Saturday, Jun 21, 2003 at 13:01
Hi Paul.
I have gone down this path with my troopie at the cost of ignorance thinking that I would get it cheaper then another type of diff locker.
I had an Detroit Soft Locker installed into the front diff. I found this diff lock to be just the 'ants pants' EXCEPT in mud and loose beach sand (in W.A. we have a lot of both) where it was a HUGH handicap as it would either bog me or give me little or no steering.
Just as a short note here. When the diff is in the locked up mode steering is very effected, power steering or not (which I have). To over come this problem I had to ease my foot off the pedal and the diff would sense the difference in the rotation of the two front
wheels and one axle would cam out to allow for the turn. When back in a straight line the
wheels would again lock up and I could just about drive up a brick wall :-)).
The problem: In mud there is not enough drag to allow for this camming out, hence effected or no steering at all.
In beach sand, if I took my foot off the pedal, I stopped!
If I tried to turn in
the beach sands without easing the pedal as required, one wheel would turn normally and the other would act a huge bulldozer pushing the sand in front of it until I stalled. Equally as bad, 99% of all tracks that I have come across leaving
the beach have either an sharp left or right turn halfway up them. If I did not ease the pedal, I went straight on into the bush, if I eased off I stalled halfway around
the bend.
If for any reason I stopped in loose sand without reversing back onto my track marks I would get bogged when I next moved off because both the front
wheels would bite in instead of walking out along the sand (Yes, I do let my tyres down in loose sand, and yes I do move off gently, and yes I do have enough power)
Lastly, again in beach sand, when I tried to follow in the tracks of vehicles in front of me, I would wallow around like a beached whale, as the tracks ALWAYS weave about even if slightly, and my truck tried to go straight on. I had my heart in my mouth a number of time when it lurched violently....Perhaps I may have been going a bit fast also, but then do you want to be left
miles behind your convoy?
This presented so much problem to me that I forked out extra cash and traded my front diff in for a Detroit True Track LSD.......an excellent investment, no more of the previous problems and I still have very good traction!
I have since installed an ARB air locked into the rear diff with which I am very pleased.
Knowing what I know now I would have saved a bit more money and maybe it may have taken a bit longer but I would have installed an ARB air locker also into the front diff. That way I have complete control over my machine.
A very stressful and costly exercise on my behalf, because between the 2 front diffs I had the money for an ARB conversion.
How does it go? A fool and his money..........
Give it some very serious though before YOU part with your money.
23143
Follow Up By: Member - DOZER- Saturday, Jun 21, 2003 at 19:19
I agree with Paul, if you want a locker, get one you can have 100% on or off, as there are times when you want to be in 4wd and turn the front
wheels left or right. To do that you need to be in 2wd with a front locka, and if you change from backing off to powering in a turn, you will need power steering to keep the
wheels turned....
Go an ARB, front or back doesnt matter.
Both is better.
Andrewwheredayathinkwer mike?
15345
