Towing with GQ 2.8L t/diesel
Submitted: Sunday, Mar 02, 2008 at 12:08
ThreadID: 55106 Views:3882 Replies:7 FollowUps:4
The vehicle - 97/98 Nissan RX Patrol 2.8L turbo diesel 6 cyl.
The question - If I was considering buying one of these vehicles
(lets presume it's in good or better condition) to tow a 1.5t pop top would those of you who have done so recommend it as a tow vehicle or in hindsight wished you had gone for the 4.2 diesel instead?
Was it reasonably economical? K's to the tank, with a van ?
Any answers greatly appreciated.
True Blue.
Reply By: stefan P (Penrith NSW) - Sunday, Mar 02, 2008 at 12:34
Sorry can't comment on the GQ. But have a GU 2.8
They are fine once they are rolling, BUT the lack of torque off boost makes taking off a bit tricky with a load, on hill starts it is quite hard with out slipping the clutch a bit.
Keep the speed at around 90-100km/h max when towing should get you comparable economy to the 4.2.
Go over 100km/h PAY THE PRICE at the fuel pump!!!
Sticking to around 95km/h my GU returns around 12lt per hundred.
Sit on 110-115km/h it goes to around 16-17lt per hundred.
The 4.2 won't be any faster.....but heaps more drivable with the better low down torque.
Test drive both and see how you feel....better yet take the pop top with you and try both.
Cheers Stefan
AnswerID: 290371
Reply By: Member - andrew B (Kununurra) - Sunday, Mar 02, 2008 at 12:57
Gday True Blue
Both Stefan and myself have been through a bit with the 2.8.....hindsight is a wonderful thing, my rig pics should explain with a new purchase. Altough I haven't sold the 2.8 (dark blue) I recently got a 4.2 GU and it is soooo much better at everything. Easier to drive, probably about a tie in a side by side drag race (probably not the most exciting quater mile to witness!) but cruises effortlesley, uses less fuel, will pull my boat out of the boatramp at low revs without riding the clutch (2.8 is a low range or change your clutch a lot job)......should I go on...not 'flighty' off road (throttle position and gear not as crutial) more reliable, stronger gearbox..
Any way, I would advise the 4.2 well above the 2.8.....Want to buy a 2.8 GU??? has a few problems....probably needs a new head.....V8 would go well in it......going cheap!
From what I have heard, the older 2.8 in the GQ didn't have the electronic injection pump and intercooler, and was a bit less powerful (not sure that word goes with these engines) and more reliable/cheaper to repair
Good luck
Cheers Andrew
AnswerID: 290372
Follow Up By: stefan P (Penrith NSW) - Sunday, Mar 02, 2008 at 13:02
G'day Andrew,
Hows the fitout going with the new beast?
Stefan
FollowupID: 555705
Follow Up By: Member - Glenn G (QLD) - Sunday, Mar 02, 2008 at 14:00
I have the same complaint about my 2.8 GU.pulling the boat out the ramp is a low range job or a lot of clutch riding,The wifes Subaru Outback 2.5lt pulls the boat out better !
Giffo
FollowupID: 555715
Follow Up By: Member - andrew B (Kununurra) - Sunday, Mar 02, 2008 at 15:34
Gday Stefan
fitout going well, bull bar, _Affordable_Storage_Drawers.aspx and roof racks fitted. New dual battery set up should be here soon, along with dual wheel carrier. Gas to be transfered in a couple of weeks, baybe some springs involved as well.....
From what I have read about them, I will get a new uhf, one of the flash gme units with all the controlls on the spit collector so the unit can be mounted out of site. Can't afford much else for a while, can't really aford what I have already ordered, but what the hell, its only money
Cheers Andrew
FollowupID: 555741
Reply By: Oldsquizzy (Kununurra) - Sunday, Mar 02, 2008 at 13:34
LOL, was going to say ask Andrew B...Doing much ?
AnswerID: 290374
Follow Up By: Member - andrew B (Kununurra) - Sunday, Mar 02, 2008 at 15:27
Busy on the net doing work related research LOL
FollowupID: 555739
Reply By: Kiwiausie - Sunday, Mar 02, 2008 at 15:05
Hi . We have a GQ 93 model 4.2 non turbo diesel done just on 470.000kms . we were away at Xmas towing our camper trailer approx 1250 kg .I have a very heay right foot cruise speed 115kmh (when it gets there). it will sit on that all day long until i come to a hill , sure its a bit of a Slug on hills . but just keep changing down & keep the revs up & she goes allright......
Fuel Consumpstion i get just on 520 kms per 75 litres 14.4. litres per 100 kms . Thats not bad considering fully loaded vehicle 4 people fridge , safety gear , etc also roof rack kids bikes etc
AnswerID: 290395
Reply By: Member - Barnesy - Sunday, Mar 02, 2008 at 18:33
I haven't driven one of these but common sense would say the 4.2 would be a lot better to tow with. There is no substitute for cubic inches, despite a turbo.
The 2.8 also has the smaller gearbox and drivetrain.
AnswerID: 290437
Reply By: Kumunara (NT) - Sunday, Mar 02, 2008 at 23:04
True Blue
I had a 1997 GQ RX 2.8 TD patrol
I know have a GU 4.2 TD
I have towed camper trailers with both.
Buy the 4.2. It is an excellent towing vehicle and I get 15L/100km when towing the camper trailer and fully laden.
Tjilpi
AnswerID: 290502
Reply By: True Blue - Monday, Mar 03, 2008 at 18:32
Thanks to everyone who replied to this thread.
It was pretty much as I thought it would be, but just wanted to ask anyway.
thanks again and happy motoring to you all.
True Blue
AnswerID: 290625
