How to season a steel hotplate ?
Submitted: Wednesday, May 28, 2008 at 13:49
ThreadID: 58090 Views:8433 Replies:7 FollowUps:3
Howdy everyone, I've just resurrected an old steel plate from the back yard, welded legs on it and given it a dose of the wire brush.
There still remains a fair bit of pitting and a light coating of rust.
Before I attack it with solvents, does anyone have any ideas on how to season or prep the plate ready for its first camp fire sausage ?
Cheers.....Lionel.
Reply By: Matt(WA) - Wednesday, May 28, 2008 at 13:59
Hey Lionel,
Hows it going mate? I normally just get a bit of a fire going and put it on. Get it nice and hot and give it a bit of a squirt with the hose. Or a bucket of water. That should get rid of most of the nasties. Then oil it up and let it cool down a bit. Then your right to go.
Matt
AnswerID: 306306
Follow Up By: Member - Fred G (NSW) - Wednesday, May 28, 2008 at 17:30
Ditto what Matt says.......even heat up a couple of times if a really old plate, and repeat the water treatment, hose presure is good if available, then let the heat left in the plate dry it and then re heat and season with vegetable oil. That's what works for me anyway.
Happy cooking
Fred.
FollowupID: 572331
Reply By: dedabato (SA) - Wednesday, May 28, 2008 at 15:37
Hi mate, I totally agree with Matt but also after the initial clean-up get some spring onions and cut the green shoots off of it, chop it up and put it on the hot sizzling plate for few minutes while stirring it around (If you notice slime jell from the green shoots it is a natural Teflon and plate will NOT rust after use.) After each use just wipe it off and put it away for next time.
Cheers and enjoy your first BBQ on it.
dedabto
Image Could Not Be Found
AnswerID: 306322
Follow Up By: Member - Mark G (NSW) - Wednesday, May 28, 2008 at 17:39
gees you blokes,ya makin me hungry!!!!
FollowupID: 572334
Reply By: Member - barry F (NSW) - Wednesday, May 28, 2008 at 17:37
Howdy Lionel, good advise so far, but the most important bit has been left out.
Heating, cooling & oiling the plate only looks after the needs of the plate & you yourself are being neglected.
You should consider having your wife keep a chilled stubby within easy reach as you slave away for what will be a very enjoyable BBQ. LOL & Cheers
AnswerID: 306338
Reply By: Scrubcat - Wednesday, May 28, 2008 at 20:48
G`day Lionel,
Get plate hot enough to sizzle water.
Have a can/stubby.
Mix 50/50 vinegar and water.
Have a can/stubby.
When plate is hot pour mixture over plate and wipe with paper towel. Don't get the fumes from vinegar into your breathing system.
If you do have another can/stubby immediately.
When dry, oil plate.
Have a can/stubby.
Put tucker on.
Have a few more cans/stubbies while it`s cooking.
This is also an excellent way to clean a dirty/oily bbq plate before use.
I use it all the time when away camping.
Scrubcat.
AnswerID: 306372
Reply By: Member - John W (WA) - Wednesday, May 28, 2008 at 23:10
I`ve always lite the fire under
heavy sprinkle of salt over the plate
when its hot , splash a lot of water on & swirl it around the plate
makes it look a weird white scarred top as the water evaps
then a light cover of oil , wipe off excess salt/oil
& plate is cured
cheers John
AnswerID: 306409
Reply By: Member - Lionel A (WA) - Thursday, May 29, 2008 at 07:24
Thankyou Gentlemen.....and Matt......hehehehe.
Excellent advice, the missus has been given the fire, water, salt, onion and oilling duties.
My job is stubbie storage and turnover.
Cheers.....Lionel.
AnswerID: 306422
Follow Up By: Matt(WA) - Friday, May 30, 2008 at 15:28
Thats not very nice
FollowupID: 572664
Reply By: Ozboc - Friday, May 30, 2008 at 18:31
I often have to do this with one of my old plates made from 10 mm plate ....
If you have a wire brush that you stick into your Drill , just use that to rip off all the rust ..... then use salt on a rag and oil -- heat the plate and rub it into the plate -- this acts like sand paper
and lastly -- get some cheap nasty sacrificial sausages -- cook them on the plate ---Lots of cooking oil ..... then give to the dog ---
this is what i do --- still alive today --and no signs of testiness
Boc
AnswerID: 306798
