L300 Engine swaps
Submitted: Wednesday, Jun 04, 2003 at 18:05
ThreadID: 5286 Views:18783 Replies:7 FollowUps:4
Mates Mitsubishi L300 4WD is getting a little sad and he cant afford a new 4Wd. Paarts Peddler has import 2.4lt engines for L300's. Does anyone know if they are a bolt up application and if not what is the cheapest way out with the least modifications to get a replacement donk with more grunt. At the moment my diesel hilux is like a petrol compared to the L300.
Reply By: diamond (bendigo) - Wednesday, Jun 04, 2003 at 18:37
we recently done a lL300 engine swap with an imported motor.
there was a few problems we had but nothing major.
motor was out a front wheel drive car nimbus i think so we had to change a water pipe .engine mounts ect.
motor was fuel injected but just bolted carby and manifold of old engine.
this was where we had a little trouble.
if the motor your mate gets is a fuel injected one change the timing cover over from the old motor and timing belt while your going.reason being fuel injected motor timing mark was in a totally diferent place to his carby one they run a much higher degree of timing.
apart from that everything else went good as gold.
when we got the motor it came with gaskets/engine mounts and a piece to bolt on where you change the qwater pipe to cover a hole from the old water pipe.
good luck .
looking foward to september(landcruiser park/fraser island)
AnswerID: 21858
Follow Up By: howesy - Wednesday, Jun 04, 2003 at 18:43
What size was the import motor in capacity and if you can let me know where you sourced it from. Thanx been good help.
FollowupID: 14273
Follow Up By: diamond (bendigo) - Thursday, Jun 05, 2003 at 08:56
gday howsey.
the engine we got was from an engine importer in geelong(vic).
he had a 1.8 but put in a 2ltr.
cost wasnt cheap about $800.looking foward to september(landcruiser park/fraser island)
FollowupID: 14310
Reply By: Dozer - Wednesday, Jun 04, 2003 at 19:55
Ive seen 2.6 astron motors in these cars. I have just sold a l300 2wd, and have a spare car in the front yard. It has a 2 litre with extracters in the back of it complete (almost) depending on where you are, it might be a cheaper alternative.
Andrew Wollongong
AnswerID: 21867
Reply By: Eric - Wednesday, Jun 04, 2003 at 22:12
Howesy.
The motor in the L300 at the moment is the 1800 I presume, a 2 litre sigma motor will go in easy the 2.6 has a bigger clutch and diferent bolts spacing. So if you can find a 2L sigma with a good motor and rusty body [standard] you will be ok, If you are in Melbourne I can supply, Eric.
AnswerID: 21878
Follow Up By: Dozer - Thursday, Jun 05, 2003 at 16:20
Hi Howsey
The std motor in a 4wd L300 is a 2 litre isnt it?
2wd L300 had 1.6 saturn, 1.8 and 2.0 but wernt Astron. The L300 4wd was thesame running gear as the Pajero that came with 2.6 std.
Andrew
FollowupID: 14357
Follow Up By: Eric - Thursday, Jun 05, 2003 at 23:17
Howesy.
The gear box in the L300 is not the same as the Pajero, it has a smaller bellhousing. the L300 4x4 was made with 1800 or 2000 never 2600, you can put a 2600 in but you have to use the block from an early magna as they used the smaller clutch, but if you do that you still have to get a sigma motor to get the front cover and water pump. I have done both conversions and the 2Litre sigma was the better result because the gear ratios are wrong for the 2.6. Eric.
FollowupID: 14394
Reply By: ray91 - Thursday, Jun 05, 2003 at 20:10
I have seen a six cyl in commodore in a L300 with commo auto box.
AnswerID: 21949
Reply By: Suzuki Viagra - Thursday, Jun 05, 2003 at 22:14
believe it or not a friend recently sent me a website showing a 2wd one of these being used as a plumbers van with a 350 Chev in it. It runs something like 11 second quarters with the plumbers roof rack still on it.
In all seriousness, that's amusing but not very sensible, unless of course you have a chev just sitting there.
Mistubishi have a range of import engines which sould fit, from 80 hp single cam jobs right through to Evo Lancer and Galant VR4 ones.
I bought a secondhand engine for a Hyundai Sonata I had once, then was absolutely furious when I found out it would have cost me less to fit a twin cam turbo GSR Lancer engine than a clapped out old 2.4 Single cam lardbucket......
You see, no-one even considered it as a swap, me included. But there are heaps of engines which will go into it, and often the biggest one isn't the fastest or best. Make sure you check out all the Mitsu engines in that age in 1.6-2.6 litre capacities before you decide.
AnswerID: 21961
Reply By: flappan - Friday, Jun 06, 2003 at 14:43
What about the G64B 2.4l ??? Maybe thats an option. They I think came out of the "newer" Starwagons.
I've seen a couple of 2.6 converts. They were very happy with it, but I never got around to asking how they went about it.
AnswerID: 21987
Reply By: Ian - Tuesday, Jun 17, 2003 at 21:29
I am currently converting my L300 1800cc to a Astron 2600cc. So far so good If you are interested the sigma GL AUTOMATIC motor fits easily you only need to alter the sump to miss the front diff (my biggest problem so far) and move the radiator forward 1 inch( easy with the way they mount it)
Take the auto stuff off the Astron and fit the fly wheel of the old motor and bolt the gear box straight on. I am a mechasnical moron and i seem to be muddling through
AnswerID: 22828
