Fridge temp ??
Submitted: Friday, May 02, 2008 at 18:15
ThreadID: 57205 Views:3875 Replies:9 FollowUps:5
Hi All
Can anyone please tell me the best temp to run my new fridge at??
Its a trailblaza 60lt...
Reply By: RalfR - Friday, May 02, 2008 at 18:23
My research reveals the ideal beer temp to be 2.5 degree C.
Pretty much all you need to know.
AnswerID: 301718
Reply By: Member - Phillip S (WA) - Friday, May 02, 2008 at 18:29
Fridges......2 to 4 degrees c.
Freezers.....-18 to -22 degrees c.
Information from the fridge / freezer thermometers purchased from aplliance stores.
AnswerID: 301721
Reply By: VH-GU4 - Friday, May 02, 2008 at 18:30
I run my fridge on about 4 degrees, but if you like your beer icy cold then maybe colder. Just the remember the colder it is the more your fridge has to work and the bigger drain on the battery.
AnswerID: 301722
Reply By: Affordable Batteries & Radiators - Friday, May 02, 2008 at 18:39
Hi jonboy
Around 2 deg is good. This should allow for cycles with out freezing food or allowing meat or cheese to get warm.
Derek.
AnswerID: 301725
Follow Up By: Member- Tony C - Saturday, May 03, 2008 at 15:26
Derek,
Just wondered if you could tell me how much quicker my 105ah battery would run down maintaining a 40litre Engel at freeze temperatures compared with normal fridge temps?
I am going on a trip soon and have a fair amount of meat in the deep freeze and tossing up wether tp take it frozen or thaw it out before hand and have it vaccum sealed.
Tony
FollowupID: 567928
Follow Up By: Affordable Batteries & Radiators - Saturday, May 03, 2008 at 15:50
Cryovac is the way to go especially if you only have 105 a/h which is around 3 days in fridge mode.
Most butchers will prepare your cryovac portions for your trip. I had this done for my last trip and had the meat right at the bottom of the fridge under the cold beer.
Just make sure they are a reputable shop and keep your fridge at around 1 to 3 deg.
FollowupID: 567932
Follow Up By: Member- Tony C - Saturday, May 03, 2008 at 19:44
Thanks Derek.Thats a great help you have more than answered my question. cheers Tony
FollowupID: 567979
Reply By: kcandco - Friday, May 02, 2008 at 20:16
Hi Jonboy
Whilst travelling and the fridge is running from the car I usually set my fridge to -4. I find that after half a days travel, the contents are very cold but not starting to freeze. Once camp is set up I change the setting to +3. I figure this has given the fridge a head start of 7 degrees and therefore reduces the drain on the battery if not starting the car for a couple of days. I have a dual battery setup, which I highly recommend.
Cheers Kc
AnswerID: 301742
Follow Up By: Mainey (wa) - Saturday, May 03, 2008 at 09:41
Kc
I understand at Minus four degrees (-4) water will actually turn to ice
as most veggies are mainly water, why don't they suffer from 'freezer burn' and wilt ??
Maybe the temp gauge is not too accurate ??
Mainey . . .
FollowupID: 567897
Follow Up By: kcandco - Saturday, May 03, 2008 at 20:29
Hi Mainey
I transfere goodies from the home fridge at about +4 to the car fridge. I put drinks and meat type goods on the bottom closest to the cooling element and place vegies or other more fragile items in the top basket. That way I find the drinks very cold, probably near ice stage but the vegies ok. The digital readout says -4 but bear in mind that it is at the bottom of the fridge and also that a full load is placed into the fridge so it takes a while to chill all this down. I dare say that any longer would see problems with freezing , just as you say. Before installing the dual battery system I also used to freeze as much as possible.
regards Kc
FollowupID: 567988
Reply By: warbo - Friday, May 02, 2008 at 20:47
well done on buying Australian made, I have an Explorer has analog temp guages in it run fridge at 0 freezer at -15 works good for me!
AnswerID: 301751
Reply By: Bri - Saturday, May 03, 2008 at 00:54
I reckon you are right ....but when we get the chance to get OUT THERE I am happy with a beer ...or 2 that is anything below 5
Bri
AnswerID: 301788
Reply By: Gronk - Saturday, May 03, 2008 at 00:57
For me its 1 deg.....just before the soft drink is freezing but the beer is icy cold....
Depends on how warm you like your beer ??
AnswerID: 301789
Reply By: Member - Stephen L (SA) - Saturday, May 03, 2008 at 08:34
Hi Jonboy
When we were involved in the food industry year ago, 3ºC and lower were the temperatures that you had to aim for to keep food from bacterial growth. Temperatures above 4ºC, your food will go off very quick, and with some food types, eg chicken and seafood be very back for you heath and can even cause food poisoning.
Stick to 3ºC or lower and you will have no problems.
AnswerID: 301800
