Point & Shoot Camera
Submitted: Thursday, Dec 20, 2007 at 10:39
ThreadID: 52708 Views:2709 Replies:12 FollowUps:6
Thinking of buying myself a good Point & Shoot Camera...at least 6 mega pixels.
I have a good Olympus SP-510UZ that I take away on travels, but would like a small camera that will fit in the shirt pocket when I go walking etc.
I always find a photo opportunity when I haven't got the good camera with me. The Mobile Phone camera is not adequate.
Would appreciate any comments or recommendations.
Thanks in advance and a safe and happy Christmas to you all.
Ian
One life. Live it while you can.
Reply By: Member -Signman - Thursday, Dec 20, 2007 at 10:44
Sony Cybershot...
AnswerID: 277613
Reply By: Flash32 - Thursday, Dec 20, 2007 at 10:45
If you want to take a punt on this go to chinavasion.com and you will find a few goodies at reasonable pricing and good delivery.Dont forget to use the AUD converter half way down on the RH side.
Havr tried them and they are fine
AnswerID: 277614
Reply By: Member - Mike DID - Thursday, Dec 20, 2007 at 10:50
If you want to take photos in very low light conditions without using flash, then the only choice is the Fuji Finepix F50.
AnswerID: 277615
Reply By: TerraFirma - Thursday, Dec 20, 2007 at 11:31
Sony DSCN2 is the Rolls Royce of these ,(Think now superceded) the value choice and by far the biggest seller is the Cannon Ixus 75 through to the 90 depending on your budget. $300 to $650.00 for the Cannon range. (Top to bottom) The Ixus 900TI is 10 Megapixels.
AnswerID: 277625
Reply By: mfewster - Thursday, Dec 20, 2007 at 11:55
As always, depends on what you want to shoot. I agree with Mike DID re choice for low light conditions, but the camera has a few issues under other light conditions. If you are into landscapes get something with as wide a lens as possible or one of the Canon Ixus range with the stitch assist feature that makes stitching them together easy, I also like my "always in the pocket " camera to have a view finder, not just an LCD screen on the back so I can turn the LCD off. this gives much better battery life as the screens chew up juice. I have been very happy with a Canon Ixus 800 is for this use.
Something else to think about. Pocket cameras are pretty vulnerable to scratching (unless you keep them in a bulky case which kind of defeats the purpose. There is a product called "invisi shield" that is used for protecting helicopter blade leading edges. Seems bulletproof and virtually invisible. Google and you will find it. I have used it on a few electronic things and think it is so good that I would only buy a packet camera if it was a model that had an invisi shield kit available. Not too pricey, but has to be posted from the USA.
AnswerID: 277628
Follow Up By: age - Thursday, Dec 20, 2007 at 12:39
mfewster
Similar product available from Exim called a Spuc - can be bought for most phones and some cameras. Easy to trim to size if they don't offer exact model. When the LCD is lit it is 99% invisible if applied correctly and to a clean surface. Have them on all my phones and cameras and the screens are still 100% perfect even after a couple of years
Available from a few places direct, but way way cheaper through Ebay
A
FollowupID: 541579
Follow Up By: mfewster - Thursday, Dec 20, 2007 at 13:05
Hi Age
The thing about invisi shield is that you cover the whole camera or whatever gadget, not just the screen. The kits come in a number of pieces that wrap around the various sections of the camera. The whole camera, except the lens, is covered in a virtually invisible and bulletproof layer. If you check their website, they have some impressive demos showing how well it protects. My experience with the stuff, while not as extreme, supports this. It isn't an ordinary film. It was developed to cover the leading edges of helicopter blades which are liable to impact damage, should they hit something, with catastrophic results.
FollowupID: 541580
Reply By: Peter McG (Member, Melbourne) - Thursday, Dec 20, 2007 at 12:16
Ian
I bought the Sony cybershot DCS W80 recntly for exactly the same purpose. Very pleased with it too.
AnswerID: 277631
Reply By: Member - joc45 (WA) - Thursday, Dec 20, 2007 at 12:25
Check out this site:
http://www.dpreview.com/reviews/
Apart from the obvious attributes, worth considering are:
- Low-light capability
- Stitch feature (Canon has it)
- Optical viewfinder. This feature is essential when you cannot see the LCD screen in bright daylight.
Gerry
AnswerID: 277633
Follow Up By: Member - Graham H (QLD) - Thursday, Dec 20, 2007 at 18:40
This site is recognised as probably the best reviews on the net
Always consistent and comparisons are all done under the same conditions
FollowupID: 541651
Reply By: Moose - Thursday, Dec 20, 2007 at 14:25
You should also check out www.photoreview.com.au
AnswerID: 277649
Reply By: Robin Miller - Thursday, Dec 20, 2007 at 14:32
Hi Ian
I can certainly endorse the comments made about the Cannon Ixus range.
I think mine is a Ixus 6.0 and it really is a slip in the
pocket and take everywhere unit that gives acceptable performance over a wide range of conditions.
I particularly use mine for taking short videos at VGA 640X400 resolution when out driving and using these to embrass others when they get stuck etc.
You get about 10minutes per 1 gig card which is great.
Pixels isn't very important as the lense and speed of processing
is more likely to be the limitation , so I rarely use mine at more
than about 3MP which blows up well enough for A3 prints.
I got a little slip in case for mine which still allows it to go in a
shirt pocket comfortably, and completes a simple effective package.
Robin Miller
AnswerID: 277650
Reply By: Member - Davoe (Yalgoo) - Thursday, Dec 20, 2007 at 19:08
big mega pixels in a small camera is a bit of a wank. the sensors are usually too small to handle it causing excessive noise.
it also creates storage issues mith a 10 meg photo taking up about 5 meg of storage. anything above a 6 meg camera is heeeeps i see some of the p and S are up to 12 meg
my fz50 is 10 meg but i usually shoot at 3 meg and take advantage of the cropping function which gives an effective 24x optical zoom and creates pictureas around 300kb
AnswerID: 277698
Reply By: Motherhen - Thursday, Dec 20, 2007 at 22:42
Hi Ian
Never mind what brand - just choose a recognised 'brand name' preferably with a good brand of lens. Pick one that takes standard batteries of the type you use for most of our stuff. I have two: 1) A Sony, which is a bit bigger and heavier than 2) Olympus which is a small lightweight one when i really need to carry just a pocket camera. Both take two AA batteries; both use the same type of download cord. Both are easy 'point and shoot' with heaps more features if i needed them, and both have the fairly standard 3 x zoom which i find adequate for holiday snaps.
Recently i was holidaying with my sister in Bali and she had chosen a Canon with its own type of battery, and like many rechargeables, it had reached a stage where it only held a charge for a short while, She could only take half a dozen of so photos before needing to recharge, and a new battery would cost as much as a new camera. My pair of AA rechargeables lasted almost all the holiday in my Canon (which i took because of its size) before i needed to put in the spares.
Don't get hung up on the need for more mega pixels unless you have a need to print huge poster sized photos. My first digital was a matchbox sized 1.3 mp BenQ. I can put the photos on a 19" monitor and they are still perfectly clear.
AnswerID: 277746
Follow Up By: Member - Davoe (Yalgoo) - Thursday, Dec 20, 2007 at 23:41
MH rechargebles for mine (panosonic fz 50) ARE $ 40 A POP
and last so much longer than AA baterys - easily the memory cards worth of 240 photos i have seen AA cameras and the others and i dont see its a selling point
FollowupID: 541700
Follow Up By: Motherhen - Friday, Dec 21, 2007 at 00:00
Hi Davoe
You've got a better deal than my sis with her Canon.
I took 200 odd photos in Bali and only changed the batts on the last day in the Olympus. I took the Sony to Kalgoorlie, and took 450 or so over two weeks, again changing the batts on the way home. I'm happy with that - they are cheap to purchase, and easy to charge in my AA and AAA charger so i only need to take the one charger. I didn't take a charger to Bali - just a few sets of spare batteries. I can even use regular AAs if i do run out of recharged batts. Hence this type of battery is on my criteria for a camera.
PS We saw some beaut snakes around sis's place - they come in from the rice fields. According to the book i just got, most are only mildly venomous and not harmful to humans.
FollowupID: 541702
Follow Up By: Motherhen - Friday, Dec 21, 2007 at 00:03
Ian, i should have added also to get one with a fairly standard type of memory card - they are cheaper and more readily available that really brand specific cards. I buy a few 1 gb cards then i can takes heaps on full resolution without needing to download till i get home.
Mh
FollowupID: 541703
Reply By: PajeroTD - Saturday, Dec 22, 2007 at 08:02
Check out the Panasonic TZ3.
Compact, 8 megapixel, Leica lens, 10 times optical zoom
http://www.dpreview.com/reviews/panasonictz3/
It bugs me when people ask for advice on an easy to use camera and people recommend digital SLRs
AnswerID: 277932
