Wire Gauges
Submitted: Monday, Apr 14, 2008 at 17:16
Member - Ian W (NSW)
I'm about to wire up a Podigy Brake Controller. If the truth be known I'm gettinging the bits so that my electrician son can do it for me.
Now the Yankee instructions specify minimum 14 gauge wire.
Is 14g an international standard or do I need to convert that size to "Australian Speak" when I front into Jaycar to purchase the required run from the controller back to the camper trailer?
Any assistance would be appreciated. Just in case no one has picked it up, I'm a complete novice at this electrical stuff.
Ian
Reply By: Member - Mike DID - Monday, Apr 14, 2008 at 17:26
As`long as it'si 14AWG (American Wire Gauge) or 14B&S (Brown & Sharpe), they're the same thing. B&S became AWG.
There is the British SWG, which is totally different.
298463
Reply By: Dunaruna - Monday, Apr 14, 2008 at 18:07
In aussie speak -
If it's a single axle (2 x magnets) 4mm for the blue is adequate but 6mm is the norm, especially for tandems.
The red only needs to be 3 or 4 mm.
298472
Reply By: Derek from Affordable Batteries & Radiators - Monday, Apr 14, 2008 at 18:31
Let the auto electrician supply the wire and fuse.
Derek.
298480
Follow Up By: TD100 - Monday, Apr 14, 2008 at 19:21
here here Derek
564616
Reply By: Member - Ian W (NSW) - Monday, Apr 14, 2008 at 19:34
Thanks Mike & Dunaruma,
You have given me something to start with.
As I said in my post, I wish to have the right bits and pieces for my electrician son to kick off with. If I was giving it to an auto electrician I would let him do the whole job but after a number of half arsed jobs charged at extortionate rates and sub standard results I'm more than happy to approach this job from a diferent direction. Son is more than happy to do it, I just wish to do the running around to save his time.
Ian
298509
Follow Up By: Member - Mike DID - Tuesday, Apr 15, 2008 at 12:03
. . . exactly. A friend got a quote for 4 gauge wiring to the Rear of the Troopy by his "friendly" Auto Electrician.
When he went to pick it up he had wired it with totally useless 4mm wire.
564768
Reply By: autosparky - Tuesday, Apr 15, 2008 at 00:11
Hi Ian 14awg is 4mm wiring in my trade i use 5mm twin it solves vd( volt drop) and most trailer plugs will accept the connection of the 5mm wire saves a lot of hassles later on and gives peace of mind knowing you have compensated for all adverse contingensies
298581
Follow Up By: Member - Ian W (NSW) - Tuesday, Apr 15, 2008 at 08:01
autosparky
Thanks for your reply. Appreciate the input.
Ian
564709
Follow Up By: Paul Grabonski. Vic - Tuesday, Apr 15, 2008 at 08:04
yes 5mm every time.
you also need 20A Col Hersey type circuit breaker
564712
Follow Up By: Member - Ian W (NSW) - Tuesday, Apr 15, 2008 at 15:33
Thanks Paul,
Have the circuit breaker
Ian
564790
