battery packs
Submitted: Thursday, Dec 06, 2001 at 01:00
ThreadID: 587 Views:2859 Replies:3 FollowUps:2
I am thinking of purchasing a battery pack to run my fridge when away on camping trips,has anybody had any experience with these type of units as compared to a duel battery set up ? ,thanks Ian
Reply By: Steve Campbell - Thursday, Dec 06, 2001 at 01:00
I've used one before I put in my dual battery setup. It was good as it was not tied to the Troopy (ie I could put in next to the tent if I went for a drive). However, I found the capacity was not great, and it took much longer to charge than my Optima Deep Cycle. I suppose it depends on how often you'll used it.
AnswerID: 1538
Reply By: porl - Thursday, Dec 06, 2001 at 01:00
I suggest that if money is an issue and you will be running the car almost every day - don't use the battery pack to run your fridge, use it to start you wagon if its battery is ever run down by running the fridge off your accessory outlet every day and night. But be sure to change your battery for a heavy duty one that won't usually run out overnight.
AnswerID: 1540
Reply By: Patrick - Thursday, Dec 06, 2001 at 01:00
Hi Ian - I had a simailar question on this site back on 24 October and receieved some interesting feedback.
In my case I was looking at a Thumper unit to power my Waeco 52 litre fridge because at that time I understood that a 2nd battery system could not be installed in my Pathfinder. I subsequently found through an aftermarket dealer in Brisbane that I could. The 2nd system cost $650 which was for an Parnaha tray with an Optima deep cycle battery plus 2x 6amp cables to connectors in the rear. The Thumper alternative was $700 - $750 and I found through the advice received that it would only run my fridge for around 24hrs before charging would be required. The charging process is very slow and could take up to 18hrs to conmplete.
There were plenty of people who said that they liked the Thumper but I also spoke to extremely experienced off-roaders and a couple of local 4wd shops who said that they are more suitable to low ampage use rather than powering a fridge.
A normal Danfross 35 condenser can use up to 4 amps per hour when the conditions are hot so it does not take much to draw down a 48amp battery. Remember that you have to allow for a cut off at around 20% of that.
I believe that after all the advice I received that my decision to install the 2nd battery sysyem was the more practical and cost efficient way for me for the future.
For more info try doing a search of Exploroz.com by simply going to the search option, typing battery packs of power packs and up it come.
Best of luck
AnswerID: 1542
Follow Up By: Ian - Thursday, Dec 06, 2001 at 01:00
thanks guys it gives me something more to think about !!!! ian
FollowupID: 487
Follow Up By: Geoff - Monday, Dec 10, 2001 at 01:00
Patrick could you e-mail me the Brisbane dealer who did the work
Thanks Geoff
FollowupID: 497
