Tuesday, Jan 15, 2008 at 11:19
G`Day Geepeem,,,Yes there are two types as you said. I have the non computer type that simply injects metered gas through a jet into the air intake. The gas is turned on and off by a micro switch on the accelerator pedal and the jet size is determined by running on a dyno until the correct size is found. It is a super simple system with only a T fitted into the heater hose to supply warm
water to the regulator, and the crankcase breather hose relocated behind where the gas is injected. This is done to prevent gas entering the crankcase. My Navara has the ZD 30 engine and is turboed. It was fitted by a company called
Liberty gas in Rockingham WA. As I have said I am very happy with the set-up so far. The gas
tank is a 40 Ltr that holds 38 Ltrs gas and fits up under the chassis and the system uses 15 Ltr gas per 1000Km so has a total range of over 2000Km. The reason I chose this system was its simplicity and the fact that it has minimal interference with the engine and electrics, and the total cost of $3865.00. After rebates it only cost me $865.00 . I feel the advantage of extra power as we pull a 20Ft van and the extra 100Km a
tank of
fuel will soon pay for its self. Hope this information is of some help. Regards Nav.
546055
