Friday, Oct 05, 2007 at 11:16
G'day Murray
At the moment it is on the back burner. Busy laying some concrete down in the garage extension. Will get to it soon however, and will post the result.
FollowupID: 527036
Follow Up By: Matt(WA) - Friday, Oct 05, 2007 at 12:02
Thanks for everyones replys. I will give little borgy a bell and see what he has to say. A couple of verticle ups cant be too hard for a boilermaker. Cheers
Matt
FollowupID: 527046
Follow Up By: Hairy (NT) - Friday, Oct 05, 2007 at 20:52
Matt,
Vertical down on what your looking at would give you a lot less heat and penetration than an up but strong enough to do the job without severely affecting chassis.
There are no hard and fast rules...every job is different, Ive welded up down and all around chassis....trucks, cars buses etc, every job is treated differently.
Im a boilermaker/welder by trade and would honestly not like to give advice without seeing the job.
If you have a mate who is a welder, get him, ask if he'll to do it, even qualified people will give you advice that varies....let the person who is going to do the job decide.
FollowupID: 527141
Reply By: Member - DOZER- Friday, Oct 05, 2007 at 17:25
Matt
The chassis on a 4wd is not hardened steel,as in trucks, but mild steel, and therefore it is very easily welded by someone who can, but will bge a modification under the letter of the law etc etc..
As others have stated, make sure you knew nothing about it, the sidesteps were std as far as you new, and they were there when you purchased the car if insurance ask...
AnswerID: 265191
Reply By: QLD Kev - Saturday, Oct 06, 2007 at 08:45
Matt,
I just found on another forum Teabags new GU that he has set up, read the attached link it shows how his Cheezy slider were fitted.
Read This
Cheers Kev
Russell Coight:
AnswerID: 265265
